Hi. Please understand me if I write bad english.
when I used 8.90.4, if I set ‘disable deinterlacing’, not happened this problem.
but 8.90.5 is ineffective this way.
My android box is m8s pro l.
Thank you for reading this post and please help me.!
1920x1080i means interlaced.
THX. I’ll fix this issue in next release. For now disable CoreElec option 'Disable deinterlacing and use @anon88919003 command.
The problem still exists on my x96mini box with CE 8.95.4.3
Doesn’t matter if I use Tvheadend with Astrometa USB TV DVB-C stick (which runs extremly good), or DVBViewer Client with Recording-Service as server (with DVB-C and S2 cards)
The most 1920x1080i (DVB-C and DVB-S2) channels have that red line problem. Somtimes directly, somtimes after a while.
I did the “echo 1 > /sys/module/di/parameters/bypass_all” trick, put it in autostart.sh, with no effect.
If I remember correctly the deinterlacing trick in autostart.sh does not work any longer because something else keeps modifying the value after startup. Change it manually in settings instead.
