Try with v. 2.0.5.
It doesn’t work with 2.0.5 either.
Have you enabled root acess before?There should be zero issues with video playback on AM9 though CE.
This is not true for latest firmware. Same applies for some other devices.
Okay I admit,just tested CE on AM9,cannot play movies with my service.
This is the final warning, we don’t care where you get your streams. No mention to banned add-ons or services as defined by team Kodi:
Can someone with old 1.x firmware add loglevel=9 to /flash/config.ini file, reboot and play one file for 2 seconds. Then dmesg | paste.
Crash in the loop after I updated to 20251218. Every second new crashlog file is being generated. Kodi.FAILED folder is created but black screen only.
Where I can get the version 20251217 from?
[EDIT1] - got it, at the bottom of the web page there is a link [-- Search archive website --]
[EDIT2] - but there is in each subfolder only one file without information what this release is, no “Generic” in the name and size is bigger than typical “Generic” version 400MB vs. 346MB so still I don’t know where to get the file CoreELEC-Amlogic-no.aarch64-22.0-Piers_nightly_20251217-Generic.img.gz from. Is the version 20251219 correct? Does it also cause bootloop?
I was able to copy few of these crashlogs but all looks the same.
############## kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri Dec 19 17:56:23 CET 2025
kodi Options: --standalone -fs
Arch: aarch64
Kernel: Linux 5.15.170 #1 SMP PREEMPT Thu Dec 18 01:34:07 IST 2025
Release: CoreELEC 22.0-Piers_nightly_20251218
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /storage/.cache/cores/core.!usr!lib!kodi!kodi.bin.1766163380.1934
[New LWP 1934]
[New LWP 1941]
[New LWP 1935]
[New LWP 1937]
[New LWP 1938]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/usr/lib/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin --audio-backend=alsa+pulseaudio --standalone -fs'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x0000007fb4194f08 in ?? () from /usr/lib/libc.so.6
[Current thread is 1 (Thread 0x7fbaa48620 (LWP 1934))]
Thread 5 (Thread 0x7fa7ffeda0 (LWP 1938)):
#0 0x0000007fb4182ce8 in ?? () from /usr/lib/libc.so.6
#1 0x0000007fb4177eb0 in ?? () from /usr/lib/libc.so.6
#2 0x0000007fb4177ef8 in ?? () from /usr/lib/libc.so.6
#3 0x0000007fb4f9527c in lirc_nextcode () from /usr/lib/liblirc_client.so.0
#4 0x00000000008db7bc in CLirc::Process() ()
#5 0x0000000000c440e4 in CThread::Action() ()
#6 0x0000000000c4e2bc in ?? ()
#7 0x0000007fb441cd1c in ?? () from /usr/lib/libstdc++.so.6
#8 0x0000007fb417afd0 in ?? () from /usr/lib/libc.so.6
#9 0x0000007fb41d878c in ?? () from /usr/lib/libc.so.6
Thread 4 (Thread 0x7fb0a4eda0 (LWP 1937)):
#3 0x0000007fb41cfb98 in poll () from /usr/lib/libc.so.6
#4 0x0000007fb4e32d50 in ?? () from /usr/lib/libpulse.so.0
#5 0x0000007fb4e2b15c in pa_mainloop_poll () from /usr/lib/libpulse.so.0
#6 0x0000007fb4e2b4ac in pa_mainloop_iterate () from /usr/lib/libpulse.so.0
#7 0x0000007fb4e2b530 in pa_mainloop_run () from /usr/lib/libpulse.so.0
#8 0x0000007fb4e32db8 in ?? () from /usr/lib/libpulse.so.0
#9 0x0000007fb33d7f64 in ?? () from /usr/lib/pulseaudio/libpulsecommon-17.0.so
#10 0x0000007fb417afd0 in ?? () from /usr/lib/libc.so.6
#11 0x0000007fb41d878c in ?? () from /usr/lib/libc.so.6
Thread 3 (Thread 0x7fb125eda0 (LWP 1935)):
#2 0x0000007fb41781cc in ?? () from /usr/lib/libc.so.6
#3 0x0000007fb417a5bc in pthread_cond_wait () from /usr/lib/libc.so.6
#4 0x0000000000c44464 in ?? ()
#5 0x00000000013b50a0 in ANNOUNCEMENT::CAnnouncementManager::Process() ()
#6 0x0000000000c440e4 in CThread::Action() ()
#7 0x0000000000c4e2bc in ?? ()
#8 0x0000007fb441cd1c in ?? () from /usr/lib/libstdc++.so.6
#9 0x0000007fb417afd0 in ?? () from /usr/lib/libc.so.6
#10 0x0000007fb41d878c in ?? () from /usr/lib/libc.so.6
Thread 2 (Thread 0x7fa77eeda0 (LWP 1941)):
#0 0x0000007fb4182cec in ?? () from /usr/lib/libc.so.6
#3 0x0000007fb41d881c in epoll_pwait () from /usr/lib/libc.so.6
#4 0x00000000008fc550 in CLibInputHandler::Process() ()
Thread 1 (Thread 0x7fbaa48620 (LWP 1934)):
#1 0x00000000007f1f48 in ?? ()
#2 0x000000000155ca38 in CAMLDRMUtils::aml_get_drmDevice_mode[abi:cxx11]() ()
#3 0x00000000015661e0 in CAMLDisplay::aml_get_native_resolution(RESOLUTION_INFO*) ()
#4 0x0000000001566b70 in KODI::WINDOWING::AML::CWinSystemAmlogicGLESContext::CreateNewWindow(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, RESOLUTION_INFO&) ()
#5 0x000000000154e934 in KODI::WINDOWING::AML::CWinSystemAmlogicGLESContext::SetFullScreen(bool, RESOLUTION_INFO&, bool) ()
#6 0x0000000000b4d9d4 in CGraphicContext::SetVideoResolutionInternal(RESOLUTION, bool) ()
#7 0x000000000156f204 in CWinSystemAmlogic::HotplugEvent() ()
#8 0x0000000001570a8c in KODI::WINDOWING::AML::CWinSystemAmlogicGLESContext::InitWindowSystem() ()
#9 0x0000000000df6668 in CApplication::CreateGUI() ()
#10 0x0000000000c802f0 in XBMC_Run ()
#11 0x0000000000790fa4 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
...2025-12-19 17:56:18.889 T:1934 info <general>: -----------------------------------------------------------------------
2025-12-19 17:56:18.889 T:1934 info <general>: Starting Kodi (22.0-ALPHA2 (21.90.702) Git:044e711cb9d837c2322beca7c72e8a942fcb2617). Platform: Linux ARM 64-bit
2025-12-19 17:56:18.889 T:1934 info <general>: Using Release Kodi x64
2025-12-19 17:56:18.889 T:1934 info <general>: Kodi compiled 2025-12-18 02:38:26 by GCC 15.2.0 for Linux ARM 64-bit version 5.15.170 (331690)
2025-12-19 17:56:18.889 T:1934 info <general>: Running on Ugoos AM9 with CoreELEC (official): 22.0-Piers_nightly_20251218, kernel: Linux ARM 64-bit version 5.15.170
2025-12-19 17:56:18.889 T:1934 info <general>: FFmpeg version/source: 8.0.1
2025-12-19 17:56:18.889 T:1934 info <general>: 4 CPU cores available
2025-12-19 17:56:18.889 T:1934 info <general>: ARM Features: Neon enabled
2025-12-19 17:56:18.889 T:1934 info <general>: special://xbmc/ is mapped to: /usr/share/kodi/
2025-12-19 17:56:18.889 T:1934 info <general>: special://xbmcbin/ is mapped to: /usr/lib/kodi
2025-12-19 17:56:18.889 T:1934 info <general>: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2025-12-19 17:56:18.889 T:1934 info <general>: special://masterprofile/ is mapped to: /storage/.kodi/userdata
2025-12-19 17:56:18.889 T:1934 info <general>: special://envhome/ is mapped to: /storage
2025-12-19 17:56:18.889 T:1934 info <general>: special://home/ is mapped to: /storage/.kodi
2025-12-19 17:56:18.889 T:1934 info <general>: special://temp/ is mapped to: /storage/.kodi/temp
2025-12-19 17:56:18.889 T:1934 info <general>: special://logpath/ is mapped to: /storage/.kodi/temp
2025-12-19 17:56:18.889 T:1934 info <general>: Webserver extra whitelist paths:
2025-12-19 17:56:18.889 T:1934 info <general>: The executable running is: /usr/lib/kodi/kodi.bin
2025-12-19 17:56:18.889 T:1934 info <general>: Local hostname: AM9Rafal
2025-12-19 17:56:18.889 T:1934 info <general>: Log File is located: /storage/.kodi/temp/kodi.log
2025-12-19 17:56:18.889 T:1934 info <general>: loading settings
2025-12-19 17:56:18.890 T:1934 info <general>: special://profile/ is mapped to: special://masterprofile/
2025-12-19 17:56:18.904 T:1934 info <general>: Loaded settings file from special://xbmc/system/advancedsettings.xml
2025-12-19 17:56:18.904 T:1934 info <general>: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="utf-8" ?>
<advancedsettings>
<cputempcommand>/usr/bin/cputemp</cputempcommand>
<gputempcommand>/usr/bin/gputemp</gputempcommand>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<splash>false</splash>
</advancedsettings>
2025-12-19 17:56:18.904 T:1934 warning <CSettingsManager>: missing version attribute
2025-12-19 17:56:18.905 T:1934 info <general>: Loaded settings file from special://profile/advancedsettings.xml
2025-12-19 17:56:18.905 T:1934 info <general>: Contents of special://profile/advancedsettings.xml are...
<!-- Created using Easy Advanced Settings addon -->
<advancedsettings>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
<videodatabase>
<name>MyVideos</name>
<host>192.168.1.119</host>
<user>kodi</user>
<pass>*****</pass>
<type>mysql</type>
<port>3307</port>
</videodatabase>
<musicdatabase>
<name>MyMusic</name>
<user>kodi</user>
<pass>*****</pass>
<type>mysql</type>
<port>3307</port>
</musicdatabase>
</advancedsettings>
2025-12-19 17:56:18.905 T:1934 warning <general>: VIDEO database configuration is experimental.
2025-12-19 17:56:18.905 T:1934 warning <CSettingsManager>: missing version attribute
2025-12-19 17:56:18.906 T:1934 info <general>: Default Video Player: VideoPlayer
2025-12-19 17:56:18.906 T:1934 info <general>: Default Audio Player: paplayer
2025-12-19 17:56:18.906 T:1934 info <general>: Disabled debug logging due to GUI setting. Level 0.
2025-12-19 17:56:18.906 T:1934 info <general>: Log level changed to "info"
2025-12-19 17:56:18.906 T:1934 info <general>: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2025-12-19 17:56:18.906 T:1934 info <general>: WakeOnAccess - Load settings :
2025-12-19 17:56:18.906 T:1934 info <general>: WakeOnAccess - Enabled:FALSE
2025-12-19 17:56:18.906 T:1934 info <general>: -Network init timeout : [20] sec
2025-12-19 17:56:18.906 T:1934 info <general>: -Network settle time : [500] ms
2025-12-19 17:56:18.906 T:1934 info <general>: Registering wakeup entry:
2025-12-19 17:56:18.906 T:1934 info <general>: HostName : 192.168.1.119
2025-12-19 17:56:18.906 T:1934 info <general>: MacAddress : 00:11:32:F7:BF:55
2025-12-19 17:56:18.906 T:1934 info <general>: PingPort : 0
2025-12-19 17:56:18.906 T:1934 info <general>: PingMode : 0
2025-12-19 17:56:18.906 T:1934 info <general>: Timeout : 300 (sec)
2025-12-19 17:56:18.906 T:1934 info <general>: WaitForOnline : 40 (sec)
2025-12-19 17:56:18.906 T:1934 info <general>: WaitForOnlineEx : 40 (sec)
2025-12-19 17:56:18.906 T:1934 info <general>: WaitForServices : 5 (sec)
2025-12-19 17:56:18.906 T:1934 info <general>: Registering upnp_map entry [DS920Plus : 001132f7-bf55-0011-55bf-55bff7321100] -> [00:11:32:F7:BF:55]
2025-12-19 17:56:18.913 T:1934 info <general>: New Cache GUI Settings (replacement of cache in advancedsettings.xml) are:
Buffer Mode: 4
Memory Size: 1024 MB
Read Factor: 10.00 x
Chunk Size : 524288 bytes
2025-12-19 17:56:18.913 T:1934 info <general>: creating subdirectories
2025-12-19 17:56:18.913 T:1934 info <general>: userdata folder: special://masterprofile/
2025-12-19 17:56:18.913 T:1934 info <general>: recording folder:
2025-12-19 17:56:18.913 T:1934 info <general>: screenshots folder: /storage/screenshots/
2025-12-19 17:56:18.916 T:1934 info <general>: Running database version Addons33
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'audioencoder.kodi.builtin.aac v1.0.2'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'audioencoder.kodi.builtin.wma v1.0.2'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'game.controller.cec.adapter v1.0.4'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'game.controller.default v1.0.46'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'game.controller.keyboard v1.1.47'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'game.controller.mouse v1.0.30'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'game.controller.snes v1.0.46'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'inputstream.adaptive v22.3.3.1'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.global.audioengine v1.1.1'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.global.filesystem v1.1.10'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.global.general v1.0.5'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.global.gui v5.15.1'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.global.main v2.0.2'
2025-12-19 17:56:18.951 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.global.network v1.0.4'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.global.tools v1.0.4'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.audiodecoder v4.0.0'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.audioencoder v3.0.0'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.game v4.1.0'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.imagedecoder v3.0.1'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.inputstream v3.4.0'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.peripheral v3.0.2'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.pvr v9.2.0'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.screensaver v2.2.0'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.shaderpreset v1.1.0'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.vfs v3.0.1'
2025-12-19 17:56:18.952 T:1934 info <general>: Addon Manager: Found addon: 'kodi.binary.instance.videocodec v2.1.0'
Here you go: https://paste.coreelec.org/ProceedTailored
I couldn’t figure out what firmware I’m using, but I haven’t updated it for the last ~6 weeks and playback in Coreelec still works fine in my case
You asked me for that 12 days ago in private message and I delivered this data the same day. Maybe you didn’t check your inbox?
I didn’t realise you could use CE, I thought you could only use the NO release of the v22 as it had specific mentions of the s905x5 as being supported.
I have the AM9 and still so much to learn obviously
I am having audio sync issues in Android 14 and Kodi 21.2, is this expected?
My system 2024 55” Samsung The Frame (free Sync) Samsung HW-A990c soundbar (11.2.1) Ugoos AM9 Certified 8k HDMI cables
Previous setup was with a Nvidia shield for 10 years no audio sync issues.
My AM9 is running latest firmware I have tried multiple custom builds of Kodi, tried all the settings I can find in Kodi and hardware. I have had to resort to using the addon that auto applys audio delay based on audio codec.
I would have expected for a device that has hardware support for the types of video compression being played and the TV is matching the frame rate of the video that the audio sync would be spot on.
Please what am I missing?
Nice! You got already a Christmas present?
What DTB you used for 21.2 and AM9?
Wrong forum?
Hi mate
If your post is for me?
Sorry i thought I might have been dealing with a kodi issue
Also I have only tried the Coreelec 22 alfa build as I thought it was the only build that supported the hardware
Wrong forum for Android - non-CoreELEC.
Yeah I know, but you guys seem to have experience with the AM9 and Kodi. I really only want to use Coreelec build on my AM9, but I suppose I need to be patient?
You could wait for CoreELEC stable version for AM9 or you could flash Alpha-2 version or latest Nightly version which are released every ~2-3 days.
In each scenario you could expect different results including Kodi crashes, CEC functioning in strange way, unexpected reboots back to Android, etc.with Nightly releases like I experienced.
Up to you.
Thanks rabaraf, I have been playing with some of the nightly builds.
Is there any point in trying the 21.2 or 21.3 builds? Would they even work?
@Wildpig954 I have been using nightly builds for several weeks now. All is very stable, for me there’s no need to even consider alpha 2. 21.2/21.3 won’t work as the chipset wasn’t supported when these versions were released.
Hey chielmi thanks for the info.
I think I’m missing something, just tonight I downloaded today’s nightly build and followed the instructions to setup on an sd. I successfully booted into coreELEC
I set the basic settings for video, audio passthrough, no addons, then tried to play some video files on my HDD.
Nothing plays, wheel spins, once I got some sound.
I think I need to dig through the wiki I suppose.
