Ok I guess since it is a partly revert and you confirm it working I think there is no harm adding a patch.
So I will add the partly revert patch and also your fanartres patch. But right now I need to do an emergency 9.2.4.1 release.
Yes but always the same even 4.9 if I restore backup parameters. By try to set only some parameters it’s run without any freeze when start a movie. I need to check each parameters one by one for try to found one who cause this freeze.
But still crash issue without any logs when you start playing or when go 1/2/5min later :
2020-08-13 19:43:23.001 T:3765429120 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, pass-through)
2020-08-13 19:43:23.356 T:4086894608 NOTICE: Whitelist search for: width: 3840, height: 1608, fps: 23.976, 3D: false
2020-08-13 19:43:23.357 T:4086894608 NOTICE: Display resolution ADJUST : 3840x2160 @ 23.98 - Full Screen (40) (weight: 0.000)
2020-08-13 19:43:23.560 T:4086894608 NOTICE: VideoPlayer: OnLostDisplay received
2020-08-13 19:43:23.560 T:4086894608 ERROR: GetString: error reading /sys/class/amhdmitx/amhdmitx0/custom_mode
2020-08-13 19:43:23.768 T:4086894608 NOTICE: VideoPlayer: OnResetDisplay received
Do you have an AVR between box and TV?
HLG and HDR10+ are most definitely work on CE.
I’m not sure what the problem is with your setup, but it’s most likely an issue with configuration/connections.
