I have a Nexbox A95X-A7N S905H working great with 9.2.1 image.
The problem is that I can not power on the device with original remote. I need to unplug and plug again the DC power.
Is there any configuration that I could test?
Thanks for your help.
Regards.
Thanks @kostaman.
So there is not solution for it. I will leave it powered on and configure the remote to power on/off the TV with CEC.
If someone find a fix for power on the box, reply here please.
Regards.
I’ve PM’d you a link for Android Rom with fixed uboot with proper on off.
