I have a MagentaTV Stick and the hardware acceleration doesn’t work there. I’ve tried different codecs/sources.
When I play a video, the picture is black and the sound works at times. Sometimes Kodi also hangs a bit when playing.
With H.264 comes in the log files when playing:
CoreELEC kernel: 0: timeout_process decoder timeout, DPB_STATUS_REG 0xf0
CoreELEC kernel: 0: vh264_work_implement, decode timeout flush dpb
Here are the logs where I reproduce the error with H.264:
http://ix.io/4lF6
The hardware of the Magenta Stick is comparable to the Radxa Zero.
Processor S905Y2 4x 1.8 GHz ARM Cortex-A53
GPU ARM Mali-G31 MP2
RAM 2GB
I have the problem with Coreelec 19 Generic and 20 Generic and the g12a_s905y2_2g.dtb
But I’ve already tested the image for the Radxa Zero and there the same error.
I would like to use hardware acceleration. Can someone tell me why it doesn’t work and maybe even how I can solve it.
Thank you very much
dile
