today I came to play on my device Dune HD Homatics Box R 4K Plus, but when the CE started the gui became like video. I did format the hd that CE was in and I installed it again but same problem.
FYI, I can play and movies dv, hdr and sdr no issue with PQ just the problem same with the video.
@Damas007
I have seen that on Nokia 8010 (with latest Android 12 update) and it has to do with Android HDR settings. IIRC setting HDR to Auto resolves this effect…
When 8010 boots to Android and first a HDR sign appears on black screen followed with a Dolby Vision sign, this effect will happen. If HDR is set to Auto there are no HDR/DV signs while booting Android, and there is no such effect then booting CE…
