Please add the dtb for using s905L2B&3B soc's tvbox,such as mgv2000、zte b860av2.1a\m\t、e900v21e etc,thank you guys verymuch!
I find the way that update uboot only!
gxl_p211_v1#help
?       - alias for 'help'
aml_sysrecovery- Burning with amlogic format package from partition sysrecovery
amlmmc  - AMLMMC sub system
amlnf   - aml nand sub-system
amlnf_test- AMLPHYNAND sub-system
autoscr - run script from memory
base    - print or set address offset
bmp     - manipulate BMP image data
booti   - boot arm64 Linux Image image from memory
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
cbusreg - cbus register read/write
clkmsr  - measure PLL clock
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
cvbs    - CVBS sub-system
d2pll   - DDR set PLL function
dcache  - enable or disable data cache
ddr_dqs_window_step- DDR tune dqs function
ddr_spec_test- DDR test function
ddr_sram_tune- DDR sram tune dqs
ddr_test_ac_bit_setup_hold_window- DDR test ac bit margin function
ddr_test_cmd- ddr_test_cmd cmd arg1 arg2 arg3...
ddr_test_copy- ddr_test_copy function
ddr_test_data_bit_setup_hold_window- DDR test data bit margin function
ddr_test_tune_dqs_env- do_ddr_fine_tune_lcdlr_env arg1 arg2 arg3...
ddr_tune_aclcdlr_step- ddr_tune_aclcdlr_step function
ddr_tune_ddr_ac_acbdlr_ck- DDR tune dqs function
ddr_tune_ddr_ac_aclcdlr- DDR tune dqs function
ddr_tune_ddr_ac_bdlr- DDR tune ac bdl function
ddr_tune_ddr_vref- DDR tune vref function ddr_tune_ddr_vref  a 0 0x8000000  1 48                      1
ddr_tune_dqs- DDR tune dqs function
ddr_tune_dqs_step- ddr_tune_dqs_step function
ddrft   - Enable/Disable ddr full test at runtime
Only support gxl/gxm/txl
ddrtest - DDR test function
ddrtest_gate- DDR test function should dcache off ddrtest_gate a 0 0x80000 1 0 3
ddrtest_gx_crosstalk- DDR test function
ddrtest_gxtvbb_crosstalk- DDR test function
defenv_reserv- reserve some specified envs after defaulting env
dhcp    - boot image via network using DHCP/TFTP protocol
echo    - echo args to console
efuse   - efuse read/write data commands
efuse_user- efuse user space read write ops
emmc    - EMMC sub system
env     - environment handling commands
exit    - exit script
false   - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fatsize - determine a file's size
fdt     - flattened device tree utility commands
get_rebootmode- get reboot mode
go      - start application at address 'addr'
gpio    - query and control gpio pins
hdmitx  - HDMITX sub-system
help    - print command description/usage
i2c     - I2C sub-system
icache  - enable or disable instruction cache
imgread - Read the image from internal flash with actual size
irkey   - irkey key_value1 key_value2 key_value3 time_value
itest   - return true/false on integer compare
jtagoff - disable jtag
jtagon  - enable jtag
keyman  - Unify key ops interfaces based dts cfg
keyunify- key unify sub-system
loop    - infinite loop on address range
macreg  - ethernet mac register read/write/dump
md      - memory display
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
mw      - memory write (fill)
mwm     - mw mask function
nm      - memory modify (constant address)
open_scp_log- print SCP messgage
osd     - osd sub-system
phyreg  - ethernet phy register read/write/dump
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
rarpboot- boot image via network using RARP/TFTP protocol
read_temp- cpu temp-system
reboot  - set reboot mode and reboot system
reset   - Perform RESET of the CPU
rsvmem  - reserve memory
run     - run commands in an environment variable
saradc  - saradc sub-system
saradc_12bit- saradc sub-system
saveenv - save environment variables to persistent storage
sdc_burn- Burning with amlogic format package in sdmmc
sdc_update- Burning a partition with image file in sdmmc card
set_trim_base- cpu temp-system
set_usb_boot- set usb boot mode
setenv  - set environment variables
showvar - print local hushshell variables
sleep   - delay execution for some time
store   - STORE sub-system
systemoff- system off
temp_triming- cpu temp-system
test    - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true    - do nothing, successfully
unpackimg- un pack logo image into pictures
update  - Enter v2 usbburning mode
usb     - USB sub-system
usb_burn- Burning with amlogic format package in usb
usb_update- Burning a partition with image file in usb host
usbboot - boot from USB device
version - print monitor, compiler and linker version
vout    - VOUT sub-system
vpu     - vpu sub-system
wipeisb - wipeisb
write_trim- cpu temp-system
write_version- cpu temp-system
gxl_p211_v1#usb_update bootloader u-boot.bin
usb_start_count 1
[fat]Filesize is 0xd4000B[0M]
[MSG]Down(store) part(bootloader) sz(0xd4000) fmt(normal)
[MSG]totalSlotNum = 0, nextWriteBackSlot 14
[MSG]Burn Start...
mmc switch to boot0 success
mmc switch to boot1 success
mmc switch to user success
[MSG]align bootloader sz from 0xd4000 to 0x100000
[MSG]Burn complete
BURN u-boot.bin to part bootloader OK!
=====>Burn part bootloader in fmt normal OK<======
gxl_p211_v1#
gxl_p211_v1#<INTERRUPT>
gxl_p211_v1#reboot
reboot use default mode: normal
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State OFF
INFO:      AffInst: Level 0, MPID 0x2, State OFF
INFO:      AffInst: Level 0, MPID 0x3, State OFF
bl31 reb▒GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 95600
BL2 Built : 15:21:58, Mar 26 2020. gxl g486bc38 - gongwei.chen@droid11-sz
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 3
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0+1 @ 792MHz - FAIL
DDR3 chl: Rank0 @ 792MHz
bist_test rank: 0 20 00 41 2d 11 49 1e 00 3d 30 15 4c 20 00 40 2e 13 4a 1e 00 3c 2f 14 4b 725   - PASS
Rank0: 1024MB(auto)-2T-11
AddrBus test pass!
Set ddr ssc: ppm1000-
eMMC boot @ 0
sw8 s
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
emmc switch 0 ok
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000, part: 0
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x013c0000, size: 0x0000d600, part: 0
Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x0002c400, part: 0
0002c400Load bl33 from eMMC, src: 0x00050200, des: 0x01000000, size: 0x00080a00, part: 0
NOTICE:  BL3-1: v1.0(release):f5121da90
NOTICE:  BL3-1: Built : 20:18:22, Nov 22 2019
NOTICE:  BL3-1: GXL normal boot!
NOTICE:  BL3-1: BL33 decompress fail
NOTICE:  BL3-1: ERROR! GXL FIP HDR process fail 4!
mpu_config_enable:system pre init ok
dmc sec lock
[Image: gxl_v1.1.3394-7d43064d5 2020-05-07 15:37:15 gongwei.chen@droid11-sz]
OPS=0xc1
26 0a c1 00 f7 d1 f1 21 3d 41 65 dd 84 f5 c4 f7
[0.557530 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
I restore my box again with original IMG,then i copied the u-boot.bin to USB drive,then i stoped the autoboot and reboot it from USB drive with uboot cmd.
gxl_p211_v1#
gxl_p211_v1#usbboot
** No device specified **
gxl_p211_v1#usb
Usage:
usb start - start (scan) USB controller
usb reset - reset (rescan) USB controller
usb stop [f] - stop USB [f]=force stop
usb tree - show USB device tree
usb info [dev] - show available USB devices
usb test [dev] [port] [mode] - set USB 2.0 test mode
    (specify port 0 to indicate the device's upstream port)
    Available modes: J, K, S[E0_NAK], P[acket], F[orce_Enable]
usb storage - show details of USB storage devices
usb dev [dev] - show or set current USB storage device
usb part [dev] - print partition table of one or all USB storage    devices
usb read addr blk# cnt - read `cnt' blocks starting at block `blk#'
    to memory address `addr'
usb write addr blk# cnt - write `cnt' blocks starting at block `blk#'
    from memory address `addr'
gxl_p211_v1#usb start
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... init_part() 278: PART_TYPE_DOS
1 Storage Device(s) found
gxl_p211_v1#usbboot
gxl_p211_v1#No device specified <INTERRUPT>
gxl_p211_v1#usbboot  /help
gxl_p211_v1#usb tree
USB device tree:
  1  Hub (5 Gb/s, 0mA)
  |  u-boot XHCI Host Controller
  +-2  Mass Storage (480 Mb/s, 300mA)
       Kingston DataTraveler 3.0 60A44C413984F2A10970AB41
gxl_p211_v1#usb dev [dev1]
USB device 0:
    Device 0: Vendor: Kingston Rev:  Prod: DataTraveler 3.0
            Type: Removable Hard Disk
            Capacity: 14755.2 MB = 14.4 GB (30218842 x 512)
... is now current device
gxl_p211_v1#usbboot Device 0
Loading from usb device 0, partition 1: Name: usbda1  Type: U-Boot
"Synchronous Abort" handler, esr 0x96000210
ELR:     37ebe380
LR:      37ec2730
x0 : 00000000000000de x1 : 0000000037f80cc0
x2 : 0000000000000000 x3 : 0000000000000200
x4 : 0000000033e7e0c0 x5 : 0000000037f14db0
x6 : 0000000037f14db0 x7 : 0000000000000200
x8 : 000000000000000d x9 : 0000000000000000
x10: 00000000003e0000 x11: 0000000000010000
x12: 0000000000000000 x13: 0000000000000000
x14: 0000000000000000 x15: 0000000000000000
x16: 0000000000000000 x17: 0000000000000000
x18: 0000000033e75e28 x19: 00000000000000de
x20: 0000000000000003 x21: 0000000000000000
x22: 0000000000000001 x23: 0000000033e80030
x24: 0000000000000001 x25: 0000000000000000
x26: 0000000037f612b0 x27: 0000000033e80060
x28: 0000000000000000 x29: 0000000033e75aa0
Resetting CPU ...
resetting ...
TE: 175460
BL2 Built : 20:33:18, Oct 17 2017.
gxl ge978680 - liqiang.hou@droid07-sz
Board ID = 3, adc=227
set vcck to 1070 mv
set vddee to 1070 mv
CPU clk: 1200MHz
2layers board, use ddr_set[0]
DQS-corr enabled
Pull down ddr cke
STICKY_REG0: 0x00000000
STICKY_REG1: 0x00000000
STICKY_REG9: 0x00000000
DDR3 chl: Rank0 @ 696MHz
DataBus test pass!
AddrBus test pass!
emmc switch highspeed 52M
-s
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x00007600
Load bl301 from eMMC, src: 0x00018200, des: 0x01200000, size: 0x00002200
Load bl31 from eMMC, src: 0x0001c200, des: 0x10100000, size: 0x00019600
Load bl33 from eMMC, src: 0x00038200, des: 0x01000000, size: 0x0007d800
NOTICE:  BL3-1: v1.0(debug):3048f05
NOTICE:  BL3-1: Built : 22:38:14, Aug 20 2017
NOTICE:  BL31: GXL normal boot!
NOTICE:  BL31: BL33 decompress pass
[Image: gxl_v1.1.3098-cf1f353 2017-09-11 19:43:10 xiaobo.gu@droid12]
efuse init ops = c1
efuse init hdcp = c, cf9=7
bl30: check_permit, count is 1
bl30: check_permit: ok!
chipid: 0 0 3 c c 0 92 b3 98 a0 0 c1 not ES chip
[0.429212 Inits done]
INFOs:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
ecure task start!
kigh tas
s
ttUa-rBto!o
  2lo0w1 5t.a0s1k  (sMtaarr t0!5
 2018 - 20:55:20)
DRAM:  1 GiB
Relocation Offset is: 36e86000
gpio: pin GPIODV_24 (gpio 43) value is 1
register usb cfg[0][1] = 0000000037f582b0
[CANVAS]canvas init
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC:   aml_priv->desc_buf = 0x0000000033e76ac0
aml_priv->desc_buf = 0x0000000033e78de0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_init] mmc init success
dtb magic 08088b1f
      Amlogic multi-dtb tool
      GZIP format, decompress...
      Multi dtb detected
      2layers board, board id use 7
      Multi dtb tool version: v2 .
      Support 7 dtbs.
        aml_dt soc: gxlx platform: p261 variant: 1g
        dtb 0 soc: gxbb   plat: p201   vari: 1g
        dtb 1 soc: gxbb   plat: p201   vari: 2g
        dtb 2 soc: gxl   plat: p211   vari: 1g
        dtb 3 soc: gxl   plat: p211   vari: 2g
        dtb 4 soc: gxl   plat: p215   vari: 1g
        dtb 5 soc: gxl   plat: p215   vari: 2g
        dtb 6 soc: gxlx   plat: p261   vari: 1g
      Find match dtb: 6
start dts,buffer=0000000033e7b610,dt_addr=0000000033e7b610
      Single dtb detected
parts: 13
00:      logo   0000000002000000 1
01:  recovery   0000000002000000 1
02:       rsv   0000000000800000 1
03:       tee   0000000000800000 1
04:     crypt   0000000002000000 1
05:      misc   0000000002000000 1
06: instaboot   0000000020000000 1
07:      boot   0000000002000000 1
08:    system   0000000040000000 1
09:     cache   0000000020000000 2
10:    params   0000000004000000 2
11: bootfiles   0000000020000000 2
12:      data   ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
check pattern success
mmc env offset: 0x27400000
In:    serial
Out:   serial
Err:   serial
board id is : 3
hpd_state=0
cvbs performance type = 7, table = 1
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-917: calc da98d767, store da98d767
dtb_read()-1039: total valid 2
dtb_read()-1106: do nothing
      Multi dtb detected
      Support 7 dtbs.
      Find match dtb: 6
Net:   dwmac.c9410000
wipe_data=successful
wipe_cache=successful
bmp pixel: 16
[CANVAS]addr=0x3d800000 width=2560, height=1440
upgrade_step=2
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
rebootmode=normal
key1 = 7d82dd22
key2 = 7e81dd22
key3 = 7788dd22
time_out = 7a120
ir init
Usage:
irkey
key1 = fb04ff00
key2 = ef10ff00
key3 = b14eff00
time_out = 7a120
ir init
Usage:
irkey
Hit any key to stop autoboot:  0
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =33efb830
copy done
      Single dtb detected
load dtb from 0x1000000 ......
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x01fba400
   Loading Ramdisk to 33d7a000, end 33e7368d ... OK
   Loading Device Tree to 000000001fff3000, end 000000001ffff6f9 ... OK
signature:
fdt_instaboot: get header err
Starting kernel ...
uboot time: 2772923 us
[    0.000000@0] Initializing cgroup subsys cpu
[    0.000000@0] Initializing cgroup subsys cpuacct
[    0.000000@0] Linux version 3.14.29 (yangyumei@vanlen) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #1 SMP PREEMPT Sat Mar 17 09:22:24 CST 2018
[    0.000000@0] CPU: ARMv71 Processor [410fd034] revision 4
[    0.000000@0] no prop version_code
[    0.000000@0] bootconsole [earlycon0] enabled
get_dvfs_info 0007
INFO:    HDCP22 key read fail!
INFO:    p1d 0
INFO:    pd1 0
root@p201_iptv:/ #
bl30 dump.txt (145.9 KB)
You can only use these commands for the stock u-boot, not for the p211, since the blobs are of different sizes.
I have now fixed FIP signing errors. Please install this IMG via UBT and post the log.
aml_upgrade_package_gxlx
Note: Partition sizes are reduced to a minimum, as your eMMC only has 8GB storage capacity.
Can’t install!!!
gxl_p211_v1#
gxl_p211_v1#update
Enter USB burn
Set Addr 17
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
ID[16]
tplcmd[    echo 12345]
12345
[MSG]ret = 0
[info]success
BULKcmd[    low_power]
[info]success
BULKcmd[bootloader_is_old]
[info]success
BULKcmd[erase_bootloader]
[info]success
BULKcmd[reset]
reboot mode: normal
bl31 reboot re▒GXLX:BL1:9ac50e:4a8da0;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 96186
Board ID = 3, adc=226
set vcck to 1070 mv
CPU clk: 1200MHz
Skip usb!
0.0;
TE: 2744563
set vcck to 1120 mv
Board ID = 3
CPU clk: 1200MHz
BL2 USB
DQS-corr enabled
bist_test rank: 0 21 00 43 2d 11 4a 1f 00 3e 30 15 4c 20 00 41 2f 13 4b 1e 00 3c 30 14 4c 725   - PASS
Load fip header from USB, src: 0x0000c000, des: 0x01400000, size: 0x00004000, part: 0
New fip structure!
Load bl30 from USB, src: 0x00010000, des: 0x013c0000, size: 0x0000d600, part: 0
Load bl31 from USB, src: 0x00020000, des: 0x05100000, size: 0x0002c400, part: 0
0002c400Load bl33 from USB, src: 0x00050000, des: 0x01000000, size: 0x00080a00, part: 0
dmc sec lock
OPS=0xc1
[3.522747 Inits done]
secure task start!
high task start!
low task start!
It’s really like i install the img of you asked me replace 3 files by myself last time.
What should i do next?
check your PM, install the update
Success!
gxl_p211_v1#update
Enter USB burn
Set Addr 6
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
ID[16]
tplcmd[    echo 12345]
12345
[MSG]ret = 0
[info]success
BULKcmd[    low_power]
[info]success
[info]success
[info]success
BULKcmd[reset]
reboot mode: normal
TE: 96177
set vcck to 1070 mv
CPU clk: 1200MHz
Skip usb!
0.0;
TE: 2783560
BL2 Built : 16:43:57, Apr  3 2019. gxl gf3484f5 - luan.yuan@droid15-sz
set vcck to 1120 mv
Board ID = 3
CPU clk: 1200MHz
BL2 USB
DQS-corr enabled
bist_test rank: 0 22 00 44 2d 0d 4d 1f 00 3f 32 14 50 21 00 43 30 10 50 1e 00 3c 30 12 4f 725   - PASS
Rank0: 1024MB-2T-11
New fip structure!
Load bl31 from USB, src: 0x00020000, des: 0x05100000, size: 0x0002b400, part: 0
Load bl33 from USB, src: 0x0004c000, des: 0x01000000, size: 0x00083200, part: 0
NOTICE:  BL3-1: v1.0(release):7864fbc
NOTICE:  BL3-1: Built : 17:15:18, Mar  5 2019
NOTICE:  BL3-1: BL33 decompress pass
dmc sec lock
OPS=0xc1
[3.537639 Inits done]
secure task start!
high task start!
low task start!
U-Boot 2015.01-gabeeb4952b-dirty (Apr 25 2021 - 21:29:24)
DRAM:  1 GiB
Relocation Offset is: 36e78000
mmu cfg end: 0x40000000
[MSG]MMC init in usb
aml_priv->desc_buf = 0x0000000033e78640
aml_priv->desc_buf = 0x0000000033e7a980
InUsbBurn
[MSG]sof
Set Addr 8
Get DT cfg
Get DT cfg
Get DT cfg
set CFG
ID[16]
tplcmd[    echo 12345]
12345
[MSG]ret = 0
[info]success
BULKcmd[    low_power]
[info]success
ID[16]
tplcmd[    download mem dtb normal 120832]
[MSG]Down(mem) part(dtb) sz(0x1d800) fmt(normal)
[MSG]totalSlotNum = 0, nextWriteBackSlot 2
[info]success
[MSG]Burn Start...
[MSG]load dt.img to 0x0000000001000000, sz=0x1d800
[MSG]Burn complete
BULKcmd[download get_status]
[info]success
BULKcmd[disk_initial 1]
      Multi dtb detected
      Support 2 dtbs.
        aml_dt soc: gxl platform: p211 variant: 1g
        dtb 0 soc: gxl   plat: p211   vari: 1g
        dtb 1 soc: gxlx   plat: p261   vari: 1g
      Find match dtb: 0
start dts,buffer=0000000001000000,dt_addr=0000000001000800
get_partition_from_dts() 92: ret 0
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
parts: 17
00:      logo   0000000001000000 1
01:  recovery   0000000001800000 1
02:      misc   0000000000800000 1
03:      dtbo   0000000000800000 1
04:  cri_data   0000000000800000 2
05:     param   0000000001000000 2
06:      boot   0000000001000000 1
set has_boot_slot = 0
07:       rsv   0000000001000000 1
08:  metadata   0000000001000000 1
09:    vbmeta   0000000000200000 1
10:       tee   0000000002000000 1
11:    vendor   000000000fa00000 1
12:       odm   0000000008000000 1
13:    system   000000003e800000 1
14:   product   0000000008000000 1
15:     cache   0000000046000000 2
16:      data   ffffffffffffffff 4
co-phase 0x2, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x3ff2800
emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x3ff2800
co-phase 0x2, tx-dly 0, clock 40000000
init_part() 297: PART_TYPE_AML
_cmp_iptbl()-620: partition count is not same 20:16
mmc_device_init()-1354: update rsv with dtb!
check pattern failed,need to write
several 0x55aa55aa pattern blocks write OK
crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!!
check magic failed,need to write
several 0xff00ff pattern blocks write OK
crc32_s:0x8b2a7ae8 == storage crc_pattern:0xee152b83!!!
check random failed,need to write
several 0x52414e44 pattern blocks write OK
crc32_s:0x8b2a7ae8 == storage crc_pattern:0x79f50f07!!!
XXXXXXX======enter EMMC boot======XXXXXX
switch to partitions #0, OK
mmc1(part 0) is current device
Device: SDIO Port C
Manufacturer ID: 70
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: (0x1c8000000 Bytes) 7.1 GiB
mmc clock: 40000000
Bus Width: 8-bit
[store]amlmmc erase 1emmckey_is_protected(): protect
start = 0,end = 57343
start = 221184,end = 14942207
Erasing blocks 0 to 8192 @ boot0
start = 0,end = 8191
Erasing blocks 0 to 8192 @ boot1
[MSG]usb producing env_relocate
mmc env offset: 0x4d400000
*** Warning - bad CRC, using default environment
Saving Environment to aml-storage...
Writing to MMC(1)... done
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
[MSG]to erase ddr parameters
[info]success
ID[16]
tplcmd[download store _aml_dtb normal 120832]
[MSG]Down(store) part(_aml_dtb) sz(0x1d800) fmt(normal)
[info]success
[MSG]Burn Start...
[MSG]optimus_download_dtb_image:dataSzReceived=0x1d800
start erase dtb......
dev # 1,  , several blocks erased OK
[store]To run cmd[emmc dtb_write 0x0000000007700000 0x40000]
dtb_write()-3737: valid 0
dtb_write()-3757: new stamp 0, checksum 0x283e0ce2, version 1, magic A~D
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
start dts,buffer=0000000033e86d30,dt_addr=0000000033e87530
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
start dts,buffer=0000000007700000,dt_addr=0000000007700800
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
parts: 17
partition table success
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum 278cdd8078f826cdd9f5578222e6d5379670ca3e]
[store]To run cmd[emmc dtb_read 0x0000000007700000 0x40000]
dtb_read_shortcut()-3534: short cut in...
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store boot normal 9977856]
[MSG]flash LOGIC partCap 0x1000000B
[MSG]Down(store) part(boot) sz(0x984000) fmt(normal)
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum e07f698acb22c210c708f387ec1f377ca3008a84]
[MSG]Verify Start...
[MSG]To verify part boot in fmt normal
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store dtbo normal 438]
[MSG]flash LOGIC partCap 0x800000B
[MSG]Down(store) part(dtbo) sz(0x1b6) fmt(normal)
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum 7e63f51086267cbfc7ea71d55d89d967a9d2916a]
[MSG]To verify part dtbo in fmt normal
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store logo normal 5048640]
[MSG]Down(store) part(logo) sz(0x4d0940) fmt(normal)
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum 1abddad2fa6742ed3a15dd50ca046983df124b62]
[MSG]To verify part logo in fmt normal
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store odm sparse 573516]
[MSG]flash LOGIC partCap 0x8000000B
[MSG]Down(store) part(odm) sz(0x8c04c) fmt(sparse)
[MSG]totalSlotNum = 0, nextWriteBackSlot 9
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum 1492468e470f27363a93dd70fec61c7b389366dc]
[MSG]To verify part odm in fmt sparse
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store product sparse 11673676]
[MSG]Down(store) part(product) sz(0xb2204c) fmt(sparse)
[MSG]totalSlotNum = 0, nextWriteBackSlot 179
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum 0089d662ae864972ff9886cb1cab6ea3e14c7fd1]
[MSG]To verify part product in fmt sparse
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store recovery normal 16738304]
[MSG]flash LOGIC partCap 0x1800000B
[MSG]Down(store) part(recovery) sz(0xff6800) fmt(normal)
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum d6064110e87d325b882e17fe8a88f29e51e57de4]
[MSG]To verify part recovery in fmt normal
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store system sparse 970301636]
[MSG]flash LOGIC partCap 0x3e800000B
[MSG]Down(store) part(system) sz(0x39d5a0c4) fmt(sparse)
[MSG]totalSlotNum = 0, nextWriteBackSlot 1024
[info]success
[MSG]Burn Start...
[MSG]Burn complete
Downloading %100
[info]success
BULKcmd[verify sha1sum 2d39562a66a3da48f8dbb314b32298234bae4ba8]
[MSG]To verify part system in fmt sparse
[MSG]Verify End
[MSG]VERIFY OK
[info]success
[WRN]total 0x200 < tranferred 0x400
ID[16]
tplcmd[download store vbmeta normal 4096]
[MSG]flash LOGIC partCap 0x200000B
[MSG]Down(store) part(vbmeta) sz(0x1000) fmt(normal)
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum ebc223238e8f93d5bb549a7db978aac490db19bc]
[MSG]To verify part vbmeta in fmt normal
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store vendor sparse 235589756]
[MSG]flash LOGIC partCap 0xfa00000B
[MSG]Down(store) part(vendor) sz(0xe0ad07c) fmt(sparse)
[info]success
[MSG]Burn Start...
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum 8dfac62f1ee3887506858f99146aeb9f8b7074c1]
[MSG]To verify part vendor in fmt sparse
[MSG]Verify End
[MSG]VERIFY OK
[info]success
ID[16]
tplcmd[download store bootloader normal 851968]
[MSG]Down(store) part(bootloader) sz(0xd0000) fmt(normal)
[MSG]totalSlotNum = 0, nextWriteBackSlot 13
[info]success
[MSG]Burn Start...
amlmmc_write_bootloader() 573: map 0x7
Wrting blocks 1 to 1664 @ user
Wrting blocks 1 to 1664 @ boot0
boot_info.rsv_base_addr :       12000
boot_info.ddr.addr      :       4000
boot_info.ddr.size      :       0004
boot_info.version       :       0001
boot_info.checksum      :       16005
Wrting blocks 1 to 1664 @ boot1
[MSG]Burn complete
[info]success
BULKcmd[verify sha1sum d9fe7070161a203b948de8f8e03d0393904446ed]
[MSG]VERIFY OK
[info]success
BULKcmd[save_setting]
## save_setting ##
[MSG]Set upgrade_step to 2
[info]success
BULKcmd[burn_complete 3]
[MSG]Pls un-plug USB line to poweroff
[info]success
The new IMG start log:
TE: 115608
set vcck to 1120 mv
Board ID = 3
CPU clk: 1200MHz
DQS-corr enabled
bist_test rank: 0 23 01 45 2d 0d 4d 1f 00 3f 32 14 50 21 00 42 30 11 50 1e 00 3c 30 11 50 725   - PASS
Rank0: 1024MB-2T-11
AddrBus test pass!
eMMC boot @ 0
sw8 s
emmc switch 3 ok
emmc switch 0 ok
New fip structure!
Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x0002b400, part: 0
Load bl33 from eMMC, src: 0x0004c200, des: 0x01000000, size: 0x00083200, part: 0
dmc sec lock
OPS=0xc1
[0.565003 Inits done]
secure task start!
high task start!
low task start!
DRAM:  1 GiB
register usb cfg[0][1] = 0000000037f4f2b0
[CANVAS]canvas init
reset failed
MMC:   aml_priv->desc_buf = 0x0000000033e786b0
aml_priv->desc_buf = 0x0000000033e7a9f0
emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x1ff2800
emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x1ff2800
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
start dts,buffer=0000000033e7d240,dt_addr=0000000033e7da40
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
parts: 17
crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!!
crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!!
In:    serial
Out:   serial
Err:   serial
aml log : internal sys error!
reboot_mode=cold_boot
_verify_dtb_checksum()-3476: calc 283e0ce2, store 283e0ce2
dtb_read()-3691: total valid 2
update_old_dtb()-3672: do nothing
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
vpu: error: invalid vpu
vpp: vpp_init
No dtb matched!
No, dtb has been installed successfully. Disconnect the uart connection and try to boot into Android. See if the bootloader logo appears on the TV
unfortunately,nothing appears on the screen.
Please run “store init 3” and install only the uboot, the dtb, and the kernel. See if the kernel is loaded. Probably the emmc capacity for android 9 is not sufficient.
fatload usb 0 ${loadaddr} bootloader.PARTITION
store rom_write ${loadaddr} 0 100000
usb 0 ${loadaddr} _aml_dtb.PARTITION
store dtb write ${loadaddr}
usb_update boot boot.PARTITION
Should I flash back to the original img or enter the command directly?
gxl_p211_v1#store init 3
Device: SDIO Port C
Manufacturer ID: 70
OEM: 100
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
mmc clock: 40000000
Bus Width: 8-bit
[store]amlmmc erase 1emmckey_is_protected : protect
Caution! Your devices Erase group is 0x400
The erase range would be change to 0x36000~0xe3ffff
start = 221184,end = 14942206
(Re)start USB...
USB XHCI 1.00
gxl_p211_v1#fatload usb 0 ${loadaddr} bootloader.PARTITION
reading bootloader.PARTITION
868352 bytes read in 470 ms (1.8 MiB/s)
gxl_p211_v1#store rom_write ${loadaddr} 0 100000
gxl_p211_v1#usb 0 ${loadaddr} _aml_dtb.PARTITION
Usage:
gxl_p211_v1#usb device0 ${loadaddr} _aml_dtb.PARTITION
USB device 0: Vendor: Kingston Rev:  Prod: DataTraveler 3.0
gxl_p211_v1#usb device 0 ${loadaddr} _aml_dtb.PARTITION
gxl_p211_v1#fatload usb 0 ${loadaddr} _aml_dtb.PARTITION
reading _aml_dtb.PARTITION
120832 bytes read in 81 ms (1.4 MiB/s)
gxl_p211_v1#store dtb write ${loadaddr}
[store]To run cmd[emmc dtb_write 1080000 0x40000]
dtb_write()-1140: valid 2
dtb_write()-1160: new stamp 1, checksum 0xba7dd51c, version 1, magic A~D
dtb magic 5f4c4d41
      Multi dtb detected
      Support 2 dtbs.
        dtb 0 soc: gxl   plat: p261   vari: 1g
        dtb 1 soc: gxl   plat: p271   vari: 1g
      Not match any dtb.
start dts,buffer=0000000001080000,dt_addr=0000000001080000
check_valid_dts: FDT_ERR_BADMAGIC
gxl_p211_v1#usb_update boot boot.PARTITION
usb_start_count 0
(Re)start USB...
USB XHCI 1.00
[fat]Filesize is 0x795f9fB[7M]
[MSG]flash LOGIC partCap 0x2000000B
[MSG]Down(store) part(boot) sz(0x795f9f) fmt(normal)
[MSG]Burn Start...
[fat]0x:leftSz f9f < BPS 1000, gotSz 5f9f
[MSG]Burn complete
BURN boot.PARTITION to part boot OK!
=====>Burn part boot in fmt normal OK<======
gxl_p211_v1#reboot
TE: 100075
set vcck to 1120 mv
Board ID = 3
CPU clk: 1200MHz
DQS-corr enabled
bist_test rank: 0 20 00 41 2d 11 49 1e 00 3d 2f 14 4b 20 00 41 2f 14 4b 1e 00 3c 30 14 4c 725   - PASS
AddrBus test pass!
eMMC boot @ 0
sw8 s
emmc switch 3 ok
emmc switch 0 ok
New fip structure!
sha fail.
sha fail.
gxl_p211_v1#
Device: SDIO Port C
Manufacturer ID: 70
OEM: 100
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
mmc clock: 40000000
Bus Width: 8-bit
** Bad device usb 0 **
(Re)start USB...
USB XHCI 1.00
851968 bytes read in 465 ms (1.7 MiB/s)
Usage:
Unknown command 'usb' - try 'help'
(Re)start USB...
USB XHCI 1.00
dtb_write()-1160: new stamp 1, checksum 0xf6dc45ff, version 1, magic A~D
dtb magic 5f4c4d41
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
start dts,buffer=0000000001080000,dt_addr=000000000108f000
dtb magic 5f4c4d41
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 1
parts: 17
_cmp_iptbl()-599: partition count is not same 20:16
mmc_device_init()-1115: update rsv with dtb!
usb_start_count 0
(Re)start USB...
USB XHCI 1.00
[fat]Filesize is 0x984000B[9M]
[MSG]Burn Start...
[MSG]Burn complete
gxl_p211_v1#reboot
TE: 104253
set vcck to 1120 mv
Board ID = 3
CPU clk: 1200MHz
DQS-corr enabled
bist_test rank: 0 21 00 42 2d 0d 4d 1f 00 3e 31 13 4f 21 00 42 30 11 50 1e 00 3c 30 11 4f 725   - PASS
Rank0: 1024MB-2T-11
AddrBus test pass!
eMMC boot @ 0
sw8 s
emmc switch 3 ok
emmc switch 0 ok
New fip structure!
dmc sec lock
OPS=0xc1
[0.554730 Inits done]
secure task start!
high task start!
low task start!
DRAM:  1 GiB
[CANVAS]canvas init
reset failed
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
parts: 17
In:    serial
Out:   serial
Err:   serial
reboot_mode=normal
_verify_dtb_checksum()-3476: calc f6dc45ff, store f6dc45ff
      Multi dtb detected
      Support 2 dtbs.
      Find match dtb: 0
vpp: vpp_init
gxl_p211_v1#store disprotect key
[store]disprotect key
Device: SDIO Port C
Manufacturer ID: 70
OEM: 100
Rd Block Len: 512
MMC version 5.0
High Capacity: Yes
Capacity: 7.1 GiB
mmc clock: 40000000
Bus Width: 8-bit
[store]amlmmc key
emmc disprotect key
[store]amlmmc erase 1emmckey_is_protected : disprotect
 blkcnt = 14942208
start = 0,end = 14942207
(Re)start USB...
USB XHCI 1.00
Usage:
usb_start_count 0
(Re)start USB...
USB XHCI 1.00
[MSG]Burn Start...
[MSG]Burn complete
gxl_p211_v1#reboot
TE: 97780
set vcck to 1120 mv
Board ID = 3
CPU clk: 1200MHz
DQS-corr enabled
bist_test rank: 0 21 00 42 2c 0d 4c 1f 00 3e 31 13 4f 20 00 41 30 11 4f 1e 00 3d 31 12 50 725   - PASS
Rank0: 1024MB-2T-11
AddrBus test pass!
eMMC boot @ 0
sw8 s
emmc switch 3 ok
emmc switch 0 ok
New fip structure!
dmc sec lock
OPS=0xc1
[0.548735 Inits done]
secure task start!
high task start!
low task start!
DRAM:  1 GiB
[CANVAS]canvas init
reset failed
      Cannot find legal dtb!
start dts,buffer=0000000033e7d240,dt_addr=0000000033e7d240
get_partition_from_dts() 92: ret -9
get_partition_from_dts() 95: ret -9
get_ptbl_from_dtb()-272: get partition table from dts faild
mmc_device_init()-1320: get partition table from dtb failed
get_ptbl_rsv()-494: magic faild MPT,
mmc_device_init()-1347: dtb&rsv are not exist, no LPT source
get partition info failed !!
Using default environment
In:    serial
Out:   serial
Err:   serial
reboot_mode=normal
_verify_dtb_checksum()-3476: calc 0, store 0
update_dtb_info()-3584: cpy 1 is not valid
update_dtb_info()-3584: cpy 0 is not valid
dtb_read()-3691: total valid 0
Usage:
emmc dtb_read addr size
emmc dtb_write addr size
emmc erase dtb
emmc erase key
emmc fastboot_read addr size
emmc fastboot_write addr size
[store]Err:do_store_dtb_ops,L425:Fail in fdt check header
board_late_init(): [store dtb read $dtb_mem_addr] fail
load dtb to 1000000
[store]To run cmd[emmc dtb_read 1000000 0x40000]
Usage:
emmc erase dtb
emmc erase key
board_late_init(): store dtb read 1000000 fail
vpp: vpp_init
The kernel couldn’t load.
