I noticed the same behaviour … at least when dealing with the problematic uboot (k)nightlies, and the followup fixes …
But in my case it was even wearder because I am always disabling dhcp and using fixed-IP-addresses and suddenly all my devices went back to dhcp and therefore a different IP … but I think this problem is gone now.
Yeah I got a little stumped on that. All I have are notebooks so I had to go out and rustle up a USB keyboard/mouse to set up my box. Would be better if ssh was enabled out of the gate, but they don’t seem to be willing to change that. Not a big deal, not like I often have to set up a new install.
A question about WakeOnLAN:
I’ve read that with activated WOL the stand by power consumption will increase.
I didn’t use WOL and so I will deactivate this function.
I found in the boot.ini
setenv wol “1”
Is that the right way, if I set this value to “0”
Or how can I do that?
Edit the /flash/config.ini instead because the boot.ini is reset on each upgrade.
You must do a:
mount -o remount,rw /flash
first if you edit config.ini with ssh
It will only increase in poweroff and suspend. Although it is minor.
Noticed a small bug with Analog Audio.
But don’t know when it appeared.
I’m using Analog Audio.
Each time Corelec update I have residual sound on the HDMI output.(same sounds than Analog but with low level and very bad quality)
I have to select HDMI output then reselect Analog audio to have no sound on the HDMI output.
Not a big deal however.
Edit proper section in config.ini :
WOL Setting for Odroid N2, 0=off/1=on
wol=0
Okay, I will do that this way.
In config.ini
I have to uncommented wol=1
and set to wol=0
Is that right?
Oh, I see @Sholander give me the correct information!
Just got my Odroid-N2. Installed latest nightly build… testing…
Configuration: Odroid-N2 connected by HDMI to Denon AVR and Denon AVR of course connected to Panasonic TV.
Previously the same configuration with Odroid-C2 without issues described below:
Issue 1 with Odroid-N2: stop, pause buttons are not responsive.
Issue 2 with Odroid-N2: during playback when TV is switched off and switched on again Kodi is stop responding for any CEC keys, screen is frozen - playback is not contiuning…
Issue 3 with Odroid-N2: switching source to TV and then back to HDMI 2 cause Odroid-N2 is not responding for any CEC keys.
CEC Adapter settings are the same as in Odroid-C2:
Enabled - on
Switch source to this device on startup - off
Devices to power on during startup - None
Devices to power off during startup - None
Send “Inactive source” command on shutdown - off
Put devices in standby mode when activating the screensaver - off
Wake devices deactivating the screensaver - off
When the TV is switched off - Ignore
Devices to also put in standby mode - off
Use the TV’s language setting - off
Action when switching to another source - Pause Playback
Physical address (overrules HDMI port) - 0
Force AVR to wake up when Kodi is activated - off
Remote button press delay before repeating (ms) - 600
Remote button press repeat rate (ms) - 20
Remote button press release time (ms) - 150
Verbose logging for the libCEC library is enabled so if needed I can paste log file.
I would like to help you guys in troubleshooting CEC as apparently it doesn’t work as it should comparing with Odroid-C2
Would be nice
Exactly at 23:00 I have changed the source on my TV to TV and then back to HDMI 2 and since then N2 doesn’t respond for CEC
second log collected in the following scenario:
TV on
Amplifier on
Odroid-N2 rebooted
Result: not responding for CEC
third log collected. contain the action of TV turned off at 23:19:59 and turned on again in few seconds. Result: N2 still doesn’t respond for CEC keys.
kodi-03.log (147.4 KB)
Couldn’t understand from the thread - are the boot problems resolved? I’ve been holding off on updates for the past week.
If so, should I update directly to the latest nightly?
Thanks!
yeah, the boot problems are resolved!
This looks a libCEC
problem. Your TV is a Panasonic.
When your TV get detected by libCEC it changes the CEC address from 1
to 4
After that nothing more does happen.
I guess it is better to go over to https://github.com/Pulse-Eight/libcec/issues and make a new issue.
Here is your cec log for the issue:
Line 715: 2019-06-06 23:11:11.215 T:3783209840 DEBUG: CecLogMessage - Broadcast (F): osd name set to 'Broadcast'
Line 716: 2019-06-06 23:11:11.215 T:3783209840 DEBUG: CecLogMessage - connection opened
Line 717: 2019-06-06 23:11:11.215 T:3783209840 DEBUG: CecLogMessage - << Broadcast (F) -> TV (0): POLL
Line 718: 2019-06-06 23:11:11.215 T:3783209840 DEBUG: CecLogMessage - << f0
Line 719: 2019-06-06 23:11:11.215 T:3783209840 DEBUG: CecLogMessage - processor thread started
Line 722: 2019-06-06 23:11:11.272 T:3783209840 DEBUG: CecLogMessage - >> POLL sent
Line 723: 2019-06-06 23:11:11.272 T:3783209840 DEBUG: CecLogMessage - TV (0): device status changed into 'present'
Line 724: 2019-06-06 23:11:11.272 T:3783209840 DEBUG: CecLogMessage - << requesting vendor ID of 'TV' (0)
Line 725: 2019-06-06 23:11:11.272 T:3783209840 DEBUG: CecLogMessage - << f0:8c
Line 729: 2019-06-06 23:11:12.356 T:3783209840 DEBUG: CecLogMessage - expected response not received (87: device vendor id)
Line 730: 2019-06-06 23:11:12.356 T:3783209840 DEBUG: CecLogMessage - << f0:8c
Line 792: 2019-06-06 23:11:13.436 T:3783209840 DEBUG: CecLogMessage - expected response not received (87: device vendor id)
Line 793: 2019-06-06 23:11:13.436 T:3783209840 DEBUG: CecLogMessage - registering new CEC client - v4.0.0
Line 794: 2019-06-06 23:11:13.436 T:3783209840 DEBUG: CecLogMessage - detecting logical address for type 'recording device'
Line 795: 2019-06-06 23:11:13.436 T:3783209840 DEBUG: CecLogMessage - trying logical address 'Recorder 1'
Line 796: 2019-06-06 23:11:13.436 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Recorder 1 (1): POLL
Line 797: 2019-06-06 23:11:13.436 T:3783209840 DEBUG: CecLogMessage - << 11
Line 798: 2019-06-06 23:11:13.496 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 799: 2019-06-06 23:11:13.496 T:3783209840 DEBUG: CecLogMessage - << 11
Line 800: 2019-06-06 23:11:13.552 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 801: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 802: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - using logical address 'Recorder 1'
Line 803: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): device status changed into 'handled by libCEC'
Line 804: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): power status changed from 'unknown' to 'on'
Line 805: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): vendor = Pulse Eight (001582)
Line 806: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): CEC version 1.4
Line 807: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
Line 808: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): osd name set to 'Kodi'
Line 809: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): menu language set to 'eng'
Line 810: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - AutodetectPhysicalAddress - autodetected physical address '2500'
Line 811: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): physical address changed from ffff to 2500
Line 812: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> broadcast (F): physical address 2500
Line 813: 2019-06-06 23:11:13.552 T:3783209840 DEBUG: CecLogMessage - << 1f:84:25:00:01
Line 824: 2019-06-06 23:11:13.709 T:3783209840 DEBUG: CecLogMessage - CEC client registered: libCEC version = 4.0.4, client version = 4.0.0, firmware version = 5, logical address(es) = Recorder 1 (1) , physical address: 2.5.0.0, compiled on Wed Jun 5 23:19:28 UTC 2019 by relkai@hammbwcor01 on Linux 4.15.0-48-generic (x86_64), features: P8_USB, DRM, P8_detect, AOCEC
Line 825: 2019-06-06 23:11:13.710 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> TV (0): OSD name 'Kodi'
Line 826: 2019-06-06 23:11:13.710 T:3783209840 DEBUG: CecLogMessage - << 10:47:4b:6f:64:69
Line 829: 2019-06-06 23:11:13.886 T:3783209840 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
Line 830: 2019-06-06 23:11:13.886 T:3783209840 DEBUG: CecLogMessage - << 10:8f
Line 831: 2019-06-06 23:11:14.005 T:3783209840 DEBUG: CecLogMessage - >> 01:00:47:00
Line 832: 2019-06-06 23:11:14.005 T:3783209840 DEBUG: CecLogMessage - marking opcode 'set osd name' as unsupported feature for device 'TV'
Line 833: 2019-06-06 23:11:14.005 T:3783209840 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): feature abort ( 0)
Line 834: 2019-06-06 23:11:14.207 T:3783209840 DEBUG: CecLogMessage - >> 01:90:00
Line 835: 2019-06-06 23:11:14.207 T:3783209840 DEBUG: CecLogMessage - TV (0): power status changed from 'unknown' to 'on'
Line 836: 2019-06-06 23:11:14.207 T:3783209840 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): report power status (90)
Line 839: 2019-06-06 23:11:14.207 T:3783209840 DEBUG: CecLogMessage - expected response received (90: report power status)
Line 842: 2019-06-06 23:11:14.207 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Recorder 2 (2): POLL
Line 843: 2019-06-06 23:11:14.207 T:3783209840 DEBUG: CecLogMessage - << 12
Line 844: 2019-06-06 23:11:14.263 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 845: 2019-06-06 23:11:14.264 T:3783209840 DEBUG: CecLogMessage - << 12
Line 850: 2019-06-06 23:11:14.320 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 851: 2019-06-06 23:11:14.320 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 852: 2019-06-06 23:11:14.320 T:3783209840 DEBUG: CecLogMessage - Recorder 2 (2): device status changed into 'not present'
Line 853: 2019-06-06 23:11:14.320 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Tuner 1 (3): POLL
Line 854: 2019-06-06 23:11:14.320 T:3783209840 DEBUG: CecLogMessage - << 13
Line 878: 2019-06-06 23:11:14.376 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 879: 2019-06-06 23:11:14.376 T:3783209840 DEBUG: CecLogMessage - << 13
Line 884: 2019-06-06 23:11:14.432 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 885: 2019-06-06 23:11:14.432 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 886: 2019-06-06 23:11:14.432 T:3783209840 DEBUG: CecLogMessage - Tuner 1 (3): device status changed into 'not present'
Line 887: 2019-06-06 23:11:14.432 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Playback 1 (4): POLL
Line 888: 2019-06-06 23:11:14.432 T:3783209840 DEBUG: CecLogMessage - << 14
Line 896: 2019-06-06 23:11:14.488 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 897: 2019-06-06 23:11:14.488 T:3783209840 DEBUG: CecLogMessage - << 14
Line 899: 2019-06-06 23:11:14.544 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 900: 2019-06-06 23:11:14.544 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 901: 2019-06-06 23:11:14.544 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): device status changed into 'not present'
Line 902: 2019-06-06 23:11:14.544 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Audio (5): POLL
Line 903: 2019-06-06 23:11:14.544 T:3783209840 DEBUG: CecLogMessage - << 15
Line 904: 2019-06-06 23:11:14.600 T:3783209840 DEBUG: CecLogMessage - >> POLL sent
Line 905: 2019-06-06 23:11:14.600 T:3783209840 DEBUG: CecLogMessage - Audio (5): device status changed into 'present'
Line 906: 2019-06-06 23:11:14.600 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Tuner 2 (6): POLL
Line 907: 2019-06-06 23:11:14.600 T:3783209840 DEBUG: CecLogMessage - << 16
Line 908: 2019-06-06 23:11:14.656 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 909: 2019-06-06 23:11:14.656 T:3783209840 DEBUG: CecLogMessage - << 16
Line 910: 2019-06-06 23:11:14.711 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 911: 2019-06-06 23:11:14.712 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 912: 2019-06-06 23:11:14.712 T:3783209840 DEBUG: CecLogMessage - Tuner 2 (6): device status changed into 'not present'
Line 913: 2019-06-06 23:11:14.712 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Tuner 3 (7): POLL
Line 914: 2019-06-06 23:11:14.712 T:3783209840 DEBUG: CecLogMessage - << 17
Line 915: 2019-06-06 23:11:14.767 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 916: 2019-06-06 23:11:14.768 T:3783209840 DEBUG: CecLogMessage - << 17
Line 917: 2019-06-06 23:11:14.824 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 918: 2019-06-06 23:11:14.824 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 919: 2019-06-06 23:11:14.824 T:3783209840 DEBUG: CecLogMessage - Tuner 3 (7): device status changed into 'not present'
Line 920: 2019-06-06 23:11:14.824 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Playback 2 (8): POLL
Line 921: 2019-06-06 23:11:14.824 T:3783209840 DEBUG: CecLogMessage - << 18
Line 922: 2019-06-06 23:11:14.880 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 923: 2019-06-06 23:11:14.880 T:3783209840 DEBUG: CecLogMessage - << 18
Line 924: 2019-06-06 23:11:14.936 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 925: 2019-06-06 23:11:14.936 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 926: 2019-06-06 23:11:14.936 T:3783209840 DEBUG: CecLogMessage - Playback 2 (8): device status changed into 'not present'
Line 927: 2019-06-06 23:11:14.936 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Recorder 3 (9): POLL
Line 928: 2019-06-06 23:11:14.936 T:3783209840 DEBUG: CecLogMessage - << 19
Line 929: 2019-06-06 23:11:14.992 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 930: 2019-06-06 23:11:14.992 T:3783209840 DEBUG: CecLogMessage - << 19
Line 931: 2019-06-06 23:11:15.052 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 932: 2019-06-06 23:11:15.052 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 933: 2019-06-06 23:11:15.052 T:3783209840 DEBUG: CecLogMessage - Recorder 3 (9): device status changed into 'not present'
Line 934: 2019-06-06 23:11:15.052 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Tuner 4 (A): POLL
Line 935: 2019-06-06 23:11:15.052 T:3783209840 DEBUG: CecLogMessage - << 1a
Line 936: 2019-06-06 23:11:15.108 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 937: 2019-06-06 23:11:15.109 T:3783209840 DEBUG: CecLogMessage - << 1a
Line 938: 2019-06-06 23:11:15.164 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 939: 2019-06-06 23:11:15.164 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 940: 2019-06-06 23:11:15.164 T:3783209840 DEBUG: CecLogMessage - Tuner 4 (A): device status changed into 'not present'
Line 941: 2019-06-06 23:11:15.164 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Playback 3 (B): POLL
Line 942: 2019-06-06 23:11:15.164 T:3783209840 DEBUG: CecLogMessage - << 1b
Line 943: 2019-06-06 23:11:15.220 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 944: 2019-06-06 23:11:15.220 T:3783209840 DEBUG: CecLogMessage - << 1b
Line 945: 2019-06-06 23:11:15.276 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 946: 2019-06-06 23:11:15.276 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 947: 2019-06-06 23:11:15.276 T:3783209840 DEBUG: CecLogMessage - Playback 3 (B): device status changed into 'not present'
Line 948: 2019-06-06 23:11:15.276 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Reserved 1 (C): POLL
Line 949: 2019-06-06 23:11:15.276 T:3783209840 DEBUG: CecLogMessage - << 1c
Line 950: 2019-06-06 23:11:15.332 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 951: 2019-06-06 23:11:15.332 T:3783209840 DEBUG: CecLogMessage - << 1c
Line 952: 2019-06-06 23:11:15.388 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 953: 2019-06-06 23:11:15.388 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 954: 2019-06-06 23:11:15.388 T:3783209840 DEBUG: CecLogMessage - Reserved 1 (C): device status changed into 'not present'
Line 955: 2019-06-06 23:11:15.388 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Reserved 2 (D): POLL
Line 956: 2019-06-06 23:11:15.388 T:3783209840 DEBUG: CecLogMessage - << 1d
Line 957: 2019-06-06 23:11:15.444 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 958: 2019-06-06 23:11:15.444 T:3783209840 DEBUG: CecLogMessage - << 1d
Line 959: 2019-06-06 23:11:15.500 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 960: 2019-06-06 23:11:15.500 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 961: 2019-06-06 23:11:15.500 T:3783209840 DEBUG: CecLogMessage - Reserved 2 (D): device status changed into 'not present'
Line 962: 2019-06-06 23:11:15.500 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> Free use (E): POLL
Line 963: 2019-06-06 23:11:15.500 T:3783209840 DEBUG: CecLogMessage - << 1e
Line 964: 2019-06-06 23:11:15.560 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 965: 2019-06-06 23:11:15.560 T:3783209840 DEBUG: CecLogMessage - << 1e
Line 966: 2019-06-06 23:11:15.616 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 967: 2019-06-06 23:11:15.616 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 968: 2019-06-06 23:11:15.616 T:3783209840 DEBUG: CecLogMessage - Free use (E): device status changed into 'not present'
Line 969: 2019-06-06 23:11:15.616 T:3783209840 DEBUG: CecLogMessage - << requesting vendor ID of 'Audio' (5)
Line 970: 2019-06-06 23:11:15.616 T:3783209840 DEBUG: CecLogMessage - << 15:8c
Line 1000: 2019-06-06 23:11:15.835 T:3783209840 DEBUG: CecLogMessage - >> 5f:87:00:80:45
Line 1001: 2019-06-06 23:11:15.835 T:3783209840 DEBUG: CecLogMessage - Audio (5): vendor = Panasonic (008045)
Line 1002: 2019-06-06 23:11:15.835 T:3783209840 DEBUG: CecLogMessage - >> Audio (5) -> Broadcast (F): device vendor id (87)
Line 1003: 2019-06-06 23:11:15.836 T:3783209840 DEBUG: CecLogMessage - expected response received (87: device vendor id)
Line 1004: 2019-06-06 23:11:15.836 T:3783209840 DEBUG: CecLogMessage - replacing the command handler for device 'Audio' (5)
Line 1005: 2019-06-06 23:11:15.836 T:3783209840 DEBUG: CecLogMessage - << requesting OSD name of 'Audio' (5)
Line 1006: 2019-06-06 23:11:15.836 T:3783209840 DEBUG: CecLogMessage - << 15:46
Line 1010: 2019-06-06 23:11:15.906 T:3783209840 DEBUG: CecLogMessage - >> 01:8c
Line 1011: 2019-06-06 23:11:15.906 T:3783209840 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): give device vendor id (8C)
Line 1012: 2019-06-06 23:11:16.001 T:3783209840 DEBUG: CecLogMessage - << Recorder 1 (1) -> TV (0): vendor id Pulse Eight (1582)
Line 1013: 2019-06-06 23:11:16.001 T:3783209840 DEBUG: CecLogMessage - << 1f:87:00:15:82
Line 1034: 2019-06-06 23:11:16.445 T:3783209840 DEBUG: CecLogMessage - >> 51:47:41:56:52:2d:58:32:30:30:30
Line 1035: 2019-06-06 23:11:16.445 T:3783209840 DEBUG: CecLogMessage - Audio (5): osd name set to 'AVR-X2000'
Line 1036: 2019-06-06 23:11:16.445 T:3783209840 DEBUG: CecLogMessage - >> Audio (5) -> Recorder 1 (1): set osd name (47)
Line 1040: 2019-06-06 23:11:16.446 T:3783209840 DEBUG: CecLogMessage - expected response received (47: set osd name)
Line 1044: 2019-06-06 23:11:16.636 T:3783209840 DEBUG: CecLogMessage - >> 01:a0:00:80:45:06:05
Line 1045: 2019-06-06 23:11:16.636 T:3783209840 DEBUG: CecLogMessage - TV (0): vendor = Panasonic (008045)
Line 1046: 2019-06-06 23:11:16.636 T:3783209840 DEBUG: CecLogMessage - >> process after replacing vendor handler: >> 01:a0:00:80:45:06:05
Line 1047: 2019-06-06 23:11:16.636 T:3783209840 DEBUG: CecLogMessage - replacing the command handler for device 'TV' (0)
Line 1048: 2019-06-06 23:11:16.636 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): vendor = Panasonic (008045)
Line 1049: 2019-06-06 23:11:16.636 T:3783209840 DEBUG: CecLogMessage - replacing the command handler for device 'Recorder 1' (1)
Line 1050: 2019-06-06 23:11:16.636 T:3783209840 DEBUG: CecLogMessage - changing device type 'recording device' into 'playback device'
Line 1051: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - unregistering client: libCEC version = 4.0.4, client version = 4.0.0, firmware version = 5, logical address(es) = Recorder 1 (1) , physical address: 2.5.0.0, compiled on Wed Jun 5 23:19:28 UTC 2019 by relkai@hammbwcor01 on Linux 4.15.0-48-generic (x86_64), features: P8_USB, DRM, P8_detect, AOCEC
Line 1052: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): power status changed from 'on' to 'unknown'
Line 1053: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): vendor command with id (A0)
Line 1054: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): vendor = Unknown (000000)
Line 1055: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): CEC version unknown
Line 1056: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): osd name set to 'Recorder 1'
Line 1057: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - Recorder 1 (1): device status changed into 'unknown'
Line 1058: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - registering new CEC client - v4.0.0
Line 1059: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - detecting logical address for type 'playback device'
Line 1060: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - trying logical address 'Playback 1'
Line 1061: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - << Playback 1 (4) -> Playback 1 (4): POLL
Line 1062: 2019-06-06 23:11:16.637 T:3783209840 DEBUG: CecLogMessage - << 44
Line 1065: 2019-06-06 23:11:16.692 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 1066: 2019-06-06 23:11:16.692 T:3783209840 DEBUG: CecLogMessage - << 44
Line 1067: 2019-06-06 23:11:16.748 T:3783209840 WARNING: CecLogMessage - Write: write failed
Line 1068: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - >> POLL not sent
Line 1069: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - using logical address 'Playback 1'
Line 1070: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): device status changed into 'handled by libCEC'
Line 1071: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): power status changed from 'unknown' to 'on'
Line 1072: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): vendor = Pulse Eight (001582)
Line 1073: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): CEC version 1.4
Line 1074: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - AllocateLogicalAddresses - device '0', type 'playback device', LA '4'
Line 1075: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - AutodetectPhysicalAddress - autodetected physical address '2500'
Line 1076: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): physical address changed from ffff to 2500
Line 1077: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): osd name set to 'Kodi'
Line 1078: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): menu language set to 'eng'
Line 1079: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - physical address unchanged (2500)
Line 1080: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - CEC client registered: libCEC version = 4.0.4, client version = 4.0.0, firmware version = 5, logical address(es) = Playback 1 (4) , physical address: 2.5.0.0, compiled on Wed Jun 5 23:19:28 UTC 2019 by relkai@hammbwcor01 on Linux 4.15.0-48-generic (x86_64), features: P8_USB, DRM, P8_detect, AOCEC
Line 1081: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - Playback 1 (4): vendor = Panasonic (008045)
Line 1082: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - replacing the command handler for device 'Playback 1' (4)
Line 1083: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - << Playback 1 (4) -> TV (0): OSD name 'Kodi'
Line 1084: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - 'set osd name' is marked as unsupported feature for device 'TV'
Line 1085: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
Line 1086: 2019-06-06 23:11:16.748 T:3783209840 DEBUG: CecLogMessage - << 40:8f
Line 1089: 2019-06-06 23:11:17.828 T:3783209840 DEBUG: CecLogMessage - expected response not received (90: report power status)
Line 1090: 2019-06-06 23:11:17.828 T:3783209840 DEBUG: CecLogMessage - << 40:8f
Line 1091: 2019-06-06 23:11:18.908 T:3783209840 DEBUG: CecLogMessage - expected response not received (90: report power status)
Line 1092: 2019-06-06 23:11:18.909 T:3783209840 DEBUG: CecLogMessage - TV (0): power status changed from 'on' to 'unknown'
Line 1093: 2019-06-06 23:11:18.909 T:3783209840 DEBUG: CecLogMessage - >> 01:a0:00:80:45:06:05
Line 1094: 2019-06-06 23:11:18.909 T:3783209840 DEBUG: CecLogMessage - >> 04:90:00
Line 1095: 2019-06-06 23:11:18.909 T:3783209840 DEBUG: CecLogMessage - TV (0): power status changed from 'unknown' to 'on'
Line 1096: 2019-06-06 23:11:18.909 T:3783209840 DEBUG: CecLogMessage - >> 04:90:00
Line 1097: 2019-06-06 23:11:18.909 T:3783209840 DEBUG: CecLogMessage - >> TV (0) -> Playback 1 (4): report power status (90)
It’s about this commit: https://github.com/Pulse-Eight/libcec/commit/3e61b35032f69fb93869796e2f985de8cff2ae33#diff-37ade17cbd0eda62edcd3a08ab42f319R44 from 1 1 2012.
Does someone know how to rotate screen to upside down (180 degrees) on Odroid N2?
Thanks for your response.
As I’m not technician I’m afraid it would be pointless to rise myself a case at github
Is there anything what can be fixed by you or this is a problem out of CoreELEC?
Interesting is that there are no such issues when I connect Odroid-C2 instead of Odroid-N2. Especially issue 2 is annoying. Are you able to reproduce that scenario?
It is a issue by libCEC & Panasonic TV. I can’t reproduce as I do not have your TV (brand, type)
Maybe Panasonic changed something in newer models as the commit is from 2012…
Just open an issue and use the log above I posted and descripe your problem.
When libCEC is fixed we can include the changes in our build.
Make the same log also for the C2 please - I will compare it with the N2.
