Ugoos UR02 Remote
I need help with one topic. I have successfully paired the UR02, installed remoteconfi2 and everything working as expected. However, with the Chapter up and down buttons, they don’t allow me to add those as alternative buttons within Kodi’s Keymap Editor. Just to be clear, the buttons work; however, when selecting them within Keymap Editor, they default to the exaxt same code. I have successfully set Red button as “stop”, purple button as “Global search”, brown and blue as “3min skip back” and “3min skip forward”, yellow as “pause/play” which was default, and green as “subs on/off”. Grey power button as learned from Ugoos remote 1. I was hoping Chapter up and down could be set to an alternative within Kodi’s Keymap Editor. What am I missing? Should I be editing the RemoteConf file, or am I misinterpreting something. Because it was a grey button, I also figured it could “learn”; however, I have used all buttons from original remote so I don’t need to learn another button technically. I am just trying to set default Ch+ and Ch- to something else with Keymap Editor. Is there a solution? Worked for all the bottom (colored) buttons, but not for the Ch+ and Ch- button. Any help is appreciated. Thank you. Otherwise, I very happy with the UR02. The ability to just “stop” content without pulling up onscreen menu, or using “sub” off and on, is gamechanger for Kodi control for me.
Now that I think about it, I technically may have two additional buttons if the Ch+ and Ch- issue can be solved. The Mic button as well as one of the back buttons. The grey back button and the black back button, as basically the same as I understand it. If I find I need another one or two hot keys, I presume I will be able to use. Hopefully the Ch+ and Ch- can be a scroll button up and down for navigation, but at this point, just auto defaults to the same 5-digit code for both. Now that I typed that, I am wondering if this is an IR/BT thing…damn. Will test that. Or any info that I may be missing. How creative have you all got with UR02 for Kodi interaction?
UPDATE1: So…Ch+ and Ch- down function as IR buttons, so probably late to party on that knowledge. That it is why it is auto defaulting to same button in Keymap Editor. Is there a way to change that in the remoteconf, or similar to give me a few more buttons to leverage?
UPDATE2 for @CityCobra’s question that I learned after dealing with my issue. Not seeing how to change buttons from IR to BT (hopefully there is a way, so I can add Ch+ and Ch- as editabe): The way I understand IR/BT, once you connect the remote as BT, the remote is going to handle the IR or BT issues, or which buttons are IR and which are BT. At least that is how it works for me. Maybe the initial power button if you set that to grey power button via learning from original, you may have to use IR to turn Ugoos box on, but then within a few seconds BT should connect for all other buttons as you don’t need line of sight. If you have BT and IR working, I assume remote will default with BT since it is in a sense the same button press, maybe BT overrides it being a double press???, but not sure. That is how mine is working. Once I “trust/connected”, it has been working perfectly, other than my minor issue above with the Ch+/Ch- keys auto defaulting.
If you are having trouble with BT, I would try to pair again, and Trust/connect. The first time I did it, the BT screen is all wonky, especially if there are a bunch of BT signals in your area. My screen was finding new and freaking the hell out, once I re-paired the remote to the Ugoos box, all was good, even after turning Ugoos box off. It would start right back up with IR, and then auto pair with BT.
Regarding UR02 Remote…
(previously i had bought NVidia Shield Remote… although it was amazing in the grip and the fact that is was backlit it tend to crash a lot and had to remove batteries in order to work… (didnt have nvidia shield , only ugoos so i dont know if anything of this was solved via a firmware update))
Lets continue to Ugoos ur02 remote
I have bought two ugoos AM6b+…
one is connected to a Marantz receiver. the other on a sonos sound bar…
a) Marantz.
i connected via bluetooth the ugoos am6b+ to the ur02 remote… everything works great.
then i used the marantz remote so the ugoos am6b+ could up and down the volume of the receiver (via IR)… eveything works great also…
used the original ur01 to teach on the ur02 to power on / off Ugoos via IR…
(also changed the bluetooth volume up/down of the ur02 to scroll page up / page down in coreelec)
b) regarding sonos sound bar…
Via bluetooth everything ok… same as before…
to increase / decrease sonos sound bar volume i was using the LG remote of the TV…
when i tried ugoos ur02 to learn the LG volume up / volume down…(from the original remote) nothing happened…
here is the weird thing…
i have been using an One for All 7955 since ever…
one of the thing i taught it was the volume up / down from the lg tv and it was working as intended…
Ugoos UR02 could not learn IR Volume up/ down from the original LG remote…
BUT it learned withouth no problems from the One for All remote the Volume Up/Down of the LG TV…
I share my experience if i can help :slight_smile:
(nvidia shield remote has also IR Buttons / plus the Bluetooth, is really an amazing remote (plus the backlit when you raise it)… BUT one needs an Nvidia shield to firmware update it to work properly …)
Hope i ve helped :slight_smile:
You most likely have LG magic remote. It is conected to your tv with bluetooth so its not transmitting IR signals unless u disconnect it from bluetooth, that would explain why UR02 cant learn from it.
Hmm didnt think of that…
Nevertheless, found another solution :slight_smile:
@Portisch
The button next and previous not working on UR02 for AM6B+
please update the remote conf file thx
Send me the remote and I will do it.
The remote config works fine. I have 2 UR02, both is ok.
Works, I have the BT Remote UR 02 not corectly connected to the AM6B+ CE
Just bought a Ugoos AM6B+ that comes with the UR02 remote. I replaced the remote.conf in /flash/ with the UR02 config from GitHub. The remote pairs on Android OS and works, but on CoreElec the mouse pointer doesn’t work. I have to pair it again in CE to make the pointer work, but then when I reboot back to Android the remote stops working.
This is expected behavior. Unfortunately, the remote cannot remember two pairings at the same time. You either need a second remote or use your remote with IR on either Android or CE.
By the way, remote.conf is only needed if you’re using IR and not with bluetooth AFAIK.
The file for BT is available here.
Put the file “UgoosUR02.hwdb” in “storage/config/hwdb.d”.
.config (storage/.config/hwdb.d) or config (storage/config/hwdb.d)?
remote.conf and gen.xml works same as key_description image
but still mouse pointer not working, cursor not show when I click mouse button on CoreElec
but thanks a lot for config and gen.xml
Thats funny, never used any hwdb files, just paired once, half year earlier, and it’s just work, after the boot . I’m on NG.
Sorry for the off topic, I’m facing an issue with my UR01 remote which came with ugoos am6b+. I’m running coreelec build and the remote was working fine. All of a sudden, the remote started blinking red light continuously. I changed the batteries but that didn’t stop at all. Could anyone please suggest me what to do?
Any help guys?
or call support: support@ugoos.net
Have you copied the remote.conf file into the coreelec root directory?
Hello, I just receive my AMB6+ with UR02.
With the correct remote.conf, I can connect in BT and IR.
Is it possible to map Power OFF / Standby button to another device ?
For example, I would like to turn on / off my AVR instead of TV/Projector like I’m doing now with
FireTV 4K, the AVR receive only audio from the Vertex2 so I can’t use CEC. Even volume control the AVR and not the Kodi Volume.
Thank you.
You can make the UR02 learn other IR remote functions for the grey buttons. I have the grey power button and the grey up/down button copying my soundbar remote to control the soundbar directly.
Great :slight_smile: thanks for the information, did you set up from Ugoos OS ?
