[S922X] Bee-link GT King
This has been discussed in length already. Not planned.
Not happening, if you want internal install then buy an SBC.
UHS-II Supported ?
No. Not supported.
CE wont boot on my GT KING… i power on and hold reset like on other CE versions and all i got is a freezing Beelink Logo
You might have a rev A chip. Try using the rev_a dtb.
ur right its REV A now it works… whats the differnce between rev a and b ?
Basically clocks. Rev A chip is limited to 1.7GHz on the A73 cores. Rev B runs at 2.2GHz.
CE had a bug that locked all devices to 1.8GHz until two days ago, so no one really had any problem until now. Now rev B chips can run at full 2.2GHZ clocks, and rev A will need to use the correct DTB with frequency and voltage adjustments for it.
Have you bought this box recently?
Check the output please to confirm first 4 symbols are 290a
cat /proc/cpuinfo | grep Serial
Does this concern N2 in any way (rev A I suppose) ?
I run my with "max_freq_a73=‘2004’ " and "max_freq_a53=‘1992’ " on 9.0.3. Will anything change for me with new stable version, or if I switch to latest nightly?
Btw, is there a way to see both clock frequencies in “System info -> Hardware” ? At present I see only frequency for a53…
No, this doesn’t affect N2 in any way.
Default frequency is 1.8/1.9 and it can be overclocked to 2.0/2.0.
anybody knows if an DVB Version with S922x is out there or planned?
The Dreambox One is available but it isn’t cheap.
i wait for Mecool K IV PRO XD
I wait to win the Euromillions… I think I have a better odds.
Does the GT King outputs sound on HDMI and SPDIF simultaneously while running CE?
No, it doesn’t.
That’s for sure? Few weeks ago I tested the stable release and it had audio on both, HDMI and SPDIF. Has something changed since then?
Nothing changed, the output needs to be selected in the audio menu in Kodi.
It might work initially after a reboot, but after any changes from PCM to passthrough, one of them won’t work anymore.
