Thanks for the info, and thanks for the support.
where is ng nightly something about aml at bottom of page for nightly builds but dont see an ng build in list
Two posts up.
where cant find ng nightly
i loaded other nightly gt king and stays and beelink screen forever do u know how to fix and where ng generic builds are i cant find them
got it back up and running thx
Hi! Since the last 3 or 4 nightlies, I am experiencing slowdowns in liveTV, and it persist till a reboot, then it work ok again.
Don’t know if is anything related with hyperion again.
The box is a 905x without any changes since months.
What can I do to help you find the problem?
We have not changed anything for 3.14 kernel builds in the past week or two.
[[SOLVED] by autostart.sh…
I Changed Repeat delay to 150 ms .
But it will change back to 500ms after I reboot the box.
How can I keep repeat delay is 150ms?
Thank you.
CoreELEC:~ # ir-keytable -D 150 -P 100
Repeat delay = 150 ms, repeat period = 100 ms
Changed Repeat delay to 150 ms and repeat period to 100 ms
CoreELEC:~ # reboot
CoreELEC (official): nightly_20190831 (Amlogic-ng.arm)
Repeat delay = 500 ms, repeat period = 125 ms
You also need to type it into autostart.sh.
Can you please add realtek 8811cu drivers on ng build plz. It was working on stable non ng build. Thank you!
8811cu driver is already in ng builds. I only tested it with non ng builds though.
Tested again just right now, working on non ng stable 9.0.3 but not on last ng nightly. RTL8811CU
It’s possible that this driver is not functional with kernel 4.9. I have no way to test the ng build, my only Amlogic device is Le Potato board.
I’ll upload dmesg as soon i’ve access to my device (x96max 2g/16g)
Can you test this build? I built it with another version of the driver.
Hello, am I alone unable to play the AAC 5.1 ?
No need to read, just listen.
What exactly is the problem? Sample, log?
