As I wrote yes, but I am on sick leave quite a long time, so I cannot go outside buy thermal pads/square alluminium stick…
Meanwhile, I am testing VIM3L family, which comes with interesting findings. I think I will create “Temperature related” thread, because content is a bit offtopic with VIM3L (although SOC are very simmiliar). And will get back to this one, when I will be cured and will have some more results regarding X96 Air heatsink improvements (DIY for few bucks)…
Can you take a pictures inside the box?
I’m thinking to buy some small heatsink like this
what measure you advise use for gpu, cpu and other components?
Idle temperature seems to stop around 38°C after 20min idle, ondemand governor…When playing movies/browsing menu Ive got top 45°C. Thats looks much better for me and box is practically ready for deploy, considering running nightly. At least temperature-wise looks promising (hoping for values similiar to VIM3L+DYI plate@nightly)
I also cut other heatsink, so I have two more pieces for next X96 ordered.
Today I cut a hole the size of the label on the underside of the case.
Turned the device upside down.
Edited the vfd.conf file to both reverse the digits and to turn them upside down also, so the time/temp shows correctly with the device upside down.
Playing a UHD Satellite channel into a FHD monitor (as before) the temp maxes out at 65 C.
My intention is to find a heatsink soon to replace that metal plate that is fitted by default in the device with a better cooler, and I am expecting the max temp to drop to 60 C.
That is my aim … to get the temp during this test to 60 C or below.
It appears I am on the way …
To reverse the order of the digits change the line
vfd_chars=‘4,0,1,2,3’
to
vfd_chars=‘4,3,2,1,0’
Note: The first number (4) does not change - it is colon.
The other four are put in in reverse sequence.
.# 0x01 in first position to put display upside down
vfd_display_type=‘0x01,0x00,0x01,0x00’
The exact entries will likely be different for different displays/boxes.
Not ‘fixed’ yet ---- today’s nightly.
It appears the driver for the BT is present ls /lib/modules/4.9.113/RTL8822CS-aml/8822cs.ko
but some firmware file is absent?
Hopefully the analog audio out on the A/V socket gets fixed also.
