CoreELEC-nightly we can not download the latest images.img 2019-01-28
.tar format files are ok
The newest version is 20190127.
I just successfully downloaded all img.gz and .tar files.
So, I’m not entirely sure how I could help you.
You could try to download it from the archive page here:
http://coreelec.pokey.de/?dir=20190127
Very strange here I can only file.tar
tried on another computer in another network it happens the same
is rotating the blue bar around the img file
@afl1 Avl dvb-t still broken in latest nightly. I saw that that there were a bunch of dvb updates so hoped this would be resolved. Is there anything more I can do to resolve this ?
I just checked the server logs, and the img.gz files were already downloaded several times today, so I don’t think it’s a server problem.
Did you try the other server I posted above?
This is a complete different server in another country and could probably solve your problem.
I just tried
It’s the same!
@erbas can you paste which link you are trying to download, thanks
It definitely downloads here, there must be a network or some other issue on your side sorry.
Good to know, my friend!
Because I’m using Vpn and did not solve it.
Detail and only with zip.img
zip.tar download is perfect.
Did you try a different browser?
Some browsers try to extract .gz files on the fly, which could lead to download problems.
Yes friend.
with safari, internet explorer, google chrome
With vpn, without vpn!
May be some block on windows 10
I am without linux at this time.
Very strange, maybe there is some app on your computer stopping the download, try on your phone or tablet.
I have just tried on a remote server to double check as well and that was fine.
AVL dvb-T still not working in 0128
@Shoog:
I know, you already reported this problem some weeks ago, and I completely understand your frustration.
Since this is not specifically a problem of the nightly builds, I would recommend moving this issue to an own thread.
The whole conversation between you and afl1 is burried somewhere in this thread and it’s hard to keep track of it, now.
I tried to find the initial problem report and gave up after scrolling up a few pages.
I think its important for the progress of this to be noted. I have no particular expectation and can always move back to 8.95.7 but would just hope that this was resolved before final release. At least one other person is having the same issue.
Are you saying, this tuner is working in 8.95.7?
I apoligies then, as it perfectly fits into this nightly thread.
But it’s still hard to follow, because of the many other posts here.
Yes it worked up until the nightlys at end of december
Okay, I’m sure, @afl1 will take another look at it.
ive the problem that since CoreELEC-S912.arm-9.0-nightly_20190124 my H96Pro+ S912 need double time to boot up! normal it need to 20190120 35sec. now over 60sec…
ive found some errors in log 02_System.log
if found out that this only appears when booting from internal emmc!
ive using errorfree internal flash since month…
build 20190120 -
[ 18.285329@0] hdmitx: system: PHY Setting Done
[ 18.285347@0] hdmitx: system: irq 80000001
[ 18.289348@0] Sink is HDMI device
[ 18.289361@0] hdmitx: system: packet: can't get vendor data
[ 18.289366@0] hdmitx: video: vinfo: 1080p50hz 50 1
[ 18.289374@0] hdmitx: video: vinfo recalc: 1080p50hz 50 1
[ 18.289381@0] hdmtix: set audio
[ 18.289393@0] hdmitx tx_aud_src = 0
[ 18.289425@0] hdmitx: fs = 2, cd = 4, tmds_clk = 148500
[ 18.289430@0] hdmitx aud_n_para = 6272
[ 18.289452@0] hdmitx set channel status
[ 18.289518@0] hdmitx: audio: Audio Type: PCM
[ 18.289528@0] hdmitx: video: VIC: 31 (31) 1920x1080p50hz
[ 18.289540@0] hdmitx: video: Bit depth: 8-bit, Colour range RGB: limited, YCC: limited, Colourspace: YUV444
[ 18.289548@0] hdmitx: video: Colorimetry: bt709
[ 18.289555@0] hdmitx: video: PLL clock: 0xc000027b, Vid clock div 0x000a339c
[ 18.289568@0] Start = 0x10000100 End = 0x100001ff
[ 18.289581@0] [0x10000104]: 0x00000001
[ 18.289778@0] [0x10000180]: 0x000000ff
[ 18.289784@0] [0x10000181]: 0x000000ff
[ 18.289790@0] [0x10000182]: 0x00000003
[ 18.289796@0] [0x10000183]: 0x00000007
[ 18.289802@0] [0x10000184]: 0x0000003f
[ 18.289808@0] [0x10000185]: 0x00000002
[ 18.289816@0] [0x10000187]: 0x000000ff
[ 18.289822@0] [0x10000188]: 0x00000003
[ 18.290017@0] fb: osd current vmode=1080p50hz, cmd: 0x10000
[ 18.306470@4] fb: osd[0] canvas.idx =0x40
[ 18.306472@4] fb: osd[0] canvas.addr=0xb9300000
[ 18.306474@4] fb: osd[0] canvas.width=7680
[ 18.306476@4] fb: osd[0] canvas.height=2160
[ 18.306478@4] fb: osd[0] frame.width=1920
[ 18.306480@4] fb: osd[0] frame.height=1080
[ 18.366636@4] fb: osd[0] canvas.idx =0x40
[ 18.366639@4] fb: osd[0] canvas.addr=0xb9300000
[ 18.366641@4] fb: osd[0] canvas.width=7680
[ 18.366643@4] fb: osd[0] canvas.height=3240
[ 18.366645@4] fb: osd[0] frame.width=1920
[ 18.366647@4] fb: osd[0] frame.height=1080
[ 21.357630@6] audio_dsp: buf=0
[ 21.357649@6] audio_dsp: IEC958_mode_raw=0
[ 21.357700@6] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[ 21.357705@6] audio_dsp: last mode 0,now 0
[ 21.370889@6] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1)
[ 21.370906@6] aml_spdif_dai: share the same clock
[ 21.370919@6] aml_audio_hw: IEC958 PCM32
[ 21.370927@6] hdmitx: audio: aout notify rate 44100
[ 21.370931@6] hdmitx: audio: aout notify size 32
[ 21.370937@6] hdmitx: audio: no update
[ 21.370950@6] aml_snd_m8_card aml_m8_snd.49: i2s/958 same source
[ 21.371367@6] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1)
[ 21.371381@6] aml_spdif_dai: share the same clock
[ 21.371394@6] aml_audio_hw: IEC958 PCM32
[ 21.371402@6] hdmitx: audio: aout notify rate 44100
[ 21.371407@6] hdmitx: audio: aout notify size 32
[ 21.371412@6] hdmitx: audio: no update
[ 21.371425@6] aml_snd_m8_card aml_m8_snd.49: i2s/958 same source
[ 21.371700@6] channel count should be 8, we got 2 aborting
… output of lsmod
LibreELEC release: S912.arm-nightly_20190120
Module Size Used by
hci_uart 30134 1
bluetooth 340354 2 hci_uart
since 201901024 -Log is from 201901029
[ 20.186789@1] Bluetooth: HCI device and connection manager initialized
[ 20.186825@1] Bluetooth: HCI socket layer initialized
[ 20.186836@1] Bluetooth: L2CAP socket layer initialized
[ 20.186874@1] Bluetooth: SCO socket layer initialized
[ 20.195249@1] Bluetooth: HCI UART driver ver 2.2
[ 20.195265@1] Bluetooth: HCI H4 protocol initialized
[ 20.195270@1] Bluetooth: HCI BCSP protocol initialized
[ 20.195275@1] Bluetooth: HCILL protocol initialized
[ 20.195279@1] Bluetooth: HCIATH3K protocol initialized
[ 20.195284@1] Bluetooth: HCI Three-wire UART (H5) protocol initialized
[ 24.086194@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 24.086210@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 24.086218@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 24.086242@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 24.086403@6] [aml_sd_emmc_data_thread] retry cmd 18 the 8-th time(s)
[ 24.086410@6] emmc, 8 retry, adj 6 -> 7
[ 24.086428@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 24.086458@6] aml_sd_emmc_data_thread : 2586
[ 28.181194@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 28.181210@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 28.181218@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 28.181242@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 28.181402@6] [aml_sd_emmc_data_thread] retry cmd 18 the 7-th time(s)
[ 28.181408@6] emmc, 7 retry, adj 7 -> 8
[ 28.181425@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 28.181456@6] aml_sd_emmc_data_thread : 2586
[ 32.276190@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 32.276200@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 32.276207@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 32.276232@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 32.276390@6] [aml_sd_emmc_data_thread] retry cmd 18 the 6-th time(s)
[ 32.276396@6] emmc, 6 retry, adj 8 -> 9
[ 32.276413@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 32.276443@6] aml_sd_emmc_data_thread : 2586
[ 36.371191@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 36.371202@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 36.371210@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 36.371235@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 36.371388@6] [aml_sd_emmc_data_thread] retry cmd 18 the 5-th time(s)
[ 36.371394@6] emmc, 5 retry, adj 9 -> 0
[ 36.371411@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 36.371433@6] aml_sd_emmc_data_thread : 2586
[ 40.466191@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 40.466201@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 40.466209@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 40.466233@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 40.466390@6] [aml_sd_emmc_data_thread] retry cmd 18 the 4-th time(s)
[ 40.466396@6] emmc, 4 retry, adj 0 -> 1
[ 40.466413@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 40.466442@6] aml_sd_emmc_data_thread : 2586
[ 44.561191@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 44.561202@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 44.561209@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 44.561233@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 44.561393@6] [aml_sd_emmc_data_thread] retry cmd 18 the 3-th time(s)
[ 44.561399@6] emmc, 3 retry, adj 1 -> 2
[ 44.561417@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 44.561445@6] aml_sd_emmc_data_thread : 2586
[ 48.656191@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 48.656203@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 48.656210@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 48.656238@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 48.656391@6] [aml_sd_emmc_data_thread] retry cmd 18 the 2-th time(s)
[ 48.656397@6] emmc, 2 retry, adj 2 -> 3
[ 48.656414@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 48.656444@6] aml_sd_emmc_data_thread : 2586
[ 52.751191@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 52.751203@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 52.751211@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 52.751239@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 52.751396@6] [aml_sd_emmc_data_thread] retry cmd 18 the 1-th time(s)
[ 52.751403@6] emmc, 1 retry, adj 3 -> 4
[ 52.751420@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 52.751445@6] aml_sd_emmc_data_thread : 2586
[ 56.846190@0] [aml_sd_emmc_irq] emmc: desc_timeout,vstat:0xe1ff1000,virqc:3fff
[ 56.846202@0] [aml_host_bus_fsm_show] emmc: err: wait for irq service, bus_fsm:0x8
[ 56.846209@0] [mmc_cmd_LBA_show] emmc: cmd 18, arg 0x14000, operation is in [reserved] disk!
[ 56.846236@6] aml_sd_emmc_data_thread 2639 emmc: cmd:18
[ 56.846390@6] [aml_sd_emmc_data_thread] Command retried failed line:2752, cmd:18
[ 56.846407@0] [aml_sd_emmc_irq] emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
[ 56.846433@6] aml_sd_emmc_data_thread : 2586
[ 56.846465@4] _dtb_read: save dtb error
[ 56.846465@2] mmc_dtb_read: read failed:-14
[ 57.360752@2] 8021q: 802.1Q VLAN Support v1.8
[ 60.386727@1] codec:vdec_create instance ffffff800483a000, total 1
[ 61.324028@7] libphy: stmmac-0:00 - Link is Up - 1000/Full
[ 61.324059@7] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 63.747678@1] audio_dsp: buf=0
[ 63.747695@1] audio_dsp: IEC958_mode_raw=0
[ 63.747728@1] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[ 63.747732@1] audio_dsp: last mode 0,now 0
[ 63.753209@1] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1)
[ 63.753274@1] aml_spdif_dai: share the same clock
[ 63.753284@1] aml_audio_hw: IEC958 PCM32
[ 63.753290@1] hdmitx: audio: aout notify rate 44100
[ 63.753294@1] hdmitx: audio: aout notify size 32
[ 63.753299@1] hdmitx: audio: aout notify format CT_PCM
[ 63.753304@1] hdmtix: set audio
[ 63.753318@1] hdmitx tx_aud_src = 0
[ 63.753346@1] hdmitx: fs = 2, cd = 4, tmds_clk = 148500
[ 63.753350@1] hdmitx aud_n_para = 6272
[ 63.753369@1] hdmitx set channel status
[ 63.753427@1] hdmitx: audio: Audio Type: PCM
[ 63.753430@1] hdmitx: audio: set audio param
[ 63.753441@1] aml_snd_m8_card aml_m8_snd.49: i2s/958 same source
[ 63.753924@1] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1)
[ 63.753932@1] aml_spdif_dai: share the same clock
[ 63.753941@1] aml_audio_hw: IEC958 PCM32
[ 63.753947@1] hdmitx: audio: aout notify rate 44100
[ 63.753951@1] hdmitx: audio: aout notify size 32
[ 63.753954@1] hdmitx: audio: no update
[ 63.753962@1] aml_snd_m8_card aml_m8_snd.49: i2s/958 same source
[ 63.754157@1] channel count should be 8, we got 2 aborting
[ 63.994215@0] hdmitx: set frac_rate_policy as 0
[ 63.994245@0] vout_serve: vmode set to 1080p50hz
[ 63.994272@0] hdmitx: video: vinfo: 1080p60hz 60 1
[ 63.994279@0] hdmitx: video: vinfo recalc: 1080p60hz 60 1
[ 63.994283@0] fb: osd current vmode=1080p60hz, cmd: 0x50000
[ 63.994292@0] tv_vout: tv_set_current_vmode[919]fps_target_mode=18
[ 63.994298@0] tv_vout: mode is 18,sync_duration_den=1,sync_duration_num=50
[ 63.994311@0] tv_vout: TV mode 1080p50hz selected.
[ 63.994318@0]
[ 63.994318@0] vdac_enable: on:0,module_sel:8
[ 63.994328@0]
[ 63.994328@0] vdac_enable: on:0,module_sel:8
[ 63.994337@0] tv_vout: new mode =1080p50hz set ok
[ 63.994341@0] vout_serve: vinfo mode is: 1080p50hz
[ 63.994344@0] vout_serve: new mode 1080p50hz set ok
[ 63.994361@0] hdmitx: video: auto - get current mode: 1080p50hz
[ 63.994366@0] hdmitx: stream colourdepth was 8 in para 0x01b46430 (1920x1080p60hz)
[ 63.994371@0] hdmitx: update rx hdr info 5
[ 63.994374@0] hdmitx: update physcial size: 1600 900
[ 63.994390@0] hdmitx: hdev->para now = para at 0x01b46330
[ 63.994395@0] hdmitx: Stream colourdepth is 8 in para 0x01b46330 (1920x1080p50hz - VIC: 31)
[ 63.994434@0] hdmitx: system: already init VIC = 0 Now VIC = 31
[ 63.994439@0] hdmitx: system: params found at 0x01b44310
[ 63.994442@0] hdmitx: system: cur_param = param at 0x01b44310 colourdepth 8
[ 63.994449@0] hdmitx: video: pixel freq 148500, tmds clock 148500, MaxClock1 300000, HF_IEEEOUI 0xc45dd8, MaxClock2 600000
[ 63.994454@0] hdmitx: rx has SCDC present indicator
[ 63.996468@0] hdmirx version is 2.0
[ 63.996472@0] hdmitx div40: 0
[ 64.023746@0] hdmitx: system: set pll
[ 64.023752@0] hdmitx: system: param->VIC:31
[ 64.023757@0] hdmitx: set clk: VIC = 31 cd = 4 frac_rate = 0
[ 64.023768@0] hdmitx: 1920x1080p50hz doesn't have frac_rate
[ 64.023774@0] config HPLL = 2970000
[ 64.023797@0] HPLL: 0xc000027b
[ 64.023800@0] config HPLL done
[ 64.023809@0] set_hpll_od3_clk_div[442] div = 6
[ 64.023817@0] j = 4 vid_clk_div = 1
[ 64.023828@0] hdmitx: set enc for VIC: 31
[ 64.023868@0] hdmitx_set_hw[4896] set VIC = 31
[ 64.023875@0] hdmitx: system: irq 80000001
[ 64.023933@0] Set rgb_ycc to 2
[ 64.024067@0] hdmitx: system: irq 80000001
[ 64.039895@0] Start = 0x10000100 End = 0x100001ff
[ 64.039906@0] [0x10000104]: 0x00000001
[ 64.040075@0] [0x10000180]: 0x000000ff
[ 64.040080@0] [0x10000181]: 0x000000ff
[ 64.040084@0] [0x10000182]: 0x00000003
[ 64.040089@0] [0x10000183]: 0x00000007
[ 64.040093@0] [0x10000184]: 0x0000003f
[ 64.040097@0] [0x10000185]: 0x00000002
[ 64.040103@0] [0x10000187]: 0x000000ff
[ 64.040108@0] [0x10000188]: 0x00000003
[ 64.155755@0] hdmitx: system: PHY Setting Done
[ 64.159779@0] Sink is HDMI device
[ 64.159792@0] hdmitx: system: packet: can't get vendor data
[ 64.159798@0] hdmitx: video: vinfo: 1080p50hz 50 1
[ 64.159805@0] hdmitx: video: vinfo recalc: 1080p50hz 50 1
[ 64.159811@0] hdmtix: set audio
[ 64.159823@0] hdmitx tx_aud_src = 0
[ 64.159854@0] hdmitx: fs = 2, cd = 4, tmds_clk = 148500
[ 64.159860@0] hdmitx aud_n_para = 6272
[ 64.159881@0] hdmitx set channel status
[ 64.159949@0] hdmitx: audio: Audio Type: PCM
[ 64.159959@0] hdmitx: video: VIC: 31 (31) 1920x1080p50hz
[ 64.159971@0] hdmitx: video: Bit depth: 8-bit, Colour range RGB: limited, YCC: limited, Colourspace: YUV444
[ 64.159980@0] hdmitx: video: Colorimetry: bt709
[ 64.159987@0] hdmitx: video: PLL clock: 0xc000027b, Vid clock div 0x000a339c
[ 64.159994@0] fb: osd current vmode=1080p50hz, cmd: 0x10000
[ 64.217198@7] fb: osd[0] canvas.idx =0x40
[ 64.217200@7] fb: osd[0] canvas.addr=0xb9300000
[ 64.217203@7] fb: osd[0] canvas.width=7680
[ 64.217205@7] fb: osd[0] canvas.height=3240
[ 64.217207@7] fb: osd[0] frame.width=1920
[ 64.217209@7] fb: osd[0] frame.height=1080
[ 64.622725@0] vout_serve: vmode set to null
[ 64.622763@0] vout_serve: disable HDMI PHY as soon as possible
[ 64.622770@0] hdmitx: video: vinfo: 1080p50hz 50 1
[ 64.622777@0] hdmitx: video: vinfo recalc: 1080p50hz 50 1
[ 64.622781@0] fb: osd current vmode=1080p50hz, cmd: 0x50000
[ 64.622789@0] tv_vout: tv_set_current_vmode[919]fps_target_mode=59
[ 64.622794@0] tv_vout: mode is 59,sync_duration_den=1,sync_duration_num=60
[ 64.622808@0] tv_vout: 3tvinfo 58 not find
[ 64.622811@0] tv_vout: new mode =null set ok
[ 64.622815@0] vout_serve: vinfo mode is: null
[ 64.622818@0] vout_serve: new mode null set ok
[ 64.622828@0] hdmitx: edid: not find mapped vic
[ 64.622836@0] hdmitx: video: auto - get current mode: null
[ 64.622841@0] hdmitx: stream colourdepth was 8 in para 0x01b46330 (1920x1080p50hz)
[ 64.622845@0] hdmitx: display colourdepth was 8 in cur_param 0x01b44310 (VIC: 31)
[ 64.622849@0] hdmitx: update physcial size: 1600 900
[ 64.622854@0] hdmitx: video: null not valid hdmi mode
[ 64.622882@0] fb: osd current vmode=null, cmd: 0x10000
[ 64.636909@0] hdmitx: set frac_rate_policy as 0
[ 64.636930@0] vout_serve: vmode set to 1080p50hz
[ 64.636945@0] vout_serve: disable HDMI PHY as soon as possible
[ 64.636950@0] hdmitx: video: vinfo: null 60 1
[ 64.636955@0] hdmitx: video: vinfo recalc: null 60 1
[ 64.636959@0] fb: osd current vmode=null, cmd: 0x50000
[ 64.636964@0] tv_vout: tv_set_current_vmode[919]fps_target_mode=18
[ 64.636968@0] tv_vout: mode is 18,sync_duration_den=1,sync_duration_num=50
[ 64.636979@0] tv_vout: TV mode 1080p50hz selected.
[ 64.636984@0]
[ 64.636984@0] vdac_enable: on:0,module_sel:8
[ 64.636994@0]
[ 64.636994@0] vdac_enable: on:0,module_sel:8
[ 64.637003@0] tv_vout: new mode =1080p50hz set ok
[ 64.637006@0] vout_serve: vinfo mode is: 1080p50hz
[ 64.637010@0] vout_serve: new mode 1080p50hz set ok
[ 64.637025@0] hdmitx: video: auto - get current mode: 1080p50hz
[ 64.637029@0] hdmitx: stream colourdepth was 8 in para 0x01b45050 (invalid)
[ 64.637032@0] hdmitx: display colourdepth was 8 in cur_param 0x01b44310 (VIC: 31)
[ 64.637036@0] hdmitx: update rx hdr info 5
[ 64.637039@0] hdmitx: update physcial size: 1600 900
[ 64.637052@0] hdmitx: hdev->para now = para at 0x01b46330
[ 64.637057@0] hdmitx: display colourdepth is 8 in cur_param 0x01b44310 (VIC: 31)
[ 64.637062@0] hdmitx: Stream colourdepth is 8 in para 0x01b46330 (1920x1080p50hz - VIC: 31)
[ 64.637100@0] hdmitx: system: already init VIC = 0 Now VIC = 31
[ 64.637105@0] hdmitx: system: params found at 0x01b44310
[ 64.637108@0] hdmitx: system: cur_param = param at 0x01b44310 colourdepth 8
[ 64.637116@0] hdmitx: video: pixel freq 148500, tmds clock 148500, MaxClock1 300000, HF_IEEEOUI 0xc45dd8, MaxClock2 600000
[ 64.637121@0] hdmitx: rx has SCDC present indicator
[ 64.639134@0] hdmirx version is 2.0
[ 64.639138@0] hdmitx div40: 0
[ 64.663756@1] hdmitx: system: set pll
[ 64.663761@1] hdmitx: system: param->VIC:31
[ 64.663766@1] hdmitx: set clk: VIC = 31 cd = 4 frac_rate = 0
[ 64.663773@1] hdmitx: 1920x1080p50hz doesn't have frac_rate
[ 64.663782@1] config HPLL = 2970000
[ 64.663805@1] HPLL: 0xc000027b
[ 64.663808@1] config HPLL done
[ 64.663818@1] set_hpll_od3_clk_div[442] div = 6
[ 64.663827@1] j = 4 vid_clk_div = 1
[ 64.663838@1] hdmitx: set enc for VIC: 31
[ 64.663862@1] hdmitx_set_hw[4896] set VIC = 31
[ 64.663920@1] Set rgb_ycc to 2
[ 64.664084@0] hdmitx: system: irq 80000001
[ 64.664108@0] Start = 0x10000100 End = 0x100001ff
[ 64.664121@0] [0x10000104]: 0x00000001
[ 64.664317@0] [0x10000180]: 0x000000ff
[ 64.664323@0] [0x10000181]: 0x000000ff
[ 64.664328@0] [0x10000182]: 0x00000003
[ 64.664334@0] [0x10000183]: 0x00000007
[ 64.664340@0] [0x10000184]: 0x0000003f
[ 64.664346@0] [0x10000185]: 0x00000002
[ 64.664354@0] [0x10000187]: 0x000000ff
[ 64.664360@0] [0x10000188]: 0x00000003
[ 64.795753@1] hdmitx: system: PHY Setting Done
[ 64.799770@1] Sink is HDMI device
[ 64.799782@1] hdmitx: system: packet: can't get vendor data
[ 64.799788@1] hdmitx: video: vinfo: 1080p50hz 50 1
[ 64.799795@1] hdmitx: video: vinfo recalc: 1080p50hz 50 1
[ 64.799802@1] hdmtix: set audio
[ 64.799814@1] hdmitx tx_aud_src = 0
[ 64.799846@1] hdmitx: fs = 2, cd = 4, tmds_clk = 148500
[ 64.799851@1] hdmitx aud_n_para = 6272
[ 64.799873@1] hdmitx set channel status
[ 64.799939@1] hdmitx: audio: Audio Type: PCM
[ 64.799948@1] hdmitx: video: VIC: 31 (31) 1920x1080p50hz
[ 64.799961@1] hdmitx: video: Bit depth: 8-bit, Colour range RGB: limited, YCC: limited, Colourspace: YUV444
[ 64.799969@1] hdmitx: video: Colorimetry: bt709
[ 64.799976@1] hdmitx: video: PLL clock: 0xc000027b, Vid clock div 0x000a339c
[ 64.799983@1] fb: osd current vmode=1080p50hz, cmd: 0x10000
[ 64.816887@6] fb: osd[0] canvas.idx =0x40
[ 64.816889@6] fb: osd[0] canvas.addr=0xb9300000
[ 64.816892@6] fb: osd[0] canvas.width=7680
[ 64.816893@6] fb: osd[0] canvas.height=2160
[ 64.816895@6] fb: osd[0] frame.width=1920
[ 64.816897@6] fb: osd[0] frame.height=1080
[ 64.877054@6] fb: osd[0] canvas.idx =0x40
[ 64.877057@6] fb: osd[0] canvas.addr=0xb9300000
[ 64.877059@6] fb: osd[0] canvas.width=7680
[ 64.877061@6] fb: osd[0] canvas.height=3240
[ 64.877063@6] fb: osd[0] frame.width=1920
[ 64.877064@6] fb: osd[0] frame.height=1080
[ 67.824200@5] audio_dsp: buf=0
[ 67.824220@5] audio_dsp: IEC958_mode_raw=0
[ 67.824278@5] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[ 67.824283@5] audio_dsp: last mode 0,now 0
[ 67.832609@5] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1)
[ 67.832633@5] aml_spdif_dai: share the same clock
[ 67.832647@5] aml_audio_hw: IEC958 PCM32
[ 67.832658@5] hdmitx: audio: aout notify rate 44100
[ 67.832663@5] hdmitx: audio: aout notify size 32
[ 67.832669@5] hdmitx: audio: no update
[ 67.832688@5] aml_snd_m8_card aml_m8_snd.49: i2s/958 same source
[ 67.833331@5] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100, runtime->channels=2, same source mode(1)
[ 67.833341@5] aml_spdif_dai: share the same clock
[ 67.833352@5] aml_audio_hw: IEC958 PCM32
[ 67.833361@5] hdmitx: audio: aout notify rate 44100
[ 67.833365@5] hdmitx: audio: aout notify size 32
[ 67.833369@5] hdmitx: audio: no update
[ 67.833384@5] aml_snd_m8_card aml_m8_snd.49: i2s/958 same source
[ 67.833600@5] channel count should be 8, we got 2 aborting
… output of lsmod
LibreELEC release: S912.arm-nightly_20190129
Module Size Used by
8021q 19039 0
hci_uart 30134 1
