Salesi
10 October 2019 20:56
#1
I had a problem getting to the stream information, the tvbox I use GTMINI-A does not have a remote control kit that offers all the amenities
I decided to modify the skin a bit with an additional button in pvr and vodeo player and add colorful TV genres
git:skin
https://github.com/BlackGlassSkin/skin.estuary
git: colored genres
everyone has to make their own colors
Folder location [skin.estuary/media/epg-genres]
sample ad / Movies.png , Western.png etc…
Salesi
11 October 2019 12:22
#2
I have had a play with this.
I can only get sports to show up. I think the problem, in my english pvr it shows genres as two words, ie Leisure/Hobbies I have tried renaming using / - _ * in the epg folder but have had no luck so.
Salesi
11 October 2019 16:02
#4
are you talking about the colors of the genres?
try
in the same color
I tried renaming the png files in the media folder to Leisure & Hobbies as separate pngs.
I might have another go later.
Salesi
11 October 2019 18:58
#6
what .ini file are you using for webgrab ++
