I have the Rock Tek G2 and everything thing in Coreelec works but Dts Ma and Dts x. All settings are correct but all i get is the Dts core. Any ideas? Or is it not supported yet?
Well i found out what was the problem with dts x but i could never get Bluetooth to work with this. It sees it as B25 and it pairs but none of the buttons will do anything.
Try pressing pair buttons again to re-pair.
I saw some posts on the Homatics board so I thought Iād show the G2. It looks like adding an IR remote would be a nuisance with the mess in front of it. USB HID an RF work so I am ok with that. Not sure if the MOSFET is on this side.
No, the USB power switch is on backside, near the USB ports.
