Ok.
and the lan network? Will it have a solution?
The the 100mb device tree, some device are marketed as gbit whilst not actually being gbit.
in android it is gigabit without problems 400/400
the tree tested 100 and the result is the disappearance of the network
summarizing :
sm1_s905x3_4g_1gbit.dtb lan network is present but does not work
sm1_s905x3_4g.dtb lan network disappears
My TV box model is a95x F3 air(905x3). After installing the version of ācoreelec-amlogic-ng.arm-9.2-nightly_-generic.imgā, the startup is normal, the operation is basically normal, the network card and voice are normal, and the fiber audio is normal, but WiFi is not working, Bluetooth is not working, and the WiFi core seems to be mt7668
Updated from 20191217 to 20191218 on my A95X Max.
After the upgrade process and subsequent boot there was no GUI, just the CE logo and a variety of text.
I was able to SSH into the box to run a reboot but upon issuing the command, the server connection was closed and no reboot was carried out. I was also unable to SSH back again.
I switched the box off and on again and the second boot was successful.
Looking at the log for the first boot I noticed the following lines at the end:
2019-12-19 03:12:35.391 T:4062125504 ERROR: failed to initialize EGL display (EGL_NOT_INITIALIZED)
2019-12-19 03:12:35.392 T:4062125504 FATAL: CApplication::Create: Unable to init windowing system
2019-12-19 03:12:35.392 T:4062125504 NOTICE: Stopping player
2019-12-19 03:12:35.392 T:4062125504 NOTICE: Storing total System Uptime
2019-12-19 03:12:35.392 T:4062125504 NOTICE: Saving settings
2019-12-19 03:12:35.402 T:4062125504 NOTICE: Saving skin settings
2019-12-19 03:12:35.402 T:4062125504 NOTICE: Stopping all
2019-12-19 03:12:35.408 T:4062125504 NOTICE: stop dvd detect media
2019-12-19 03:12:35.409 T:4062125504 NOTICE: Application stopped
2019-12-19 03:12:35.609 T:4062125504 NOTICE: unload skin
2019-12-19 03:12:35.610 T:4062125504 NOTICE: unload sections
But all is working fully, with TVH and live TV running again.
Ran various tests and I canāt find any issues, so all thumbs up from me.
Thanks Team.
will old SoC be affected when this goes to stable builds - S905x for example.
Or will this kernel change only be a -ng thing?
@prynn
Been answered before.
@kostaman
I saw that, thatās why I asked when stable release or even a future release.
I update.
my device x96max +905x3 (64 + 4) in coreelec, no lan
I have put a new rom on Android.
rom x96Max plus versión 2gb-100.
the result:.
android: wifi 2/5g ok and lan ko
coreelec :wifi ko and lan ok 1000/1000
Hi all, I recently discovered Coreelec after Libreelec on my old S905X box failed to convert HDR to SDR. Coreelec has solved that problem, but I was recently given a new ZMQC X96 Air S905X3 box (4GB/64GB) for my birthday and having updated to the nightly build yesterday Iām having a few issues and wondered if anyone else was seeing the same?
Firstly, audio passthrough doesnāt appear to be working, as half the time no audio goes to my receiver. When it does, itās only ever AAC in stereo mode, with DTS-HD/AC3 etc being completely silent. Secondly, HDR to SDR conversion isnāt working. Thirdly, video is very choppy, whereas itās fine running on the boxās stock media player. I noticed a few other people in the thread seem to have similar boxes, but couldnāt see that anyone else had these issues. All of these things are working perfectly on the older S905X box, but Iād love to be able to use the newer one as the performance is much better (and the WiFi on the old box is terrible).
Anyway, I primarily joined to offer my genuine thanks for all of your fantastic work on Coreelec. You guys are like wizards creating this stuff and itās really appreciated! I look forward to future updates, which Iām sure will resolve the issues Iām seeing. If I can provide any info to assist, please let me know
@anon88919003 today I make a normal upgrade process using latest nightly and the issue is fixed now. System is bootable. Thank you so much. Currently my BeeLink and CoreELEC is my primary TV client due to lack of DVB-T2 tuner on my TV.
Android TV install? And last ce 905x3 no problem wifi and ethernet? Great
Great job finding a solution so fast! Can you provide a link to the rom?
Yes .
ROM Android 9 Versión 2G y 100/100
https://mega.nz/#!v4JElCIa!Q3tlpBUIViORrtTC5m2sk8f9PrUJgQF7LTmwWrf-0WM
And
ROM original Android 9 Versión 4/32/64 1000 for security
https://mega.nz/#!y5QG3YCZ!6-EeMa9x6jNnqrro3g0foyANSRCVkJ0bGttZfGqLqX4
What remote and VFD conf do you use?
I installed the 20191218 nightly on my vim3 to check out the fan (loud but works). However the GUI is a weird color combo. This is a new install today - tried 20191217 nightly with same results yesterday. Color for live tv and hd/4k moves is correct only the GUI is wrong. Not seen this posted from any other vim3 users so it must be a problem with my system? Still using 9.2.1 - works great! Any ideas on my gui problem?
Another option is to edit the āconfig.iniā file directly on your sd card in Windows using notepad etc.
Thanks - did the edit with ssh as its more fun
Now it looks great and Iāve got a noisy fan to boot.
Hi, is this temperature normal without any activity in the box (x96 air 2/16) ?: CPU Speed āā1908 Mhz | CPU Temp 64 C
