I was reading that a couple of days ago. But, from what I understood, it will only be available in China.
Agreed and I appreciate all the work the CE team has done so far. I am very excited about these new family of devices for CE and moving to new kernels, even if it means my N2 workhorse will die on the newer kernel.
Right now thereâs no clear path for the N2/N2+ and the others. Donât kill it too quicky.
The new Beelink GT-King II will be an awesome machine for dual booting.
The CoreELEC team has worked miracles getting the new Amlogic SoCâs to work with CoreELEC.
Great job!!!
No problem. Will wait and see what comes of this little unit. Appreciate yours and otherâs efforts so far. Hopefully spdif gets support down the line.
A friend of mine who lives an age away from me has this HK1, he turned me onto this device. A few hours ago I convinced him to try spdif to a receiver.
I can confirm spdif works at least from the android OS on his box.
Heâs not interested in CE Kodi so thatâs as far as his help will go unfortunately.
So I have here new dtbs to test.
All for 2g/4g and 100mbit/1gbit. I also changed the gpio of the spdif output so it might working now as well. Please test and report which device does work with what dtb and what functions are working or not working now. spdif, eth LAN, WLAN, USB, uSD,âŚ
sc2_s905x4_2g.dtb (85.3 KB)
sc2_s905x4_2g_1gbit.dtb (85.4 KB)
sc2_s905x4_4g.dtb (85.3 KB)
sc2_s905x4_4g_1gbit.dtb (85.4 KB)
Convinced my friend to test coreelec spdif. He noted that it indeed works with sc2_s905x4_4g_1gbit.dtb. He did a quick test of some hi res audio I shared for him and found that it passed 96khz but it was stuck at 16bit instead of 24 on his receiver. Wav files and flac files, so passthrough and lpcm decode stuck at 16bit.
He canât test video surround sound as his receiver is 2.0.
As for LAN, his works on android but said the menu switch to turn it on in CE doesnât go into the on position. Looks like another with LAN issue.
He has the gigabit model.
Hope this helps.
I tried the two 4g dtbs and neither worked. There is a slight difference since the light on the switch stays on with the 100Mb version even when Kodi has no networking. Also I couldnât add my hub eth1 while the eth0 cable was connected.
with the 1000Mb version like before it goes off duing boot and I get
meson6-dwmac fdc00000.ethernet: no reset control found
Hello, please could you recommend me some good CE supported box with S905X4 (eg. from Aliexpress) with 1GBit network. I want to build a small ultra low power NAS for one USB HDD with 4K Kodi and HDMI CEC support and I think this platform might be perfect for me. Thanks for the advice.
Hello world !!!
This DTB sc2_s905x4_4g.dtb works on transpeed x4s
IMG generic nightly 06/09
Used reboot update method, Will try other methods.
Eth & wlan world
Remote not working
Not working device front panel only works bluelight
Tested this new DTB >> [sc2_s905x4_4g_1gbit.dtb.
LAN works perfectly:: tested on a 75 Mb/s videoâŚ
WiFi:: Router about 30â direct line of sight.
WiFi 2.4 Ghz, will NOT play UHD or HD videos
WiFi 5Ghz will NOT play UHD videos, But WILL play HD videos.
Under Android, WiFi performance is the same
All USB ports show 5volts.
Did not test the Spdif output.
This DTB and the prior one that I used, powers the device back on after a power offâŚ
ExcellentâŚ
I tried with people sleeping and didnt check soundđ
Works fine, problem was a wizard
Question to the CE team. I know android has a limitation of 16bit audio, with USB allowing 24. is it even possible for CE to achieve 24bit audio via Hdmi and spdif toslink with Kodi?
24 bit is obviously really important to audio, will look into other methods of playback if it isnât possible for CE to achieve it.
Thanks all.
Anybody know if booting from emmc is supported on the Vim4?
Hi. So do we have a stable version for HK1 Box?
If you mean stable as âofficial stableâ thereâs no ETA. And it wonât ever be stable if thereâs only a few testing with nightlies.
Stable is relative but overall CE works as expected. Given that I have a NK1 that doesnât have the supported wired networking chip and I couldnât get sdpif or analog working (both work on Android) then there is work to be done, but I didnât find any major show stopper with my use case which is PVR except perhaps black screens changing video that I am not used to. I can run my server (NextPVR) and clients fine and the extra RAM and ROM are nice but it is not faster than an N2.
Considerations for me for a decision in the future if this is the future of CE.
- I need some features for PVR hat arenât in kernel 4.9 to get /dev/dvb support via USB that work in LE20 for Amlogic
- no recovery image from Susay if I want to try emmc
Without these Iâd just stick with the excellent devices SBC devices the have full support know.
For experimenters no Armbian Amlogic or LE 20 builds yet.
For me there is no redeeming value to the Android on this box. Some might like Kodi for Android with more memory but that has nothing to do with CE.
@clarkss12 when you posted about âDolby Visionâ support earlier did you only try on a HDR monitor? I decided to test some DV files from https://www.demolandia.net/4k-video-test/dolby-vision.html and they all play with the awful colour that I expect when the player doesnât output properly from CE or Android.
