Will do tomorrow, thanks.
I will introduce bypass_prog again. It should automatically bypass. Currently progressive is only bypassed if the resolution is bigger than 1080p.
@djnice Does bypass_post work for you too?
bypass_prog is permission denied, I will try bypass_post
I tried bypass_post, but the image is flickers and even worse quality.
thanks. bypass_prog is not implemented but will do soon
@djnice in current nighlty there should also be bypass_pre. Can you try that too please
I’m tried, but no improvements about chroma upsampling.
Just got a bit more to add on the H264 live Tv issue and nightlies updating. I’ve run on the latest nightly today with bypass_all and, in the lazy day I’m having, have watched two news programs and there’s not been a single freeeze/slowdown. I can also watch BBC streams on iplayer, unlike when I was running with bypass_post.
As to nightlies updating, they haven’t for me and I’ve been on nightlies for several days and there hasn’t been anything in .update when I’ve gone there to add the tar file manually. It would be great if it could be automatic but it’s not a must have for me.
Congrats on the brilliant job you’re doing by the way.
Let me ask around about nightly auto update.
bypass_post seems bot suitable. Bypassing deinterlace on interlaced content seems like a bad idea too but it’s good as a workaround probably.
Does not seem to update on my N2. Still on 9.0-nightly_20190429.
So i SSHd into the device during playback of “Venom” at 4k.
All i see is “No Signal”
This only occurs with auto resolution switching on
Here is the info:
Thanks Ray!
EDIT: ** tested : systemctl stop kodi / systemctl start kodi via SSH. Did nothing… I have to unplug the device to get back to kodi home page.
Is that a Vizio TV?
What file were you trying to play? Which HDMI port is the N2 connected to?
The 2015 M series didn’t have HDMI 2.0, so it was limited to 4K@30P (8 bit) for all inputs, except HDMI 5 would allow you to get 4K@60P@420 chroma (8 bit).
Looks like CE is sending a 10-bit signal, so that will unlikely to work over a HDMI 1.4 port.
@cdu13a
I’m having the same issue as @PViriX
I do have the Vizio M series from 2015,
I have it connected to my HDMI 5 port which is supposed to be 4k@60p and am still getting the no signal issue. I am also noticing a stutter and sound issue on 1080p, is this due to the HDMI 1.4 as well?
Is there any other fix for this? LibreElec at the current Kodi version on my Odroid C2 works fine.
EDIT: TV model https://support.vizio.com/s/article/M55-C2-Model-Information?language=en_US
We are looking into it.
Im using the 2015 vizio, and hdmi port 5!
I also have a Vizio M series from 2015 hooked up to port 5. I had to whitelist 3840 @ 60hz, 59hz 1080 @ 60,59,24,23 and 720p @ 60hz. 480p does weird scaling where it only fills up a portion of the screen (also when you try to adjust it the TV won’t let you, and in kodi there seems to be a bug where the IR remote is really unresponsive during the adjust pixel corners/subtitle location/make box square in 480p only).
If you whitelist those resolutions the 4k stuff will go through.
