I’m trying to create a password protected samba share via SSH but some commands are missing in coreelec like groupadd, useradd.
How can I do that?
Do it from settings…
I need to do this via ssh
You can’t add user into coreelec. But you can edit samba.conf file with terminal ![]()
Why don’t you use coreelec settings ?
No way! ![]()
Care explaining why not?
That was a joke. He’s kind of guy who suggests you to open the hood when you asked about how to fix the engine…
In order to create a password protected samba share I need to create a samba group&user for it.
That’s the problem.
Use coreelec settings is not an option because the box is used as a tvheadend server and accessible only via SSH.
CoreELEC:~ # ls -al /opt/etc/passwd
-rw-r--r-- 1 root root 336 Dec 20 23:33 /opt/etc/passwd
CoreELEC:~ # smbpasswd -a smbuser
New SMB password:
Retype new SMB password:
Failed to add entry for user smbuser.
Samba is not used from entware but it is part of CE and it uses file /etc/passwd which is readonly.
Can I disable the built-in samba and install another from entware?
Disable samba in CoreELEC settings addon under services.
I’m not using Kodi. The box serves as a tvheadend server on the LAN.
Should I disable it from systemd?
Finally solved. Writing here the steps in case someone else needs it.
source: shared folders - password protected samba share - Unix & Linux Stack Exchange
First stop the built-in samba server
# systemctl stop smbd -
install samba4 from entware
# opkg update && opkg install samba4-server -
modify /storage/.config/system.d/smbd.service like below (modify required paths to /storage/.opt/ only)
[Unit]
Description=Samba SMB Daemon
Wants=network-online.target nmbd.service
After=network-online.target nmbd.service
ConditionPathExists=!/storage/.cache/services/samba.disabled
ConditionPathExists=/run/samba/smb.conf
[Service]
Type=forking
PIDFile=/storage/.opt/var/run/samba/smbd.pid
LimitNOFILE=16384
ExecStart=/storage/.opt/sbin/smbd --configfile=/storage/.config/samba.conf
ExecReload=/bin/kill -HUP $MAINPID
TimeoutStopSec=1s
Restart=always
RestartSec=2
StartLimitInterval=0
[Install]
WantedBy=multi-user.target
- edit
/storage/.config/samba.confand create a share
[Private Share]
path=[give here the path to the folder to be shared]
force user = smbuser
force group = smbgroup
create mask = 0664
force create mode = 0664
directory mask = 0775
force directory mode = 0775
writable = yes
Create a system group. I chose smbgroup
# addgroup --system smbgroup -
create a user smbuser, in smbgroup but do not create a home directory, and also deny the ability to log in to the system
# adduser -S -H -G smbgroup -s /bin/false smbuser -
Change the ownership of folder to be shared.
# chown -R smbuser:smbuser [folder path] -
Give write access
# chmod -R g+w [folder path] -
Add samba password to smbuser.
New SMB password:[password]
Retype new SMB password:[password]
- Now restart smbd.
# systemctl restart smbd
Other factors need to be considered for using samba on entware, especially for long term usage.
The most prominent one I found so far is entware has independent setting for folders like /var and /tmp, and if you use them by default they write to your TF card (if CE is running on TF) or internal emmc (if installed internally). Just make a system script and point those folders to CE’s tmpfs instead to reduce wearing.
ln -s /tmp/temp /storage/.kodi/
ln -s /tmp/ /storage/.opt/
ln -s /var/ /storage/.opt/
Doesn’t samba sever in entware has own start scripts? And you should disable samba completely
systemctl mask smbd
