New Remote Ugoos UR02 for all Mediaplayer
See:Ugoos BT Remote Control UR02
Please Add to CE remote.conf file Thanks
That control works with BT connection.
But one problem is there: OK button not work.
Even if programming with key-map editor.
Some changes are needed like described here.
THX, got it working
Write exactly what you did and the changes will be indued in CE image.
I follow this one:
This is the file that must be installed on:
ur02.hwdb (77 Bytes)
/storage/.config/hwdb.d
Hello CE Team
are there any instructions on how to activate this remonte control UR02 via IR on the AM6B+ ???
The file “remote.conf” is required. I requested it yesterday from Ugoos and I am waiting.
if you get the remote.conf file please post the link here thanks
Ugoos today sent me the remote conf file necessary for the UR02 remote to work as IR.I tested it and it works.
I upload the file here.I hope the CE team can add it to the repository.
remote_ur-02.conf (2.3 KB)
Would it be possible to get the UR01 remote conf file as well?
Thank you
Later edit : [Guide] S922X-J (Ugoos AM6b+) CoreELEC installation and FAQs
Found it here ![]()
Does anybody know, how I can use the color buttons on UR02 remote control? The file provided by @crazyturk works principally. However, color buttons are not recognized…
At the moment the remote.config for the UR01 is in CE.
How can I now easily add the remote.config for the UR02 in CE?
Can I simply copy this UR02 remote.config into the path “\COREELEC\Configfiles”?
Or is it more complicated?
Yes, drop there, or you can alternatively copy the root of your CE pendrive/sdcard installation.
Then reboot.
It’s all documented:
sorry I was wrong.
