Definetely supports as I see that when playing the file directly via USB flash.
No, my box directly connected to TV. Could be the prioblem with the box? I heard there are different revisions of 905x3. Or could be HDMI cable an issue? (I think not as HDR is ok and HDR10+ just dynamic version of HDR10)?
You need to make sure that HDR10+ is even supported over HDMI on the TV.
It’s unlikely to be the cable. Very likely to be some settings in the TV, or maybe it doesn’t support HDR10+ over HDMI.
no new nightlies? the ones i found are dated 1.8.
from the relkai url - did that change?
URL is still the same, just nightly builds have been turned off.
Normally we stop the nightly build for a few days, and have the update system move users back to the stable build, so that users that were only using the nightly builds while they waited for hardware support for their device, or for some important fix to end up in stable, didn’t end up missing their exit to the new stable.
However this release cycle has gotten messed up because of a couple of major bugs, which is why the extended time without nightly builds.
thanks for clarification!
Tried to reboot to the Box’ Android TV and play the file with MX Player. Everything seems ok, TV detects it as HDR10+ source. The same box, the same cable. So could be any incompatibilities between box and CE?
No.
Try to enable the 4:2:2 chroma option in CoreELEC settings.
Affter enabling this option TV detects signal as YUV422 12bit (previously was YUV444 10bit) but still simple HDR. Neverless the picture looks great, bright and colorful.
What type of signal does the TV detect in Android, when HDR10+ works?
YUV444 8bit
Hi, I’m trying to build CE-ng for my device. Can anybody tell me in which package the dtb files are built in the NG version? There is a device-trees-amlogic package in the Amlogic project which I used to do the customization for the non-ng version but not in the Amlogic-ng project.
In kernel. Either fork the kernel or make a patch for the kernel.
All right. Thanks!
Hi @Ray, I’m going back to the resolution issue we’d roughly a month ago. I’m on the latest nightly from last night, however I noticed on latest stable again. It is the issue of N2 going into 840i mainly after exiting a playback or starting a playback (video). To fix it I need to select a resolution via the GUI.
I tried to open logs however can’t really reproduce as happens once in a while. Maybe it is something related to the GetCurrentResolution / ‘hdmimode=’ you fixed back in 12 July?
N2 connected to TV directly with a good official HDMI and TV HDMI settings on Extended (Sony ADV)
It is not a massive issue as rarely happens and easy to fix, though I thought to drop a note maybe there is a fix.
Many thanks!!
I hate when this happens. I have a different issue I can never catch the issue when debug is on. I’m happy to look at it but only logs would help doesn’t matter if it’s my own or your issue.
Will try to catch it… Thanks!
Can I know in which step the NG version changes the device bootloader? With my Phicomm N1(S905D) device, the bootloader can boot both the NG and non-NG versions directly. But once I boot the NG version, I’m not able to boot the non-NG version. I checked the bootloader and there is some preboot steps changed by the NG version. I did a check with all the startup scripts but couldn’t find anything changing that. Is that change in the kernel?
Applied 20200823 update to A95X Max (S905X2) and noted that the shutdown option, that resulted in a reboot being performed instead has returned following seemingly having been eliminated in 9.2.4.2 stable.
I don’t need a solution as I already have a fix to replace the DTB with an older version that works, so will just apply this on each update.
So just something to note in case others who may come across the same issue can be aware of.
ok, so i have s912 box and after update to 20200823 from 20200730 my ftp access is not working im runnig filezilla server on windows 10 pro os this is log from filezilla
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> Connected on port 9999, sending welcome message…
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> 220-FileZilla Server 0.9.60 beta
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> 220 Please visit https://filezilla-project.org/
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> TLS connection established
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> USER xxx
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> 331 Password required for xxx
(001802)27.8.2020. 20:09:15 - (not logged in) (xxx.xxx.xxx.xxx)> PASS ********
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 230 Logged on
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> PBSZ 0
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 200 PBSZ=0
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> PROT P
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 200 Protection level set to P
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> PWD
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 257 “/” is current directory.
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> PASV
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 227 Entering Passive Mode (195,154,165,139,222,166)
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> TYPE A
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 200 Type set to A
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> LIST
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 150 Opening data channel for directory listing of “/”
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> TLS connection for data connection established
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 226 Successfully transferred “/”
(001802)27.8.2020. 20:09:15 - xxx (xxx.xxx.xxx.xxx)> 227 Entering Passive Mode (195,154,165,139,231,207)
(001802)27.8.2020. 20:09:16 - xxx (xxx.xxx.xxx.xxx)> 450 TLS session of data connection has not resumed or the session does not match the control connection
(001802)27.8.2020. 20:09:16 - xxx (xxx.xxx.xxx.xxx)> disconnected.
going back to 20200730 build all is working fine
