Sorry , i don’t have p211 uboot, the files that i replaced of my box’s FW are bootloader.PARTITION, DDR.USB and UBOOT.USB, i can’t store them directly.
Do I not understand what you mean? What should I do?
I got it wrong. I’ll do it again right away.
gxl_p211_v1#store disprotect key
[store]disprotect key
gxl_p211_v1#store erase boot
emmckey_is_protected : disprotect
start = 0,end = 8191
mmc switch to boot0 success
blkcnt = 8192
mmc switch to boot1 success
blkcnt = 8192
mmc switch to user success
gxl_p211_v1#
gxl_p211_v1#reboot
reboot use default mode: normal
INFO: PSCI Affinity Map:
INFO: AffInst: Level 0, MPID 0x0, State ON
INFO: AffInst: Level 0, MPID 0x1, State OFF
INFO: AffInst: Level 0, MPID 0x2, State OFF
INFO: AffInst: Level 0, MPID 0x3, State OFF
bl31 reb▒GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:1;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:2;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:4;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:5;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:6;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:7;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:8;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:9;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:A;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:B;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;P. ▒▒▒▒▒▒▒▒▒@▒▒▒0▒▒▒x0▒k▒_fp▒▒▒▒▒▒▒▒▒▒▒▒▒▒GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:1;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:2;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:4;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:5;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:6;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:7;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:8;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:9;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8_▒▒▒▒▒▒▒▒▒▒▒▒▒kk▒▒cHK:A0;Sw▒۫m▒▒▒▒LOOP:B;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:C;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:D;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;
Is that right?
Yes, that is correct now. Install the new u-boot on the sdcard, start the box with this sdcard and post the log.
u-boot-p271-p261
GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:1;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:2;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:4;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:5;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:6;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:7;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:8;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:9;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:A;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:B;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:C;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;USB:8;LOOP:D;EMMC:0;READ:0;CHK:A0;READ:0;CHK:A0;READ:0;CHK:A0;SD:800;
These codes keep appearing. Do I have to flash back to the system and test again?
gxl_p211_v1#
gxl_p211_v1#
gxl_p211_v1#store init 3; reset
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_init] mmc init success
switch to partitions #0, OK
mmc1(part 0) is current device
Device: SDIO Port C
Manufacturer ID: 70
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
mmc clock: 40000000
Bus Width: 8-bit
[store]amlmmc key
emmc disprotect key
[store]amlmmc erase 1emmckey_is_protected : disprotect
blkcnt = 14942208
start = 0,end = 14942207
resetting ...
GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;CHK:A0;READ:0;0.0;CHK:0;
TE: 137450
BL2 Built : 20:33:18, Oct 17 2017.
gxl ge978680 - liqiang.hou@droid07-sz
Board ID = 3, adc=226
set vcck to 1070 mv
set vddee to 1070 mv
CPU clk: 1200MHz
2layers board, use ddr_set[0]
DQS-corr enabled
DDR scramble enabled
Pull down ddr cke
STICKY_REG0: 0x00000000
STICKY_REG1: 0x00000000
STICKY_REG9: 0x00000000
DDR3 chl: Rank0 @ 696MHz
Rank0: 1024MB(auto)-2T-11
DataBus test pass!
AddrBus test pass!
emmc switch highspeed 52M
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x00007600
Load bl301 from eMMC, src: 0x00018200, des: 0x01200000, size: 0x00002200
Load bl31 from eMMC, src: 0x0001c200, des: 0x10100000, size: 0x00019600
Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x0007d800
NOTICE: BL3-1: v1.0(debug):3048f05
NOTICE: BL3-1: Built : 22:38:14, Aug 20 2017
NOTICE: BL31: GXL normal boot!
NOTICE: BL31: BL33 decompress pass
[Image: gxl_v1.1.3098-cf1f353 2017-09-11 19:43:10 xiaobo.gu@droid12]
efuse init ops = c1
efuse init hdcp = c, cf9=7
bl30: check_permit, count is 1
bl30: check_permit: ok!
chipid: 0 0 3 c c 0 92 b3 98 a0 0 c1 not ES chip
[0.390439 Inits done]
sINFO: BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR: Error initializing runtime service opteed_fast
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
ecure task start!
kigh tas
s
ttUa-rBto!o
r lo2w0 1t5a.s0k1 s(tartM!a
05 2018 - 20:55:20)
DRAM: 1 GiB
Relocation Offset is: 36e86000
gpio: pin GPIODV_24 (gpio 43) value is 1
register usb cfg[0][1] = 0000000037f582b0
[CANVAS]canvas init
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC: aml_priv->desc_buf = 0x0000000033e76ac0
aml_priv->desc_buf = 0x0000000033e78de0
SDIO Port B: 0, SDIO Port C: 1
dtb magic 00000000
Amlogic multi-dtb tool
Cannot find legal dtb!
start dts,buffer=0000000033e7b610,dt_addr=0000000033e7b610
check_valid_dts: FDT_ERR_BADMAGIC
get_partition_from_dts: -9
get_ptbl_from_dtb()-259: get partition table from dts faild
mmc_device_init()-1081: get partition table from dtb failed
get_ptbl_rsv()-483: magic faild MPT,
mmc_device_init()-1108: dtb&rsv are not exist, no LPT source
_find_partition_by_name()-188: do not find match in table env
get partition info failed !!
Using default environment
In: serial
Out: serial
Err: serial
board id is : 3
hpd_state=0
cvbs performance type = 7, table = 1
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-917: calc 0, store 0
dtb_read()-1034: cpy 1 is not valid
dtb_read()-1034: cpy 0 is not valid
dtb_read()-1039: total valid 0
[store]Err:do_store_dtb_ops,L236:Fail in fdt check header
board_late_init(): [store dtb read $dtb_mem_addr] fail
load dtb to 1000000
[store]To run cmd[emmc dtb_read 1000000 0x40000]
board_late_init(): store dtb read 1000000 fail
Net: dwmac.c9410000
wipe_data=successful
wipe_cache=successful
_find_partition_by_name()-188: do not find match in table logo
Cannot find dev.
amlmmc cmd <NULL> failed
store - STORE sub-system
Usage:
store store init flag
store read name addr off|partition size
read 'size' bytes starting at offset 'off'
to/from memory address 'addr', skipping bad blocks.
store write name addr off|partition size
write 'size' bytes starting at offset 'off'
store rom_write add off size.
write uboot to the boot device
store erase boot/data:
erase the area which is uboot or data
store erase partition <partition_name>:
erase the area which partition in u-boot
store erase dtb
store erase key
store rom_protect on/off
store scrub off|partition size
scrub the area from offset and size
store dtb iread/read/write addr <size>
read/write dtb, size is optional
store key read/write addr <size>
read/write key, size is optional
store mbr addr
update mbr/partition table by dtb
cmd store failed
Err imgread(L333):Fail to read 0x2000B from part[logo] at offset 0
There is no valid bmp file at the given address
[CANVAS]addr=0x3d800000 width=3840, height=2160
upgrade_step=0
[KM]Error:f[keymanage_dts_parse]L255:not a fdt at 0x0000000001000000
rebootmode=normal
key1 = 7d82dd22
key2 = 7e81dd22
key3 = 7788dd22
time_out = 7a120
ir init
irkey - irkey key_value1 key_value2 key_value3 time_value
Usage:
irkey
key1 = fb04ff00
key2 = ef10ff00
key3 = b14eff00
time_out = 7a120
ir init
Usage:
irkey
Hit any key to stop autoboot: 0
_find_partition_by_name()-188: do not find match in table boot
Cannot find dev.
Usage:
store erase dtb
store erase key
store mbr addr
cmd store failed
Err imgread(L132):Fail to read 0x100000B from part[boot] at offset 0
Enter USB burn
Try connect time out 1001, 1000, 1808
card out
emmc/sd response timeout, cmd1, status=0x1ff2800
[MSG]mmcinfo failed!
(Re)start USB...
USB0: USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning usb for storage devices... init_part() 278: PART_TYPE_DOS
1 Storage Device(s) found
reading aml_autoscript
** Unable to read file aml_autoscript **
reading recovery.img
** Unable to read file recovery.img **
_find_partition_by_name()-188: do not find match in table recovery
Cannot find dev.
Usage:
store erase dtb
store erase key
store mbr addr
cmd store failed
Err imgread(L132):Fail to read 0x100000B from part[recovery] at offset 0
gxl_p211_v1#
You did not write the u-boot on the sd card, it is empty…
I use an USB drive not sd card.
u-boot can only be started from the sd card
But there is no TF slot in this box. I’ll try again. Isn’t the USB flash disk OK before?
I could not know this. A little later I’ll send you the link to the Android files to replace in the IMG I sent you earlier
Why could the “run store erase boot” be read yesterday?
OK,OK, I’m very sorry to disturb your time.
Please check your PM. Post logs here
I can only repalc 3 files ( bootloader.PARTITION,DDR.USBand UBOOT.USB), how to replace another two?
I can’t burn it in…
Enter USB burn
Set Addr 13
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
ID[16]
tplcmd[ echo 12345]
12345
[MSG]ret = 0
[info]success
BULKcmd[ low_power]
[info]success
BULKcmd[bootloader_is_old]
[info]success
BULKcmd[erase_bootloader]
[info]success
BULKcmd[reset]
reboot mode: normal
bl31 reboot re▒GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;CHK:A0;READ:0;0.0;CHK:0;
TE: 139024
set vcck to 1070 mv
CPU clk: 1200MHz
Skip usb!
0.0;
TE: 2711295
BL2 Built : 15:21:58, Mar 26 2020. gxl g486bc38 - gongwei.chen@droid11-sz
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 3
CPU clk: 1200MHz
BL2 USB
DQS-corr enabled
DDR3 chl: Rank0+1 @ 792MHz - FAIL
DDR3 chl: Rank0 @ 792MHz
bist_test rank: 0 21 00 42 2d 11 4a 1e 00 3d 30 15 4b 21 00 42 2d 12 49 1e 00 3d 2f 13 4b 734 - PASS
Set ddr ssc: ppm1000-
Load fip header from USB, src: 0x0000c000, des: 0x01400000, size: 0x00004000, part: 0
New fip structure!
Load bl30 from USB, src: 0x00010000, des: 0x013c0000, size: 0x0000d600, part: 0
Load bl31 from USB, src: 0x00020000, des: 0x05100000, size: 0x0002c400, part: 0
0002c400Load bl33 from USB, src: 0x00050000, des: 0x01000000, size: 0x00080a00, part: 0
NOTICE: BL3-1: v1.0(release):f5121da90
NOTICE: BL3-1: Built : 20:18:22, Nov 22 2019
NOTICE: BL3-1: GXL normal boot!
NOTICE: BL3-1: BL33 decompress fail
NOTICE: BL3-1: ERROR! GXL FIP HDR process fail 4!
