Taki this Wetek Play modul has 2 tuner but only one demod AVL6211. Second demod is onboard. That means only single tuner can be used with Odroid N2. Only issue is modul pinout. I order one to fix this as this is cheap option for dvb-s.
Not only cheaper, internal tuner are fully hw supported with minimal load to cpu.
mine was a mere recommendation. basis for this wetek tuner. but there is a different option as well as the SI2166D tuner that supports the dvb s2x. but no source code.SILC-S-A0001398498-1.pdf (58.4 KB)
https://m.globalsources.com/si/AS/HongKong-Haifei/6008833974143/pdtl/Tuner/1159228058.htm
80€ is ok for a FBC Tuner… but can these cards work with S922X? I think not…
ist aber auch nur ein dual tuner und die Frage ist ob man den eingebunden bekommt
but its only a dual tuner also, the question is if it works with the S922x chipset also
This tuner looks interesting.
We must know if it will have afl1 support.
And if it will be 100% functional.
Mut@nt HD51 DVB-S2X MultiStream Tuner uses Si2166 demod and RafaelMicro RT720 tuner. For SiliconLabs demod is avilable Si2183 driver as a superset of Si2166 from the same demod family and may be it’s compatible. But for tuner RT720 there is no source code.
I found RT710/720
http://www.codeforge.com/read/318326/RT710.c__html
rt710 driver
rt710.h.txt (1.2 KB)
rt710.c.txt (8.7 KB)
here is github
https://github.com/xuzemin/mstar/tree/master/Chakra3_017a0d6_20170731/device/tuner
// RT710.c
//Copyright 2012 by Rafaelmicro., Inc.
// C H A N G E R E C O R D
// Date Author Version Description
//03/06/2012 Ryan v2.1
//04/08/2013 Ryan v2.2 add rfgain Function
//07/25/2013 Ryan v2.3 vga agc slop from negative to positive
//01/15/2014 Ryan v2.4 modify setting Frequency from 1650~2000
//02/25/2014 Ryan v2.5 add Vga Attenuator Function
//03/11/2014 Ryan v2.6 modify rssi calculate
//01/06/2015 Ryan v2.7 Initialization value write-once
//01/29/2015 Ryan v3.0 add 720 setting
//01/29/2015 Ryan v3.1 add scan mode for RT720 (RT710 not support)
//02/17/2015 Ryan v3.2 Change the pll execution time
//02/12/2015 Ryan v3.2a Standby function add clock parameter
//03/30/2015 Ryan v3.3 Add RT720 filter table (with different RT710)
//04/07/2015 Ryan v3.3a optimize PLL Setting
//04/07/2015 Ryan v3.4C Add Xtal Cap Option only for R720 chip
//10/30/2015 Vincent v3.5 modify IF Fillter bandwidth
//03/21/2016 Vincent v3.6 Modify vth vtl parameter range
is these USB tuners (PLEX PX-W3U4/Q3U4/W3PE4/Q3PE4) work with N2?
that is no usb tuner. we dont talk usb tuner in here. we talk about hw demuxer for new nim dvb-s2x tuner. for open source tuner DVB-S2x. all usb tuner must be works on N2.
Product Details
Model Number: FTS-3166H/FTS-3166V-#9147
Brand Name: Serit
Origin: China (mainland)
Key Specifications/Special Features:
Chipset solution: SI2166D+RDA5815M
Remark: 16/32 APSK, DVB-S2X
RDA5815M driver
N2 + VTV board work fine for me.
I have no luck N2 with Wetek tuner. I know a little bit circuit. My N2 is smoked and burned at Q1. then usb no power no wifi no port on ethernet.
I am really sorry. it is necessary to be very careful when combining
In fact, the connection volts are required for 1.2 volts. ams1117 has 3 leg and voltage can pick up where it can give no electronic knowledge. I think you lost 5v on board. it can be repair. Look your board and find which burned
You probably burn out NB679GD small SMD chip - 5V voltage regulator. As a workaround you can use 5V source from VTV board (group of 6 pogo pins) and connect it to pin 2 of Expansion Connector. But at first measure resitance for possible shortcut on pin 2…
There is another elegant alternative. These are SAT> IP tuners (search on amazon.de):
Telestar Digibit R1: 4 DVB-S2 tuners (Unicable support)
Telestar Digibit Twin: 2 DVB-S2 tuners (without Unicable support)
Note: These tuners do not have support for satellite antenna motor. They work very well with tvheadend server on any board or PC.
This devices dint connect amlogic transponder stream hw demuxer. We can talk hw tuner. But cheap method for network streamin. Buy https://m.tr.aliexpress.com/item/32966599268.html?pid=808_0011_0201&spm=a2g0n.search-amp.list.32966599268&aff_trace_key=11ce29e494274d7d99303bd58d959125-1557952585440-08721-UneMJZVf&aff_platform=msite&m_page_id=3269amp-8g46SdvWDoHIGYgOAlOx8A1558482635449
38-41 usd. Work tvheadend with alexelec.
Mecool M8S DVB is’nt recommended device for CE. There is no linux driver for WiFi.
