Ugoos AM6B+ Magical combinations drop image when using PM4K
My current audio setup is my 4k TV, JBL MA710 AVR, and Ugoos AM6B+ running CoreElec 21.2 Omega-Nightly, speakers are in a 7.1 configuration. My Ugoos and TV are connected to my AVR. All cables in play are Ultra High-Speed certified. Using a Blu-ray player, I verified I can play TrueHD and DTS-MA HD codecs without issue.
I am observing that certain combinations of Audio / Video cause total video loss when using PM4K. Setting the “System resolution” seems to have some impact. If I set the resolution to 4k, I cannot play either a 1080p or a 4k VC1-TRUEHD remux (Input is dropped from TV, AVR plays an instant of audio then drops). If I set the resolution to 1080p, I can play the 1080p remux but not the 4k one. So it appears the resolution is the root cause here. However, I can play a 4k DoVI/HDR10 DTS-HD-MA 5.1 remux without issue. One interesting note, is that if I connect my Ugoos to my TV directly, I can play the video fine but lose some audio codecs, for example DTS-HD-MA codecs. So I can either choose between a video or audio problem.
kodi.log: 2025-06-29 19:51:37.362 T:3966 info <general>: ----------------------------- - Pastebin.com
dmesg: https://paste.coreelec.org/TradeCinnamon
This looks suspicious
[ 1009.362525@2]- asoc-aml-card auge_sound: S/PDIF[1] Playback enable
[ 1009.397553@0]- dim:value reg:ch[0]:fix_buf:0;ponly <0,0>
[ 1009.397564@0]- dim:3840x2160-0x501000.
[ 1009.406897@0]h detect vout mode change!!!!!!!!!!!!
[ 1009.406933@0]h [tsync_avevent_locked 1064]VIDEO_START-tsync_mode:0(S)
[ 1009.406936@0]h pcr:0x0,param:0x0,vpts:0x0,apts:0xffffffff
[ 1009.511866@3]- asoc-aml-card auge_sound: S/PDIF[1] Playback disable
[ 1009.511905@3]- iec_info: rate: 192000, codec_type:0x7, channel status L:0x9001902, R:0x9001902
[ 1009.511910@3]- hdmitx: err chn setting, must be 2, 4, 6 or 8, Rst as def
[ 1009.511911@3]- hdmitx: err chn msk, must larger than 0
[ 1009.511922@3]- aml_spdif_fifo_ctrl, bit depth:16, frddr type:1, toddr:type:1
[ 1009.512138@0]- spdif_b keep clk continuous
[ 1009.512210@3]- audio_ddr_mngr: frddrs[0] released by device ff642000.audiobus:spdif_b
[ 1009.512798@1]- vout: vmode set to null
[ 1009.513556@1]- fb: current vmode=2160p60hz420, cmd: 0x10000
[ 1009.513562@1]- vlock: event MODE_CHANGE_PRE 0
[ 1009.513603@1]- hdmitx: edid: not find mapped vic
[ 1009.513622@1]- vout: new mode null set ok
[ 1009.513623@1]- fb: current vmode=null, cmd: 0x20000
[ 1009.514148@1]- hdmitx: system: set frac_rate_policy as 1
[ 1009.514208@1]- vout: vmode set to 2160p24hz
[ 1009.514575@1]- fb: current vmode=null, cmd: 0x10000
[ 1009.514587@1]- hdmitx: hdmitx_set_current_vmode[5644]
What I tried:
Any ideas? Thanks for your time.
Some random stuff:
CoreELEC:~ # cat /sys/class/display/mode
2160p24hz
You need try use the system, without any plex addon. Users in avs forum reported weird issues, what’s gone when they using without plex addons.
Thanks for your reply, I just attempted to play the same MKV from a flash drive and experiencing the exact same issue. So I think pm4k & pkc can be ruled out.
EDIT: I was wrong. After a few minutes of buffering, the video started playing. Hmm…
After attempting to play the same MKV from the NAS directly (SMB), seeing the “black screen stutter” issue.
CoreELEC:~ # ping 192.168.4.90
PING 192.168.4.90 (192.168.4.90): 56 data bytes
64 bytes from 192.168.4.90: seq=0 ttl=64 time=0.516 ms
64 bytes from 192.168.4.90: seq=1 ttl=64 time=0.521 ms
64 bytes from 192.168.4.90: seq=2 ttl=64 time=0.527 ms
64 bytes from 192.168.4.90: seq=3 ttl=64 time=0.517 ms
64 bytes from 192.168.4.90: seq=4 ttl=64 time=0.535 ms
64 bytes from 192.168.4.90: seq=5 ttl=64 time=0.534 ms
64 bytes from 192.168.4.90: seq=6 ttl=64 time=0.527 ms
64 bytes from 192.168.4.90: seq=7 ttl=64 time=0.579 ms
64 bytes from 192.168.4.90: seq=8 ttl=64 time=0.519 ms
64 bytes from 192.168.4.90: seq=9 ttl=64 time=0.527 ms
Let’s dig deeper with iperf
CoreELEC:~ # iperf3 -s
Server listening on 5201 (test #1)
Accepted connection from 192.168.4.90, port 48990
[  5] local 192.168.4.91 port 5201 connected to 192.168.4.90 port 48992
[ ID] Interval           Transfer     Bitrate
[  5]   0.00-1.00   sec   112 MBytes   939 Mbits/sec
[  5]   1.00-2.00   sec   112 MBytes   942 Mbits/sec
[  5]   2.00-3.00   sec   112 MBytes   942 Mbits/sec
[  5]   3.00-4.00   sec   112 MBytes   941 Mbits/sec
[  5]   4.00-5.00   sec   112 MBytes   941 Mbits/sec
[  5]   5.00-6.00   sec   112 MBytes   942 Mbits/sec
[  5]   6.00-7.00   sec   112 MBytes   942 Mbits/sec
[  5]   0.00-7.00   sec   811 MBytes   972 Mbits/sec                  receiver
iperf3: the client has terminated
iperf mid transfer shows reasonable throughput hit
Accepted connection from 192.168.4.90, port 48994
[  5] local 192.168.4.91 port 5201 connected to 192.168.4.90 port 48996
[  5]   0.00-1.00   sec   101 MBytes   844 Mbits/sec
[  5]   1.00-2.00   sec   101 MBytes   845 Mbits/sec
[  5]   2.00-3.00   sec   101 MBytes   848 Mbits/sec
[  5]   3.00-4.00   sec   100 MBytes   842 Mbits/sec
[  5]   4.00-5.00   sec   102 MBytes   860 Mbits/sec
[  5]   5.00-6.00   sec   100 MBytes   840 Mbits/sec
[  5]   6.00-7.00   sec  98.6 MBytes   827 Mbits/sec
[  5]   7.00-8.00   sec   100 MBytes   842 Mbits/sec
[  5]   8.00-9.00   sec  99.2 MBytes   833 Mbits/sec
[  5]   9.00-10.00  sec   103 MBytes   863 Mbits/sec
[  5]  10.00-10.00  sec   384 KBytes   863 Mbits/sec
[  5]   0.00-10.00  sec  1007 MBytes   844 Mbits/sec                  receiver
Gee, let’s try mounting it and reading it from there.
CoreELEC:~ # mount -t cifs -o vers=3.0,username=plex,password=plexplex //192.168.4.90/Drive /storage/devo/1/
CoreELEC:~ # ls /storage/devo/1/
#Recycle  Movies
Same issue observed attempting to play a 1080p DTS-HD MA file :frowning:
EDIT: After lots of black-screen stuttering the video eventually played normally. However the original 4k file is still not playing. The theory I have is continuous “black-screen stutter” that never catches up.
Swapped over to today’s NO New Order build and observing same issue.
It’s the receiver. Swapped it out for a Denon and it just works. JBL MA710 loses some points. If you have a JBL MA710 receiver and experiencing signal loss, it’s probably the AVR.
Lesson learned; in future when trying to resolve a problem first step is to connect the box directly to TV :wink:
That was indeed my first step.
