Works fine here. Which CE version are you running? For FEL support you should install the CE-NG 21.3 stable release.
Seems like my issues was just playing it with the BDMV folders. They worked for most movies, but for some criterion discs just refuses to play in DV. I output it to MKV and they worked great.
I noticed tonight when turning on my TV, that I had a black screen.
I rebooted my AMB6+, saw the jaguar boot logo, and some seconds later there is some text in the upper left saying it failed to mount the flash filesystem. It then stays there indefintely.
This happens on every boot now. I have changed nothing recently, so I presume somehow the filesystem is corrupt (hopefully not a faulty chip).
What should I do in this case? My CE was running from the internal eMMC.
So you try run at sd card. What more to this ?
Quick question: I’m on the nightly, but haven’t had a single update since 21.3 was released/installed. My guess is that there won’t be more nightly releases this year, but i can’t find any info to backup my thesis.
Do you have any info on that?
You should update to CE-NG 21.3 Stable, because it was compiled on Nov-04, which is two days after the latest nightly from Nov-02.
Just download the CoreELEC-Amlogic-ng.arm-21.3-Omega.tar file, put it in the Update folder and reboot.
I have it already. But I noticed i haven’t receive any more updates. I interpret that this 21.3 is now stable. Are there any more nightly on 21.3 programmed for the future? or now we move to 22? We can’t move to 22 i think, since i understand we will lose DV support.
DV will not be lost.
There is no further development on CE-21 planned.
It’s final. Look at XBMC GitHub, no milestone anymore.
You wrote “I’m on the nightly” so I assumed you were on the November 2 version. If you are on the stable from November 4, you have the latest version and no new nightlies will be released anymore, unless maybe the Kodi team releases a 21.3.1 or 21.4 or whatever.
And CE-22 still has DV, but no P7 FEL support due to the lack of the required kernel module (i.e. there is no dovi.ko file with FEL support that works on 5.x kernels).
Kodi Omega is done…
Thank you very much. I was on nightly, so i updated to stable. I guess i will stay on 21.3 from now on.
hi experts. now I xxx up. seems like a seriös problem maybe someone has an idea for me. I found only a 3 year old work around for libreelec that could fit the issue, but probably is something completely different
yesterday my perfectly running am6b+ with the latest stable 21.2 somehow crashed completely, the first time. maybe something with the power cable, not sure. I did not change a setting and I doubt this crash could be possible with a wrong setting. it was freezing then dark then it booted into the standard skin (usually I use zephire reloaded) and most of my settings (if not all) and I think all of my addons were gone. after some try and error attempts I
  1. put the latest tar in the update folder which was not working because of disc space! I realized that I had 20gig of thumbnails from my kodi for next gen addon on my ugoos. I didn’t even know that they were saved locally… of course I deleted them..
  2. the I updated again with the tar, it seemed successful, NEARLY everything is working again. perfect picture no stutter, dv fel is good… but
issue now: I cannot deactivate an addon, I can press it but nothing happens. I cannot install an repo or zip addon. I don’t get an error notification. the repo / addon is just not installing.
of course multiple sources is on and everything related I could find in the addon settings with expert mode on is OK.
I never used an profile, but for me it looks that I’m using one without the authorizations for addons :frowning:
any thoughts? is it possible to destroy something in the ce section (but only a small part) with some physical boot and space issue? or am I blind with a setting?
by the way, in the meantime I installed the tar 3 times without any error. the issue is def not related to the files copied in an update.
and, after the crash before I realized that my emby addon is responsible for the disc space I deleted a lot of addons. is it possible to delete an addon that is managing the addons? not really I guess?
many thanks in advance! happy Friday!
no one an idea why or how my addon section crashed or how to fix it?
What is current status, Still on Default Estuary Skin?.After applying tar file 3 times ,settings can be returned to Default Settings in addons. You are on Expert, so double check You have allowed notifications/unknown sources/,and update official addons is set to Any repositories.
Also delete addons that share Dependencies can cause many errors, with Emby probably.
Also go to settings /Interface, and returned to Arctic Zephyr Skin, if you are not already there,with thus Skin there us option to manage Dependencies
Otherwise maybe is time to move to 21.3 Nov 4,clean install :thinking:
thanks!
I even unchecked the all sources rebooted and checked again. still no change everything works perfect but the addon section.
but indeed I should try it while running the standard skin. Haven’t done that. thanks!!
If I reset ce via ce settings will I be on the version I installed via emmc with my dovi file in place and all that? or what will it be? I’m not sure I can do it again :slight_smile: I’m not so much an it guy that was rocket science for me 1 year ago…
ah and yes I’ve checked dependencies not much there anymore. the required ones are still there
Well ,all you have done is change Skins,correct?Will not effect CoreELEC, just go to Interface in Zephyr and change to Estuary Skin, us Default Kodi/CoreELEC.
Do you have a backup tar file before the crash that you made in CoreELEC settings :thinking:. Go back to that and all addons will be returned.
Maybe try to reload/reset the Arctic Zephyr Skin .
In CoreELEC settings you could try a soft reset I have never tried myself so read what will be lost
Is your issue specific to Emby server binary? If so maybe it is the this issue SQLite package with FTS5 support and you need to get Emby involved.
no not really. i dont know what happened maybe it was the power cable, ce booted in the esturi skin and all my settings and addons were gone. no idea why.
i have an tar backup made via azr / backup addon and i restored it. now everything is perfect (as far as I see) except i cannot install an addon / repo. i click the zip file and nothing happens. i cannot deactivate a running addon i can click deactivate and nothing happens
no emby has nothing to with it. fortunately because that issue sounds so complicated i would rather start from scratch as trying to understand that one :wink: but thanks!!!
Well, your not the first person to have a crash, and had to do clean install, rebuild your CoreELEC.
You could switch to Estuary Skin and submit log?however if you have banned addons forget it.
