Was wondering why you could read it and found the desktop version of webpage of Imgur displays the image in a higher resolution. Well, new thing learnt
The board has 4 ram chips on each side (8 in total) so you need to double that, and itās 4GB in total
Am I too slow with editing, or you too fast with replying? ![]()
Already revised. But looks like the chip crisis continues, and still a hit and miss with these cheap boxesā¦
Yeah, users that want best experience and no hit and miss chip lottery better go with branded boxes like BeeLink
Thanks I was trying to figure out that logo and the mac address isnā t found. Yes reading on Armbian about this chip seems bad. I quess this doesnāt help drv: net: phy: add JLSemi jl2xxx driver Ā· unifreq/linux-5.15.y@17deb8c Ā· GitHub
Yours dont even have a ethernet PHY. Does 1000Mbps ethernet even work? Or is it 100Mbps since 100Mbps PHY is included in S905X4?
Edit: the 6334Q in the white label on board is different from ours and might suggest main component/firmware difference
I think mine is x4s 100mb/s at least ah224 is 100mb, aliexpr*** vendor specs is 100mbs
I will create another generic dtbs tomorrow with 100mbit internal phy as yours donāt have a external 1gbit one.
FYI⦠With todays update, all of my videos play perfectly, including the VC-1 video codec⦠The skipped frame on āBack to the Futureā is caused by the screen capture. The live TV stream in 480i plays perfectly, also. Actually, the picture is pretty good.
Great job⦠Thanks
BTW, I am using TVheadend DVR for my LIve and recorded TV using my HDHomeRun tuners. Using Edit4everās Kodi addon, I can get 14 days of guide data.,
Replying to my own post, I added that JLSemi driver to the build system but things arenāt improved. I als o tried as as .ko and I guess it loads
[ 175.291379@0]- jl2xxx: module license āunspecifiedā taints kernel.
but no luck. Granted I donāt know what I am doing.
Since you seem to have a number of these boxes, I thought Iād ask what performance improvements you are seeing above S905X3 boxes? Iām not asking about benchmarks, just subjective things like fluidity of response in menu navigation and the like.
That is a very good question. I have not been really comparing the two systems, since I have been playing with the HK1 exclusively.
Right now, there is issue with a closed caption not displaying properly on this new hk1 device. Tomorrow I will be comparing with the b-link which is running the X3 SoC.
But right now, I am very impressed with the X4.
I know that did not answer your question, but I plan on doing some evaluations down the road for performance.
First time post. Greetings all. Looking into going the coreelec route for high quality audio and video playback. Looking over this thread, device looks promising.
Can someone please confirm s/pdif works and plays audio straight from device to avr with coreelec, would be greatly appreciated. Only test Iāve seen so far is s/pdif from tv connected via hdmi rather than straight from the HK1.
Cheers
Chris
At this point I am not as positive on the this device as @clarkss12. If you want CoreElec a dedicated Amlogic SBC makes more sense to me. Maybe if recovery firmware is available and if you could install to emmc a 4GB 64B machine is definitely reasonably price but at this point neither is guaranteed. From the Android side it is definitely inferior to cheap Android TV devices that have Widevine L1 and support Dolby audio.
Anyway I was not able to get audio out of the a/v jack but it might need a different plug. Testing s/pdif I couldnāt get audio in Android or CE.
Thanks for testing. Ouch, so spdif is a no show with current testing? Could clarkss12 test from his system?
If I were to go another device, would the Minix Neo T5 be fully supported? I had a quick look and only the latest model from Minix had a dedicated device tree/CE image. The T5 fits my price range, Iām only interested in 4K video along with ability to pass non-video hi res audio via toslink.
Cheers for the help.
Been years since I used the s/pdif, so would have to dig through my misc. cables to find one⦠If I get the motivation to test it, it maybe awhile⦠Too hard for this old man to climb around, and behind, the entertainment centerā¦
I guess it all depends on what you use it for. I have most of the Google Certified boxes/sticks, including the 2017 Nvidia Shield. But, NONE of my devices support all the audio and video codecs. My shield does NOT support Dolby Vision, but does passthrough all of the HD audio codecs. The TiVo Stream 4k passes through the Dolby Vision, but NOT any of the HD audio codecs.
So what is the use of having a 4K TV that supports Dolby Vision and all of the other HDR and HDR +. And an audio receiver that supports all of the audio codecs, if you donāt have a player that uses those functionsā¦
Besides, my Kodi data is more than 6 gigs, so NONE Of these Official streamers have enough internal storage to install Kodi.
Right now, this HK1 is getting closer to MY holy grail (for my purposes). Of course, most people want a media streamer for their online content. I think having ones own media is dying.
That is just my 2cents.
Weāre only starting this journey, spdif doesnāt work now but can be added later, depending on the device. Itās to early to call.
Then this is good news for you ![]()
