We can’t help if you are all vague in your replies, you need to elaborate more.
Odroid C2, CoreELEC-S905.arm-9.0-nightly_20190203. I am trying to update CoreELEC-Amlogic.arm-9.0-nightly_20190213.tar (rebuilt): OK. After a reboot, the CoreELEC logo is permanently displayed on the TV screen, not Kodi. But i can log into odroid via ssh. How to run the Kodi, or what can be additionally viewed by SSH?
WP2 Kodi Log:https://paste.ubuntu.com/p/GpsKZwgHgS/
WP2 CoreElec( CoreELEC-Amlogic.arm-9.0-nightly_20190213.tar) Update Video youtube:https://youtu.be/8yYG2ID0PxM
Just as in the previous post, errors in the log are the same.
Log: 22:38:03.414 T:4093710352 ERROR: failed to initialize EGL display (EGL_BAD_ALLOC)
22:38:03.414 T:4093710352 FATAL: CApplication::Create: Unable to init windowing system
why no new CoreELEC-S912.arm-9.0-nightly the last days?
You do know… this is like a hobby and they make it in their own time… or just maby they have a live outside coreelec…
i read
Commits on Feb 13, 2019
projects/Amlogic: unify S905 and S912
what does it mean?
is the nightly file “CoreELEC-Amlogic.arm-9.0-nightly_20190214.tar” for both systems?
Yes, all boxes can be updated via one single file.
Yes big changes in CoreELEC recently ![]()
Greetings,
Wow, I was wondering, man.
Best regards…
the same,tried 0213 and 0214,kodi did not start. odroid c2
We could do with users testing our 9.0.0 release available here. These images are currently newer than the most recent nightly.
Unfortunatly I f*#c*ed up yesterday and pushed some opengl bump into the repo from a PR. please see Adams 9.0.0 release test files
Many thanks for your (and the whole team) wonderful work. I did an Odroid C2 update (CoreELEC-Amlogic.arm-9.0.0.tar 15-Feb-2019 12:21 file). Kodi works again! And the first thing I did was an actual backup:)
Greetings,
No problem, it works excellent.
Boxes: WeTek Play 2 and Mecool K1 Pro.
Best regards…
I’ve also rebuilt the nightlies with these fixes included (20190214a).
20190214 did not work for my akaso hm8; 20190214a WORKS now on akaso hm8 (s905x). thank you.
20190214 and 20190214a works on x92 (S912)
Greetings,
I found a bug in this build.
At Whitelist 720p / 50Hz, half the screen is shifting to the bottom. The top side is black
Best regards…
720p/50Hz looks good on my tv
could you share an part of file for test?
@ozkaradag could you provide a bit more detail, exactly which nightly build?
What TV/AVR?
Which Device?
Does it happen with all 720p/50Hz content or just certain video files?
Also can you run dispinfo while the problem is happening. It will collect all the relevant display debug info and pastebin it and provide you a short url you can post here to make accessing that info easy.
