No, nothing like that. ng is 4.9. in the notes some only apply to Libreelec.
Hi all,
I just received my Ugoos AM6B Plus. I installed it on the internal emmc chip but I have a question:
how can I show the video and audio infos regarding the blu-ray I am playing from the BDMV folder? I.e. I would like to see which kind of Dolby Vision profile the box is currently playing. I tried to open the PlayerProcessInfo but it only says “Dolby Vision” without any further information.
Thanks for your precious help!
The info you seek is available only with specially modified skins installed on an unsupported CoreElec version, explained in this topic
Almost had a heart attack when I updated the latest nightly, that Merry Christmas from CoreELEC screen stayed so long on screen I thought it was bricked ![]()
Not sure this is the right place to ask but how do i use the built-in WebDav/ Http/s server from a coreelec gs-king x(the source where media are stored) to access it from a coreelec minix u22-xj max(the client). Reason is ive tried nfs/smb /ftp but very occasional stutters so want to see what http/s if like.
P.S i understand plex uses http so is that same as WebDav/ https?
You set it up via File Manager → Add network location. Use WebDav http/80, as https/443 needs certificate.
C/P
When entering a source path through the GUI, be sure to include the dav: to start the address.
dav://username:password@server/share/
Thanks can you give a fake example of the address for e.g is the @server the ip address of the source?
I connect to my cloud via https/443 like this:
WebDAV URL: https://dav.mycloud_name.com/
WebDAV Login: My_FunnyName
WebDAV Password: My_unbreakable password
Still can’t get this to work, @vpeter any help please, is it doable so i use one CE device (Gskx) as a WebDav/ http server to serve to another’s ce device (minix s922x) as a client, thanks
Kodi has only some simple webserver: https://kodi.wiki/view/Webserver
Try docker with nginx or some other web server.
I’ve just ordered Ugoos AM6b+ but confused whether coreelec can be installed directly onto emmc, some people say you can and some say you can’t.
you can install to emmc.
How if is encrypted uboot by Ugoos?
Thats good to hear ! Any guides as one on here is just for dual-boot.
It has to be dual boot. But once you have CE on EMMC you’ll never see Android unless you decide to boot to it from inside CE.
Thank you, that makes sense
How can i remove shortcuts on the homescreen of ugoos?
install Projectivity Launcher
Via playstore? Or where? It says not for use for my setup via playstore?
try to sideoload it then if you can’t flash to slimBOXtv firmware which uses Android TV apps.
