Hi, I updated my S912 box to 9.2.6 and have audio issues, all was fine on 9.2.5. I’ll try get logs tomorrow (any guides?).
Basically when I play something it plays the audio for about 1-2 seconds then goes silent, I have to either skip back or if that doesn’t work I have to go to audio settings and change something to cause it to reset (e.g. toggle passthrough on then off again). Once I’ve done one of those work arounds it’s fine again till the next file then does the same again, it’s doing it consistantly though and like I said, never had an issue with 9.2.5. If it matters it’s a Kingbox K3.
