Just tested it. Full OC and the famous cormorant scene went with only 7 skips for me. Really good !
Thanks Ray !
Itās a Team effort + lots of help from Hardkernel developers. OC issue was fixed by HK developer Joy.
Yes youāre right. Thanks all the CE & HK teams !
As serious as subject demands
There are some media players, AVRs, BD players that benefit from doing a unplug for 15sec and plug back in and a restart. Would you recommend that be done with the N2? I know a itās a pitaābut it may save some troubleshooting time, etc
Still have audio pops when nothing is playing through Onkyo receiver. My Vizio 4k tv will not autoswitch, and I get a blank screen. Latest nightly, logs attached.01_KODI.log (61.5 KB) 04_Audio.log (7.4 KB)
I did not have the audio popping in previous nightly releases, so not sure what changed.
I got the audio poping too, I set gui 3840x2160, when the poping happened ,chang the resolution to 1920x1080, the poping disappears. I donāt know if it related.
Could you try to disable kodi GUI sound?
Settings->System->Play GUI sounds
@ozolli, about next song issusā¦
Did you try to rescan audio library?
Also if possible could you try a clean install on different sdcard to check if this issue still present or not with clean system?
Yes I tried a rescan and cleaning too.
I will do a clean install on the C2 first which has the same issue.
@boot2k3 GUI sounds off already (first thing I do).
Also, not sure if somehow related, but I have had the IP address change on my device after a reboot and the update to the latest nightly. Prior to these recent updates, it had never changed.
ā¦no change of the IP address here!
This is most likely an arbitrariness of the DHCP server of your router and has nothing to do with the last (k)nightly.
Running 6/5 build, still have odd sync issues with this sample:
Between build 5/29 and 6/3 bluetooth wonāt auto connect to my Harmony Hub after reboot, I have to go in CE bluetooth settings and choose connect to get a working remote they are still paired with a star icon, I just updated to 6/5 where the issue is the same.
Same here, 3 new IPās on 3 reboots within 1 hour, not the normal beh. of my Router. Lease Time is 24 hours. Going to fixed IP for my N2.
Do to ssh is off by default is was lucky to got a working HDMI CEC IR from my TV. If you dontāt have CEC running an no out of the boy IR in the crapbox a novice user is a litle bit screwed. How shold i map my IR codes with no sshā¦just my 2 centāsā¦
Please check your MAC address after each reboot. There was a change about this. When the DHCP server does see another MAC it will assign a new IP.
USB keyboard?
yes, we all have oneā¦
shhh notebook usersā¦
Is your receiver connected via HDMI?
Could you make a screenshot of Settings->System->Audio? (all settings thereā¦)
Also did you followed Kodi recommended settings guide for your current configuration?https://kodi.wiki/view/Audio_quickstart_guide
