I’m on the 19.3 nightlys:
2022-03-04 19:42:32.501 T:3698 INFO : Starting Kodi (19.3 (19.3.0) Git:6a5726ffa07d25ab7be51b9a92ef4d09aa9b6bc3). Platform: Linux ARM 32-bit
2022-03-04 19:42:32.501 T:3698 INFO : Using Release Kodi x32
2022-03-04 19:42:32.501 T:3698 INFO : Kodi compiled 2022-02-26 by GCC 10.3.0 for Linux ARM 32-bit version 4.9.255 (264703)
2022-03-04 19:42:32.501 T:3698 INFO : Running on Hardkernel ODROID-N2Plus with CoreELEC (official): 19.4-Matrix_nightly_20220226, kernel: Linux ARM 64-bit version 4.9.269
2022-03-04 19:42:32.501 T:3698 INFO : FFmpeg version/source: 4.3.2-Kodi
I’m having an issue where after playing a 5 or 6 channel FLAC audio file successfully, I then get silence when I subsequently play a two channel FLAC file.
My kodi config is for 7.1 audio on HDMI Multi Ch PCM (haven’t changed it).
When playing back a multichannel file:
2022-03-04 19:45:44.672 T:3930 DEBUG <general>: CFileCache::Process - <smb://192.168.0.112/Multimedia/multichannel/The Stranger (SACD 5.1)/07 - She's Always A Woman.flac> cache completely reset for seek to position 83330 2022-03-04 19:45:44.672 T:3921 DEBUG <general>: SeekTime - seek ended up on time 0.000 2022-03-04 19:45:45.087 T:3921 INFO <general>: Skipped 1 duplicate messages.. 2022-03-04 19:45:45.087 T:3921 INFO <general>: AudioDecoder: File is queued 2022-03-04 19:45:45.089 T:3704 INFO <general>: CActiveAESink::OpenSink - initialize sink 2022-03-04 19:45:45.089 T:3704 DEBUG <general>: CActiveAESink::OpenSink - trying to open device ALSA:surround71:CARD=AMLAUGESOUND,DEV=0 2022-03-04 19:45:45.089 T:3704 INFO <general>: CAESinkALSA::Initialize - Configure simple control for "AUGESOUND" 2022-03-04 19:45:45.089 T:3704 INFO <general>: CAESinkALSA - Use card "hw:0" and set codec format "8 CH PCM" 2022-03-04 19:45:45.090 T:3704 INFO <general>: CAESinkALSA - Set codec for "Audio spdif format" 2022-03-04 19:45:45.090 T:3704 INFO <general>: CAESinkALSA - Set codec for "Audio spdif_b format" 2022-03-04 19:45:45.090 T:3704 INFO <general>: CAESinkALSA - Set Spdif to HDMITX to "Spdif" 2022-03-04 19:45:45.090 T:3704 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "surround71:CARD=AMLAUGESOUND,DEV=0" 2022-03-04 19:45:45.095 T:3921 DEBUG <general>: AudioDecoder::GetReplayGain - Final Replaygain applied: 1.000000, Track/Album Gain 89.000000, Peak 1.000000 2022-03-04 19:45:45.096 T:3704 INFO <general>: CAESinkALSA::Initialize - Opened device "surround71:CARD=AMLAUGESOUND,DEV=0" 2022-03-04 19:45:45.098 T:3704 DEBUG <general>: CAESinkALSA::SelectALSAChannelMap - Selected ALSA map "FL FR LFE FC RL RR" 2022-03-04 19:45:45.098 T:3704 INFO <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats 2022-03-04 19:45:45.099 T:3704 INFO <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4 2022-03-04 19:45:45.099 T:3704 DEBUG <general>: CAESinkALSA::InitializeHW - Request: periodSize 4410, bufferSize 17640 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: CAESinkALSA::InitializeHW - Got: periodSize 4410, bufferSize 17640 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: CAESinkALSA::InitializeHW - Setting timeout to 200 ms 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: CAESinkALSA::GetChannelLayout - Input Channel Count: 6 Output Channel Count: 6 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR, FC, LFE, SL, SR 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: CAESinkALSA::GetChannelLayout - Got Layout: FL, FR, LFE, FC, SL, SR (ALSA: FL FR LFE FC RL RR) 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: CActiveAESink::OpenSink - ALSA Initialized: 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: Output Device : AML-AUGESOUND 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: Sample Rate : 88200 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: Sample Format : AE_FMT_S24NE4 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: Channel Count : 6 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: Channel Layout: FL, FR, LFE, FC, SL, SR 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: Frames : 4410 2022-03-04 19:45:45.153 T:3704 DEBUG <general>: Frame Size : 24 2022-03-04 19:45:45.166 T:3703 DEBUG <general>: CActiveAE::ClearDiscardedBuffers - buffer pool deleted 2022-03-04 19:45:45.217 T:3921 INFO <general>: Skipped 1 duplicate messages.. 2022-03-04 19:45:45.217 T:3921 INFO <general>: PAPlayer::PrepareStream - Ready 2022-03-04 19:45:45.218 T:3929 DEBUG <general>: OnAVStarted: CApplication::OnAVStarted 2022-03-04 19:45:45.256 T:3698 DEBUG <general>: ------ Window Deinit (DialogBusy.xml) ------ 2022-03-04 19:46:03.188 T:3722 DEBUG <general>: CLibInputKeyboard::ProcessKey - using delay: 400ms repeat: 80ms 2022-03-04 19:46:03.188 T:3932 DEBUG <general>: Thread Timer start, auto delete: false 2022-03-04 19:46:03.196 T:3698 DEBUG <general>: Keyboard: scancode: 0xa6, sym: 0x00b2, unicode: 0x0000, modifier: 0x0
When I then switch to a normal stereo two channel file:
2022-03-04 19:46:09.313 T:3943 DEBUG : CFileCache::Process - <smb://192.168.0.112/Multimedia/music/Yo-Yo Ma/The Six Unaccompanied Cello Suites (Disc 1)/01 - Suite No. 1 in G major, BWV 1007 I. Prelude.flac> cache completely reset for seek to position 8740
2022-03-04 19:46:09.314 T:3936 DEBUG : SeekTime - seek ended up on time 0.000
2022-03-04 19:46:09.344 T:3698 INFO : Skipped 1 duplicate messages…
2022-03-04 19:46:09.344 T:3698 DEBUG : ------ Window Init (DialogBusy.xml) ------
2022-03-04 19:46:09.398 T:3936 INFO : AudioDecoder: File is queued
2022-03-04 19:46:09.400 T:3936 DEBUG : AudioDecoder::GetReplayGain - Final Replaygain applied: 1.000000, Track/Album Gain 89.000000, Peak 1.000000
2022-03-04 19:46:09.402 T:3703 DEBUG : CActiveAE::ClearDiscardedBuffers - buffer pool deleted
2022-03-04 19:46:09.411 T:3936 INFO : PAPlayer::PrepareStream - Ready
2022-03-04 19:46:09.412 T:3942 DEBUG : OnAVStarted: CApplication::OnAVStarted
2022-03-04 19:46:09.414 T:3704 INFO : CActiveAESink::OpenSink - initialize sink
2022-03-04 19:46:09.414 T:3704 DEBUG : CActiveAESink::OpenSink - trying to open device ALSA:surround71:CARD=AMLAUGESOUND,DEV=0
2022-03-04 19:46:09.414 T:3704 INFO : CAESinkALSA::Initialize - Configure simple control for “AUGESOUND”
2022-03-04 19:46:09.414 T:3704 INFO : CAESinkALSA - Use card “hw:0” and set codec format “2 CH PCM”
2022-03-04 19:46:09.418 T:3704 INFO : CAESinkALSA - Set codec for “Audio spdif format”
2022-03-04 19:46:09.418 T:3704 INFO : CAESinkALSA - Set codec for “Audio spdif_b format”
2022-03-04 19:46:09.418 T:3704 INFO : CAESinkALSA - Set Spdif to HDMITX to “Spdif”
2022-03-04 19:46:09.418 T:3704 INFO : CAESinkALSA::Initialize - Attempting to open device “surround71:CARD=AMLAUGESOUND,DEV=0”
2022-03-04 19:46:09.429 T:3704 INFO : CAESinkALSA::Initialize - Opened device “surround71:CARD=AMLAUGESOUND,DEV=0”
2022-03-04 19:46:09.430 T:3704 DEBUG : CAESinkALSA::SelectALSAChannelMap - Selected ALSA map “FL FR”
2022-03-04 19:46:09.430 T:3704 INFO : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2022-03-04 19:46:09.431 T:3704 INFO : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2022-03-04 19:46:09.431 T:3704 DEBUG : CAESinkALSA::InitializeHW - Request: periodSize 2205, bufferSize 8820
2022-03-04 19:46:09.432 T:3704 DEBUG : CAESinkALSA::InitializeHW - Got: periodSize 2205, bufferSize 8820
2022-03-04 19:46:09.432 T:3704 DEBUG : CAESinkALSA::InitializeHW - Setting timeout to 200 ms
2022-03-04 19:46:09.432 T:3704 DEBUG : CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
2022-03-04 19:46:09.432 T:3704 DEBUG : CAESinkALSA::GetChannelLayout - Requested Layout: FL, FR
2022-03-04 19:46:09.432 T:3704 DEBUG : CAESinkALSA::GetChannelLayout - Got Layout: FL, FR (ALSA: FL FR)
2022-03-04 19:46:09.432 T:3704 DEBUG : CActiveAESink::OpenSink - ALSA Initialized:
2022-03-04 19:46:09.432 T:3704 DEBUG : Output Device : AML-AUGESOUND
2022-03-04 19:46:09.432 T:3704 DEBUG : Sample Rate : 44100
2022-03-04 19:46:09.432 T:3704 DEBUG : Sample Format : AE_FMT_S24NE4
2022-03-04 19:46:09.432 T:3704 DEBUG : Channel Count : 2
2022-03-04 19:46:09.432 T:3704 DEBUG : Channel Layout: FL, FR
2022-03-04 19:46:09.432 T:3704 DEBUG : Frames : 2205
2022-03-04 19:46:09.432 T:3704 DEBUG : Frame Size : 8
2022-03-04 19:46:09.436 T:3698 DEBUG : ------ Window Deinit (DialogBusy.xml) ------
2022-03-04 19:46:11.152 T:3943 DEBUG : CFileCache::Process - <smb://192.168.0.112/Multimedia/music/Yo-Yo Ma/The Six Unaccompanied Cello Suites (Disc 1)/01 - Suite No. 1 in G major, BWV 1007 I. Prelude.flac> source read hit eof
2022-03-04 19:46:39.171 T:3935 DEBUG : Thread JobWorker 3443110528 terminating (autodelete)
2022-03-04 19:46:39.171 T:3921 DEBUG : Thread JobWorker 3509469824 terminating (autodelete)
2022-03-04 19:46:39.171 T:3937 DEBUG : Thread JobWorker 3520012928 terminating (autodelete)
2022-03-04 19:46:39.411 T:3936 DEBUG : Thread JobWorker 3816800896 terminating (autodelete)
2022-03-04 19:46:52.276 T:3722 DEBUG : CLibInputKeyboard::ProcessKey - using delay: 400ms repeat: 80ms
2022-03-04 19:46:52.277 T:3698 DEBUG : Keyboard: scancode: 0xa6, sym: 0x00b2, unicode: 0x0000, modifier: 0x0
2022-03-04 19:46:52.277 T:3698 DEBUG : HandleKey: stop (0xf0bc) pressed, action is Stop
2022-03-04 19:46:52.277 T:3945 DEBUG : Thread Timer start, auto delete: false
2022-03-04 19:46:52.338 T:3943 DEBUG : Thread FileCache 3485409920 terminating
2022-03-04 19:46:52.340 T:3942 DEBUG : CSMBFile::Close closing fd 10000
2022-03-04 19:46:52.357 T:3946 DEBUG : Thread JobWorker start, auto delete: true
2022-03-04 19:46:52.358 T:3703 DEBUG : CActiveAE::DiscardStream - audio stream deleted
and the stream plays silently…
Anyone else with this issue?
