Using serial console.
Build 2024/09/9 works?
Yes build compiled 2024-09-09 is last working.
I have X96s - dtb g12a_s905y2_4g
this version 2024-09-10 is last working (build date 2024-09-09). version from 2024-09-11 (build date 2024-09-10) and next builds not works.
What was filename of the image which worked and which doesnât?
You posted 4 different dates and I have no idea what you mean.
filename download is CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20240910.tar
this is last working version (build date in CE is 2024-09-09).
same is in new-generation (ng) builds
This now makes more sense. The only change is
I will check DTB if I see anything.
Try nightly build: CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20241011.tar
Itâs solved. Wifi works and BT works and pairs with devices. Thanks
Can you please post dmesg? In SSH console type this after reboot and post url.
dmesg | paste
