Odroid N2 test builds
Wired Ethernet, no other hardware, or additions outside the Aeon Nox:SiLVO skin, but happens on default skin as well, but not as intensely.
I have a generic Bluetooth adapter, other devices connect and work with no issues on the N2. When I plug the adapter into my Windows 10 PC, the PS4 controller connects perfectly with no issues. I also havae a Steam Link that it connect perfectly to. Every time I connect the controller on my N2, either by pressing the PS button on the controller, or selecting connect through the CoreELEC menu, the system freezes for a few seconds, then reboots. But the light on the controller does go solid blue for a second before the reboot, but when the system comes back up, it’s no longer connected. Here are the last entries from the debug log.
Pastebin debug log
https://pastebin.com/NBf5bzM7
Running nightly 0601. After watching Disney XD (1080i60 mpeg2) for a while, the audio and video get out of sync (usually after commercial breaks). Previously it would start stuttering, so definitely an improvement. I think the last changes for the issue were from 5/21 and 5/22.
@zaphod24, If it possible please make a record(of channel, not how it looks) with commercial break where you see the issue and share
How do I use it?
I am experiencing a very unusual, annoying and unfixable problem with one of my N2’s.
  • When in SPI mode … device is powered on, blue led flashing and everything seems to work OK.
  • When in emmc/ySD mode and using a freshly written image (devel-version) of CE all is going well: power on, blue led flashing, coreelec starting.
  • When I update to one of the recent nightlies (or knightlies :wink: ) Power on (red LED on) no blue LED flashing, no Corelec booting, just nothing …
Has anyone experienced something like this and is able to “help” me?
Thanks in advance!
@count.zero In two latest nightly versions try to unplug power and connect it again or use early knightly :wink: version … Will be fixed on next week
Or use power off and start it again instead of reboot
Yeah I’m hunting this bug.
Thanks! u r right, it seems to be the version.
Is there a knights archive anywhere? My last downloaded img.gz is from the 10th of May (which is working currently).
The power unplug/power/off/on … did nothing; not even scratch my knights-armor :slight_smile:
Here is the UART Log from the boot error with the new nightly
cecerrornobootnightly.txt (20.4 KB)
Complete (including N2) nightly archive: http://coreelec.pokey.de/
@Sholander: gracias!!
I think this is a serious issue with the new uboot. Are you using 2G N2?
Yes, i’m using the 2G N2 Version.
@count.zero, are you also have 2GB N2?
yes, I have got the 2GB version!
Knowing that @Mister-XY tested my 177 kernel without issues before this is most likely the new uboot from Hardkernel. I will revert it.
I think, it’s the same look like this build CoreELEC-Amlogic-ng.arm-9.0-devel-1559374119.
Build CoreELEC-Amlogic-ng.arm-9.0-devel-1559304361 runs good, but the new nightly and the 1559374119 build habe the same error.
4G version here. Everything working as expected.
also have the 4GB version, currently on nightly 20190601 but had problem installing 20190531 got a blank screen on boot and blue led went out and only red light on, unplugged power and re-connected and was able to get it to boot, but had the same problem after updating to 20190601.
@Ray build 1559136451 has been the best build so far for my use.
