Works perfectly on my Denon AVRX7200WA with N2 nightly.
It initially happened to me too whenever I tried to play 4K movies which the N2 had to downscale due to the fact that my TV is FullHD, and hardware acceleration was disabled because I was trying stuff around.
With 1080p files however it always correctly passed Atmos signal, both with hardware acceleration on and off.
For this reason Iâd suggest you try with a 1080p file and see what happens.
I donât know why, however now my N2 passes the Atmos track also from 4K files (still being downscaled).
Iâm keeping hardware acceleration enabled, but iirc it did work properly even with it turned off so you really only have to try and wait for someone who can have a more technical explanation other than my empirical experienceâŚ
Just checked my receiver is compatible with 4k60p 4:4:4 so donât get what the problem could be
Install the nightly and follow instructions given to you previously by @Pelican.
Iâm going to just stuck at work chewing it over nearly didnât sleep as wanted to figure out the problem haha
Today I updated to the latest nightly and something is wrong with my ir device I guess. The remote wasnât working anymore and I did a quick check what was going on:
$ systemctl stop kodi
$ systemctl stop eventlircd
$ ir-keytable -u
No devices found
I did update to the stable branch with the same outcome. Any hints what might have happened?
remove âremote.disableâ in â/storage/.configâ or if not found, place a âdummyâ remote.conf by the command âtouchâ in this folder and reboot to enable the IR receiver.
I donât have the remote.disable file and created a dummy remote.conf:
$ ls .config/rem*
.config/remote.conf
After rebooting I still get the same behaviour. Did something change regarding the remote on the latest nightly?
You created this issue yourself by creating the dummy file, if any remote.conf exists then meson-ir is disabled.
Also when I donât have the remote.conf I get the No devices found.
Maybe this is helping: http://ix.io/1Rnq ?
Your trying to use a Minix remote with your N2?
Yes, it was working until yesterday evening. Today I booted the N2 and it wasnât responding to the remote.
Very strange, everything looks okay to me, I have a Minix remote so I will try it later.
So waking up still works - just tested it. I was afraid that it might be a hardware fault.
Surely because you have no ceiling speakers connected. Therefore, no need for the Atmos, only the TrueHD is active.
If you want to test, activate the channels in the settings of the amp.
yes, I was mixing up the remote decoders, remove all âremote.*â from the config folder should enable the meson-ir and irkeytable.
Thanks guys for all the support, changing either setting letâs 4K hdr work so Iâve put it in 4:4:2 and allâs good
@mrwsl itâs a problem with the most recent nightly, it will be fixed with tomorrowâs nightly due in ~8hrs.
Something is wrong with remotes in nightly 20190811.
Some keys on my remote do no longer work, but some work.
And ir-keytable does no longer work.
With nightly 20190809 it was ok:
CoreELEC (official): nightly_20190809 (Amlogic-ng.arm) N2-KODI:~ # ir-keytable Found /sys/class/rc/rc0/ (/dev/input/event1) with: Driver: meson-ir, table: rc-empty lirc device: /dev/lirc0 Supported protocols: unknown other lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp cec irmp Enabled protocols: lirc nec Name: meson-ir bus: 25, vendor/product: 0000:0000, version: 0x0000 Repeat delay = 375 ms, repeat period = 100 ms
With nightly 20190811:
CoreELEC (official): nightly_20190811 (Amlogic-ng.arm) N2-KODI:~ # ir-keytable No devices found
In .config there is no file remote*
Output from remoteinfo: http://ix.io/1RpU
My CEC remote has also a strange behaviour in latest nightly.
if i press âokâ it goes one up and enter very annoying
