Well - did not work for me
Went back to nightly from 9.0 stable.
Since i did this, i can see the 9.02 nightly addon repo, but if i try to use it then i get the connection to repo can not be establisht error. In addons going to nightly addon repo all buttons are greyed out . Only update button can be used telling me that there is no update …
I deleted the CE repo as recommended.
Packages is empty. Reboot. CE repo has gone.
Still no access to CE nightly repo. Updated with latest tar nightly again. Connection to repo can not be established…
Json object error in var corebuild coreelec build.coreelec something
Can not post log atm
Writing from Smartphone
I think i should set up the device again from scratch
Yes but i couldn’t access because connection could not be established
Installed CE 9.01 tar file
Everything ok
Nightly repo disappeared and CE addon repo was there and could be accessed
Then i went back to nightly from feb 26th
CE addon repo has gone and CE nightly addon repo is there - so far ok.
But if i try to access System still tells me that connection to repo can not be established.
Hi @relkai, is the manual update still working? I’ve been using it for a while and my last nightly update was in February. I just checked Available Versions now and nothing comes up. I have not changed anything since the last update.
Due to the unified build you need to perform one manual update by downloading the tar file and putting it into the .update folder.
Afterwards the manual update using the custom channel should work again.
Thanks, did the manual build and when I go to updates now I do see the releases. One thing though, tvheadend client is not working now, I tried updating the repos and the tvheadend client but it says there are no updates. Is this new? It was working in previous nightlies but I understand if the teams need to catchup.
Thanks again, it is working. I grabbed pvr.hts-4.4.14.0.zip, it was newer than pvr.hts-4.4.14.1.zip. Not sure what the difference is, they both have the same change log file.
We have stopped making images for the kvim*, and the default remote config was replaced by a more popular one.
What boot2k3 suggested above should solve the issue.
Hi Guys,
Firstly congrats on some really good software. I’ve always been on Libreelec on a Rpi3b and used the nightlies over there but have recently purchased a Le Potato board and have come across to Coreelec. Just a question, are the “nightlies” released here only every few weeks? All good if thats the case, just looking to give them a crack.
