Nightly builds
Hmmm…only kernel bumps, display fixes and hyperion-ng related things.
Nothing, which should affect subtitles at all.
I’m on the same nightly version (20181026) and BBC World News plays without any subtitles in my setup.
Did you enable “only forced” subtitles in “Settings > Player > Language” and disabled “search for closed captions”?
That setting is disabled.Its effecting BBC One and Two at least.
I don’t have these channels and can’t test it. Maybe someone else can confirm this issue?
Is it all the time? I’ve checked out BBC One and Two (East Anglia) this morning and I’m not seeing any subtitles.
It started last night at Doctor Who, but followed us to BBC2. Got to dig deeper and see if there is an overall partner, or possible the subtitles settings got corrupted in the upgrade.
Good to hear its not general.
Reboot seems to have cleared it, so just an unaccountable glitch then.
Good to hear it wasn’t a general problem.
Hi Guys and Gals,
looking at our stats we have quiet a lot of nightly users.
That’s really nice, and we are happy you like to test the newest developments in CoreELEC.
But the devs need a lot more feedback to squeeze all bugs out of future stable releases.
That’s one of the main reasons, why the nightlies are being distributed.
Could you please report any issues with the nightlies as soon as you are seeing them?
We need as much detail as possible including debug logs and steps on how to reproduce it.
This will help us a lot and would be much appreciated.
Thanks a lot for your support!
I use a nightly about one per week. But I have no issue, and no report… :wink:
box a95x
rom: CoreELEC-S905.arm-9.0-nightly_20181103
tv resolution: 1080p 50hz
starting from this build when using pvr simple client the frame rate changes to 25hz when openning a channel and that make the channels very slow to open (blackscreen for about 5 a 10 seconds and sometimes freezes complete)
before this builds the channels always was playing at 50hz
Take a look at your whitelist settings in “Settings > System > Display” (the topmost option).
Remove all low resolutions (<720p), all refresh rates with 25 and 30 Hz and all resolutions >3840x2160p.
The whitelist setting is one of the most annoying features introduced with Kodi Leia.
This will change in Beta 5. If nothing is configured, the behavior of Krypton is being restored.
I have an A95 (S905) on nightly_20181101. I noticed that while it will power off via the remote, but it will not turn on via the remote. Is this expected behavior?
Do you use the right dtb for your device?
Do you use the original remote or a third party one?
I have Odroid C2, and I can also just turn off the board using the IR remote control, but I can’t turn it on. But at the same time, I can turn on the board using the CEC command from the TV. It’s on any builds CoreElec
Do you use the original remote? Did it work before? Until which version did it work?
I use remote MINIX NEO A2 Light (https://kodi.wiki/view/MINIX_A2). Key power is IR, works without USB receiver. I tested ON/OFF somewhere since October, the result is the same. Not tested before
That won’t work and you need the original remote from Hardkernel or a Harmony remote to power on the device (or the CEC solution you are already using).
The power on command is vendor specific and another remote than the original one will most probably fail.
Take a look at this thread in the Odroid forums:
https://forum.odroid.com/viewtopic.php?f=144&t=22931&start=50
EDIT:
I asked the team about this, and you could modify and compile your uboot to change the C2’s power on command to NEC IR, which the Minix remote uses.
But this isn’t something the CoreELEC team can do for you.
I have tried all of the gb200 dtb files provided in the image in an attempt to rule that out.
All have the same behavior. I am unable to power the unit on via the remote once powered off.
I am using the stock/original remote.
If I am booted into the internal android rom, I have no issues shutting completely down and powering back on with the remote.
Android could also be using suspend. I have an C2 original remote. I will test this.
Odroid C2, nightly_20181106. TvH HTSP Client disable - is not compatible with this version of Kodi
