When I put my N2 into Suspend all the lights go out but I cannot wake it up via IR, WOL or SSH. Only a power recycle works.
Used to be OK thou.
Used to be OK thou.
Maybe the red LED turns ON after X mins I’m not 100% sure, but the issue you now also have is the same as mine, if you need a working bluetooth and turn ON 5/30 still working great until this is fixed.
Can you still download the older nighties? Do you happen to have a link?
Many thanks.
Same problem here with the N2 not coming back from sleep(happens on both 20190620 and 20190623). Was fine on 20190613
My N2 and SD Card are ready
I should download from https://relkai.coreelec.org:
https://relkai.coreelec.org/CoreELEC-Amlogic-ng.arm-9.0-nightly_20190624-Odroid_N2.img.gz
Is it ok?
I feel that the automatic update does not work anymore. Is it possible ?
It has turned off until the suspend/resume issue resolved.
Yes it is.
I’m already very fond of my N2 and of CoreELEC. I’ve been updating regularly and have noticed this issue from the outset. It is not a problem on either the RockPro or Raspberry.
I attach 2 usb drives to the N2. They’re HFS+ non-journaled. At the first mount they are fine and mount rw. I’m not quite sure when it happens but it happens consistently, I THINK it is after a reboot, but the drives are suddenly mounted as ro and report a file system lock. I detach the drives and bring them to my Mac and run first aid on them. No errors or problems reported. When I return the drives to the N2 we begin the process all over again.
This solved my Bluetooth harmony remote issues. My N2 is now in production as the daily go too.
Same here. Last known good for me was 0619.
This is a known issue, and it’s likely that the problem was found/solved.
I am really like CoreELEC on N2. Currenty I am using SD card. But out of curiosity I have ordered emmc, which will be delivered tommorow. Looking forward for even more snappy UI from running off the emmc card.
Thanks for your great work
You will never disappoint to use eMMC instead of SD, it’s more fast and reliable.
Hi, how do you rate flirc?
Is it better than build in IR?
…in my oppinion flirc is not necessary. The internal IR receiver makes the same job.
Portisch, I’m still trying to resolve lingering CEC issues. Can you tell me what this version does differently than the rest please?
https://test.coreelec.org/arthur/CoreELEC-Amlogic-ng.arm-9.0-devel-1560018436.tar
This was a test build with a lower libCEC version for Panasonic TVs. But it didn’t solve the problems. The issue got resolved by setting active source: Odroid N2 test builds
