Latest nightly working great on my C2. Very impressive that there is one update tar for all supported devices now!
What is the name of image of S905X?
*Generic.img.gz for your box installation
And now only one . tar for update any of box versions
@ozkaradag we confirm this and have a possible fix.
Hi, the above procedure (manual update through custom channel) didnāt work to update from 20190211 (s912 only) to 20190215 (unified s905/s912). I could see the updated version in the json (through web), but the āAvailable versionsā menu in kodi was empty.
Anyway, manual update through downloaded .tar fixed: now my s912 is updated to the last unified night build, and custom channel shows the available version.
Thanks.
Thanks for reporting.
Due to some show stoppers in some of the last nightlies I had to pull and rebuild them.
I assume, the values in the json file sometimes were simply wrong during this time.
It was more important to have issue-free images instead of a functional json file.
WetekPlay2 CoreELEC 9.0 live tv tests.Live TV channel Astra 19.2 travelXP 4K. Test İmaj CoreELEC-Amlogic.arm-9.0-nightly_20190215a
In the final version of CoreELEC 9.0 there is the same error.
Greetings,
Dear friend, the problem is solved.
Thank you so much.
Best regardsā¦
The source of the error was caused by the AVR video output.I changed 1080P24Hz to 1080P and it worked fine.
I canāt install the last builds after 20190206 on my C2. It will install but not loading kodi anymore. I can ssh in and after digging arround I find that symlinks not set correctā¦
How can I fix this? These symlinks are missing in newer builds after 20190206:
lrwxrwxrwx 1 root root 18 Feb 16 14:28 libEGL.so -> /var/lib/libEGL.so
lrwxrwxrwx 1 root root 18 Feb 16 14:28 libEGL.so.1 -> /usr/lib/libEGL.so
lrwxrwxrwx 1 root root 18 Feb 16 14:28 libEGL.so.1.0.0 -> /usr/lib/libEGL.so
lrwxrwxrwx 1 root root 24 Feb 16 14:28 libGLESv1_CM.so -> /var/lib/libGLESv1_CM.so
lrwxrwxrwx 1 root root 24 Feb 16 14:28 libGLESv1_CM.so.1 -> /usr/lib/libGLESv1_CM.so
lrwxrwxrwx 1 root root 24 Feb 16 14:28 libGLESv1_CM.so.1.0.1 -> /usr/lib/libGLESv1_CM.so
lrwxrwxrwx 1 root root 21 Feb 16 14:28 libGLESv2.so -> /var/lib/libGLESv2.so
lrwxrwxrwx 1 root root 21 Feb 16 14:28 libGLESv2.so.2 -> /usr/lib/libGLESv2.so
lrwxrwxrwx 1 root root 21 Feb 16 14:28 libGLESv2.so.2.0.0 -> /usr/lib/libGLESv2.so
lrwxrwxrwx 1 root root 21 Feb 16 14:28 libGLESv3.so -> /var/lib/libGLESv3.so
lrwxrwxrwx 1 root root 21 Feb 16 14:28 libGLESv3.so.3 -> /usr/lib/libGLESv3.so
lrwxrwxrwx 1 root root 21 Feb 16 14:28 libGLESv3.so.3.0.0 -> /usr/lib/libGLESv3.so
how can i build this for myself?
Getting that erros after unified image patchesā¦
ERROR: You need to specify a valid device for the Amlogic project
Valid devices for project: Amlogic
- Odroid_C2
PROJECT=Amlogic ARCH=arm make release
and this is the error i receiveā¦
jarek@tower:~/CoreElec$ PROJECT=Amlogic ARCH=arm make release
./scripts/image release
- Odroid_C2
Makefile:9: recipe for target 'release' failed
@pogo1975 you are not using the latest source code
@bgx what DTB are you using? This would be the only reason that I can see for your issue
The symlinks are setup depending on which GPU is available on your device and this is read from the dtb
Symlinks look fine. Can you ls -l /var/lib?
@anon88919003: I donāt use a special dtb just updated all the way with tar and the first installation from month with the c2.img.gz
@Ray: Shure, hereās the output:
CoreELEC:~ # ls -l /var/lib
total 0
drwxr-xr-x 2 root root 60 Jun 22 2018 dbus
lrwxrwxrwx 1 root root 63 Jun 22 2018 docker -> /storage/.kodi/userdata/addon_data/service.system.docker
/docker
drwxr-xr-x 14 root root 4060 Jun 22 2018 firmware
drwx------ 2 root root 40 Jun 22 2018 portables
drwx------ 2 root root 40 Jun 22 2018 private
drwx------ 2 root root 120 Feb 18 07:43 pulse
drwxr-xr-x 2 root root 120 Feb 18 07:43 samba
drwxr-xr-x 3 root root 60 Jun 22 2018 systemd
Well that explains it though. No mali symlinks there. This looks like a dtb issue. Can you just copy the odroidc2.dtb to /flash/dtb.img and reboot
Thatās what I also think. Will do so and report back. Thx
Where to get the c2.dtb ?
