I have a clean installation of CoreELEC 9.2.3 on a Meccol KM8. I have tried SSH (Putty / FileZilla) connections several times and always get an error (user authentication failure). Now I have a clean installation without any changes to the settings. I follow this procedure: https://kodi.wiki/view/SFTP#Windows_SSH_using_PuTTY
I apologize for the late response. I’m still solving an SSH connection issue. If I try to connect using SSH, I get this error from FileZilla:
|Error:|Authentication failed.| |—|---| |Error:|Critical error: Could not connect to server|
SSH is turned on and I have a password set, of course. Internet connection is realized by cable straight to the router (Asus RT-N18U). Disabling the firewall in the router and antivirus program has no effect.
I assume you are trying to connect to CoreElec from your PC with FileZilla. Can you connect your PC via any terminal? Try with Putty terminal to SSH to your box to check username/password.
Btw, which username/password are you using, default or your own?
I tried PuTTY and KiTTY with the same result. I have set my own passwords.
BTW Yes, I trying connect to CoreELEC from my computer (connect to the network using cable) a notebook (connect to the network using WiFi).
