I got at least 2 other Mecool K2 Pro (S905) with the same problem, after compile done from latest git.
I would assume on the last commits a lot of changes were done to unify s905 units, and etc … it looks like something hard changed.
I’ll try to compile from source again and check too … but I’m almost 99% sure it started to happen after this
Are you sure you have a dtb.img?
I’m asking because we had a multidtb inside the kernel.img but this was removed and only the additional dtb.img is read.
Tried to upgrade from a previous nightly (installed from scratch) and stable version, but does not show any unusual message (different from other installs), no error messages. It finish the upgrade, reboot and stuck in the amlogic logo bootloop.
Tried to install a self-compiled one too, same result.
On the installations from scratch I double checked I’m using the correct dtb. Using toothpick method makes it enter directly into the bootloop.
Now looking into making a serial cable to get those uart logs… At least I’m having fun
Can anyone tell me if you’re experiencing issues with Netflix? Beelink GT1 (S912). I can’t play videos from Netflix plugin (stream doesn’t start).
Looking at the plugins, all is good, except the inputsream.adaptive addon, which is still in version 2.3.6.0, when the latest from master (Git) is 2.3.11. Anyone knows why I can’t update inputstream.adaptive directly from CoreElec repos?
