They are built every night but only if there is changes in the git repository.
Any idea what happened to tonightâs build? File dates are 3/29 and release notes are 3/27, though I saw 4/3 building for a while
Thanks for the hint.
I didnât realize, there was a problem.
I will take a look at it later today.
I found it odd also, but considered that you guys were taking a break (well deserved one!)
We are mostly working on 4.9 kernel and Odroid N2 lately.
We are into a stable final release so it would be surprising if there were many nightly releases at this stage. Everything is working well on the stable release.
The problem is fixed and the latest nightly 20190404 is ready to be downloaded.
Hi.
Since I was stuck at 20190329, I downloaded CoreELEC-Amlogic.arm-9.0-nightly_20190404.tar.
After successful update, checking updates (on coreelec) still shows 20190329 available.
Bye.
same hereâŚ
@felixwolf @pepeq
Should be fixed, now.
After manually fixing the failed build I forgot to refresh the releases.json.
thanks, it works now.
On the latest nightly I am having issues playing back x.265 sd content.It will start black, after ~10s the video will refresh and freeze. Is anyone else seeing the same behavior?
Device is an S905x A95X 2g/16g.
Ping @Portisch. It might be related to recent changes
@wizardknight Just tested it with the last nightly - playing fine. Seeking is also working. With or without hyperion. But I have a S912 and no S905X
@Portisch, @wizardknight:
I can confirm the misbehaviour on nightly 20190404, which @wizardknight described.
Same on my S905X Beelink Mini MXIII II (S905X/2GB, 32GB SD-card).
Sample starts with a black picture, after 10sec picture is displayed, but freezed, sound is playing
I remuxed the sample with mkvtoolnix, but no change.
@pepeq @wizardknight please try also with version 20190329 from the archive folder.
@pepeq
I tried 20190329, and the behavior is the same.
The video does not play back correctly.
I am also seeing this behavior in the stable 9.0.1 release.
@Ray I donât think it depends on the hyperion changes as it also happens at 9.0.1.
I donât own a S905X device for testing.
Good then.
In CoreELEC settings, make sure that HEVC workaround is turned on.
