My RockTek G2 received an Android update today. They added the restart on long power like many other boxes have, which makes going back to CE much easier.
As normally happens after a firmware update, adb had to re-enabled and I had to do the adb reboot update to get CE but all seems fine.
Ok, but you should know that unfortunately 4K HDR does not work at the moment, so after upgrading to Android 5.4.210 kernel, CoreELEC only works properly up to 1080p resolution, 4K HDR does not work these “Homatics” boxes.
Just built and installed the update and h265 playback and DolbyVision are working again. DV colours on samples look much better than I remember too on my normal 1080p monitor.
Thank @vpeter, @Portisch and everyone involved in getting this working
