It’s in /flash/device-trees
Have found it and now it’s working. Thank you for your help and keep up the great work.
@anon88919003 hmm this is last commit in sources
commit 9c132bad4712f6830a3368ef880c7b13a88b9c2c (HEAD -> coreelec-9.0, origin/coreelec-9.0)
Author: Ray 1458889+Raybuntu@users.noreply.github.com
Date: Mon Feb 18 11:27:04 2019 +0100
kodi: update to 18.1
still the same issue
Do you have a file ~/.libreelec/options?
No i do not
I suggest you do a clean clone and try again.
will do that, thanks
I reproduced your error. This is a local problem and I had it too. Git doesn’t remove folders:
rm projects/Amlogic/devices/ -rf
greet,
The latest software given daily is also incompatible with pvr live tv as well.
20190217
regards
Update your addons. I think relkai builds addons too
After update.I have a pvr 4.4.12.2 in the add-in store.
PVR API has been reverted to improve compatibility with 3rd party addons and to track Kodi changes.
Try to update the addon manually from the repo, it should work, even though the version is the same.
Thanks,I’ll try the manual.
Tvheadend HTSP client and other PVR plugins are not installing.Incompatible information appears on the screen.
Greetings,
Mate; it gives the same error. I mean, it’s not manual.
Best regards…
There is a dependency error when attempting to update the Tvheadend HTSP client manually.
Same here!
What’s the exact error?
The dependency on kodi.binary.instance.pvr version 5.10.4 could not be satisfied.
Last night many addons failed to build, including PVR addons. Thus they don’t work in this build, as it’s the exact build we changed PVR API back to match Kodi’s.
You’ll have to wait for tomorrow’s build.
