I got them working on my N2 - but I followed this guide on a different Linux box (a spare Raspberry Pi running a clean version of Raspbian Lite) to create the picons from scratch rather than using a pre-rendered download.
# Ubuntu, Bash on Ubuntu on Windows
sudo apt-get install git binutils pngquant imagemagick librsvg2-bin jq
I built Service Reference Picons and only built the ones that TV Headend had found channels for by following the instructions that require a script to access my N2ās TV Headend server to get a service list.
I then copied them across and pointed TV Headend to the folder they were in (I put them in a subfolder in the picons/TVH/ folder)
OK - sorry I canāt help further. That route worked fine for me - and ensured I got a nice clean match with only the picons I needed for the services I receive - rather than hundreds more for channels I donāt receive. Took me less than 30 minutes from flashing Rasbian to a spare uSD card to having them working - would have been quicker if Iād checked the build dependencies first. (Doing stuff like this is a great way of learning more about Linux, letting you solve problems again in the future)
As Iāve had success with Service Reference Picons rather than Service Name Picons, Iād probably try and find a Service Reference Picon pack for the country you are in, and also ensure you decompress it if it comes as a tar-red file.
So far - following the guide I linked to above Iāve only got one thatās wrong (because the channel recently rebranded) for a London Freeview HD set.
Maybe building from scratch from a service list exported from TV Headend means it works better?
I would say its the only way - but the process looks daunting even for a 10year Linux user who used to have to setup drivers for obscure hardware. I have generally gone down the route of manually setting up my picons from within Kodi - far from ideal but it works.
The guide I posted above was very straight forward to follow and ājust workedā
The two scripts worked nicely (once Iād ensured I had all the dependencies I needed - I should have read the build requirements on GitHub firstā¦) and using the service list from TV Headend (which you configure in the tvheadend.serverconf file where you put the ipaddress and account login/password) means you just get the picons you need.
NB file names may not match as Iāve had a number of different BBC One HD and BBC Two HD sources in my TV Headend setup (Freeview HD, Freesat HD, self-build IP Multicast of Freeview HD etc.)
I have edited the Picon path, not the Channel Picon path, to include a sub-folder as my picons are in a subdirectory of storage/picons/tvh based on the file name of the compressed file I copied over and de-tarred into itās own folder. I think this is a neat way of working as you can have different colours, sizes, types of picons when you are experimenting with which ones you like most, without having to worry about having them all in a single folder.
Unless they have an exact code name or title match they will not be linked to your channels. Since TVH will often find multiple instances of the same channel and then merge them down to one āvirtualā channel you will see that there are many chances for name/code mismatches.
Slight differences in naming will completely throw TVH.
Other commercial media player are much more homogeneous so these issues donāt arise.
Ah - I never enable āmerge channelsā and have gone for Service Reference Picons based on the actual services I receive (rather than selecting Picon just by chancel name) in TVH - that may be why mine all match (bar one because the channel has renamed but still has the same service ref, and the Picon source hasnāt updated presumably)
This is why doing it the way you did is the only way that you can get exact match ups, every picon list has its own unique picon codes designed for a particular media player. Name matching will get you more hits but is still less than 30% successful.
You dont have filled picon path at all⦠For the channel icons path, try file:////storage/picons/tvh/%C.png ⦠it should work just fine for channel images, if you have correct .png presented on the path (case sensitive, with correct file rights).
Btw, its not N2 specific⦠And you can check TVH log during user-tests for possible troubles with rights, fileformat, or caching issues.
How I solved the task of activating the picons for tvheadend in CoreELEC:
1.- My picons are in /storage/.config/picons to be included in CoreELEC backups.
2.- I have downloaded the picons collections for several satellites in /storage/.config/picons/vdr (Astra 19.2E, Hotbird 13.0E and Hellas 39.0E) from https://www.vuplus4k.com/picons-220x132 /, https://github.com/OpenLD, https://github.com/picons/picons/releases ,and other sites. You can also download the collection of icons for Enigma2 in ipk format and open it with 7zip, but it has the problem that there are too many picons (more than 14,000), considering that I only use 387 TV services that finally become 250 channels of TV with different contents, that is, I only need 250 picons.
3.- I have set tvheadend to look for the icons in /storage/.config/picons/vdr.
4.- I have deleted all the picons that are not interesting for me, I have added the missing picons, and I have renamed the picons (with the name that asks tvheadend) that were with another name.
Everything works very well and TVH clients receive the picons from the tvheadhend server at full speed.
