I just put the UR02 into learning mode, as in the instructions, and pointed my existing remote at it.
Hi ![]()
Iâm missing the context menu button when the remote is connected on BT (the button with three line) on AMB6+ :
Over the IR, itâs ok, it works ![]()
Can I do something to make it works when connected as BT ?
Thanks.From debug logs : 2025-10-30 19:06:12.155 T:3957 debug <general>: Keyboard: scancode: 0x8b, sym: 0x00 (), unicode: 0x00, modifier: 0x0
2025-10-30 19:06:12.156 T:3957 debug <general>: GetActionCode: Trying Hardy keycode for 0xf200
2025-10-30 19:06:12.156 T:3957 info <general>: Skipped 3 duplicate messages..
2025-10-30 19:06:12.156 T:3957 debug <general>: HandleKey: 0 (0xf200, obc-61697) pressed, window 10016, action is
2025-10-30 19:06:12.329 T:5644 debug <general>: Thread Timer 2799157760 terminating
2025-10-30 19:06:12.364 T:3957 debug <general>: Keyboard: scancode: 0x8b, sym: 0x00 (), unicode: 0x00, modifier: 0x0
2025-10-30 19:06:12.629 T:3963 debug <general>: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 33ms
2025-10-30 19:06:12.630 T:5645 debug <general>: Thread Timer start, auto delete: false
2025-10-30 19:06:12.657 T:3957 debug <general>: Keyboard: scancode: 0x8b, sym: 0x00 (), unicode: 0x00, modifier: 0x0
2025-10-30 19:06:12.657 T:3957 debug <general>: GetActionCode: Trying Hardy keycode for 0xf200
2025-10-30 19:06:12.657 T:3957 info <general>: Skipped 3 duplicate messages..
2025-10-30 19:06:12.657 T:3957 debug <general>: HandleKey: 0 (0xf200, obc-61697) pressed, window 10016, action is
2025-10-30 19:06:12.799 T:5645 debug <general>: Thread Timer 2799157760 terminating
2025-10-30 19:06:12.815 T:3957 debug <general>: Keyboard: scancode: 0x8b, sym: 0x00 (), unicode: 0x00, modifier: 0x0
2025-10-30 19:06:13.079 T:3963 debug <general>: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 33ms
2025-10-30 19:06:13.080 T:5646 debug <general>: Thread Timer start, auto delete: false
2025-10-30 19:06:13.114 T:3957 debug <general>: Keyboard: scancode: 0x8b, sym: 0x00 (), unicode: 0x00, modifier: 0x0
2025-10-30 19:06:13.114 T:3957 debug <general>: GetActionCode: Trying Hardy keycode for 0xf200
2025-10-30 19:06:13.114 T:3957 info <general>: Skipped 3 duplicate messages..
2025-10-30 19:06:13.114 T:3957 debug <general>: HandleKey: 0 (0xf200, obc-61697) pressed, window 10016, action is
2025-10-30 19:06:13.280 T:5646 debug <general>: Thread Timer 2799157760 terminating
2025-10-30 19:06:13.315 T:3957 debug <general>: Keyboard: scancode: 0x8b, sym: 0x00 (), unicode: 0x00, modifier: 0x0
2025-10-30 19:06:13.720 T:3963 debug <general>: CLibInputKeyboard::ProcessKey - using delay: 500ms repeat: 33ms
From remote.conf :
key_begin
0x0e 14 # del
0x74 116 # power
0x41 582 # voice
0x67 103 # up
0x6c 108 # down
0x69 105 # left
0x6a 106 # right
0x61 97 # ok
0x9e 158 # back
0xac 102 # home
0x8b 139 # menu
0x73 115 # vol+
0x72 114 # vol-
0x71 113 # mute
0x92 146 # ch+
0x93 147 # ch-
0xa4 119 # play/pause
0xa3 123 # next
0xa5 122 # previous
0xd9 217 # search
0xab 171 # music
0x17 140 # mouse
0x96 70 # browser
key_end
So â0x8b 139 # menuâ is present and match the log test with remote configured as BT.
But I donât know what does it mean : debug : GetActionCode: Trying Hardy keycode for 0xf200
Edit : Logs from IR :
2025-10-30 19:50:05.945 T:6707 debug : Keyboard: scancode: 0x2e, sym: 0x63 (c), unicode: 0x63, modifier: 0x0
2025-10-30 19:50:05.945 T:6707 debug : HandleKey: c (0xf043) pressed, window 10106, action is Back
On IR, it seems to be 0x2e
I think when I tested this remote, long press âOKâ worked.
Yes, the long press on âOKâ button works hopefully ![]()
Thanks for mentioned it, I forgot to tell it ![]()
But the specific button âmenuâ that works with IR (when not connected as BT) doesnât work when UR02 is associate.
It did in my case but I did not use any remote.conf.
Maybe interfering, I donât think BT relies on it (no expert in this area, though)
Do you mean this button menu works on your side without copying the remote.conf and in BT ?
Thanks anywayđ
I thought so and since i still have this remote lying around (not using it daily) I did a test.
Removed all existing mappings for the âmenuâ key. It doesnât work ![]()
It does however get recognized as you already discovered, so you can assign any action to it I guess
/edit assigning âcâ for context menu worked fine. I used keymap editor, very nice little tool
Thanks both, I didnât read the BT page yet, I was trying and installed the add-on âKeymap editorâ and by reading other post on internet, I finally succeed ![]()
I have created a remote.xml file to copy in folder âkeymapsâ from âuserdataâ with this inside below.
I did try with âmenuâ instead of âcontextmenuâ and it wasnât working but at force of trying the tool âKeymapâ give me the right name ![]()
<keymap>
<global>
<keyboard>
<key id='0xf200'>contextmenu</key>
</keyboard>
</global>
</keymap>
Glad you got it working.
My AM6b came with ur-02 only , it works , but when i turn the box off with remote im unable to turn box back on ?? how do you get ur-02 remote to turn box on ??
Iâve noticed a strange issue on my remote. I have coreelec on my am6b+. Earlier I had remote.conf of UR01 remote and replaced it with this remoteâs conf file and I connected it to bluetooth in coreelec.
Problem is whenever I press any button, it continuously blinks red and blue light and after some time, it stops. The functionality works, but sometimes it doesnât work. IIRC this is something to do with remote trying to use both IR and bluetooth together. If thatsâ the case, is there any way to stop using IR entirely and only use bluetooth?
Thanks in advance!
Android 9 firmware V. 0.5.4n2 for AM6 Family
- Ugoos UR02 support added
IR now works to wake up device
New Ugoos AMB6+ user here.
Donât know if this is the best place to post, however just pointing out that the guide ([GUIDE]-s922x-j-ugoos-am6b-coreelec-ng-installation-and-faqs), which apparently I am prevented from directly linking to here, currently reflects only a link to the remote.conf for the UR01, while recent units come with the UR02.
This caused me a bit of a headache and wasted time as I already had dual-boot set up before I realized the remote wasnât functioning properly. Only way I could see to fix it was to go back to the SDCard, change the remote.conf, then rerun ceemmc using option 4.
So hoping someone can update the guide to save the other new users from the same hassle.
Thanks for everyoneâs effort and support!
