Re my post immediately before this. The CNN streams for me are now working. I don’t know why but I think it’s because my cinema amp has detected a dolby marker in the audio. All I can say is that the sound came on when I selected dolby movie and has stayed on irrespective of what I’ve set since. I’m baffled to be honest.
My personal stuff recorded from my phone still won’t play with sound though.
After one day setting up the N2 as new daily driver i can say its working really smooth and stable!
Next step would be comskip and LiveTV transcoding (if possible via hardware).
Does somebody know if there is a working comskip for N2? Does TVH support transcoding via hardware on the N2?
Would it be possible to update the first post to reflect the known issues there, and also collect a “things you may need to adjust” list somewhere? Apparently LPCM multichannel audio output (i.e. anything encoded in aac, opus, ogg etc.) is not working properly which is something I use extensively.
Forget the test builds linked in the OP, we are now onto nightly builds, see link below, make sure you download the ‘ng’ image. https://relkai.coreelec.org/
transcoding is via cpu for me, i am using TVH server in a docker container, as long as the kodi addon version has ffmpeg transcode support then this should work, but afaik there is no gpu transcoding going on.
Not sure when it was fixed as I hadn’t tried IR in a while, but IR now very good alongside Crazycat and my DVB-T2 dongle. DVB-T2 playback also flawless so far.
Hi, maybe a stupid question. But i have a emmc now with OE on and works charm. But if i put a SD card in with e.g. Emustation and make the boot select switch to left it boots inti PetitBoot … am i missing something?! Thought i could switch with this Switch between boot from emmc or SD?!
I also would like to chosse between emmc and SD or USB to boot.
In Odroid forum they managed to boot from USB instead of SD when partitions and (modified) boot.ini is present on SD. https://forum.odroid.com/viewtopic.php?f=176&t=34361#p254726
So my conclusion was to put a emmc, sd and bootable usb stick into odroid and i can switch between emmc and usb to boot from. is this not possible atm?
