Thanks that’s why I put that out there. It’s a pain for users going back and forth with Android though right?
Yep I can confirm that CE does indeed work on the KM1 Deluxe too (came with android 10).
Mine arrived today, got a good deal on it and bought it knowing it may or may not work with CE as my trusty raspberry pi 2 running kodi is showing it’s age.
I used the latest stable image with the sm1_s905x3_4g dtb, boots from either usb port, haven’t been able to get it to boot from sd card for whatever reason.
Got the remote to work easy enough as it’s basically the same as the KM9 Pro remote with 3 extra buttons being the only difference (which I didn’t bother with).
youtube - scancode = 0x71
prime video - scancode = 0x73
google play - scancode = 0x72
Only thing that seems to be missing is bluetooth I think and led control doesn’t seem to do anything (didn’t expect it to tbh).
Boot with the av port reset button.
New to coreelec and was just looking around and thought I’d share my info. ![]()
What about to mecool km6 deluxe?
Mecool is not a supporter of CE.
I don’t know how use the MesonIR. Have been using the AMRemote remote.conf file with my other box, but the Ugoos X2 Cube don’t have this files on the website
Anyone have the remote.conf file for Ugoos X4 or Ugoos X4 Cube?
I bought the Ugoos X4 Pro 32GB. When I tried CE 19.5-Matrix_rc2 (Stable) with the Ugoos X4 dtb with unique Device Tree, I can get to CE but the USB port don’t work so I cannot complete the CE setup.
But when I tried CE 19.5-Matrix_rc2 with generic Device Tree for X4, it works perfectly and the USB port is working fine too. The wifi and gigabit lan all works fine.
Why is that the Ugoos X4 unique device won’t have working USB yet the generic dtb have working USB?
I also tried booting CE from the USB with generic device dtb and it won’t boot at all. Looks like its not seeing the USB port. I am using a USB SDD. However when I try booting the same USB SDD on my HK1 RBOX, it works. This is really confusing.
So can the Ugoos boot CE from USB? If yes, how?
Please try with latest nightly
The ne nightly with Ugoos X4 unique Device Tree on microSD card fixed the usb port so now i can setup kodi with usb keyboard and remote.
But both ne & ng nightly still won’t boot with the USB SSD drive. Is this because the Ugoos X4 bootloader can’t boot from USB port?
It should boot, I’ll have to check later.
After further testing, while on ne nightly with Ugoos X4 unique Device Tree on microSD card, both wifi and LAN showing active but both don’t work. Both wifi and LAN shows its connected with internet, but it don’t have any connection to the internet. Try different addon and they all won’t connect to the internet.
Just tried CoreELEC-Amlogic-ng.arm-19.5-Matrix_nightly_20221006-Generic with Ugoos unique Device Tree and although both wifi and LAN can connect but return a different ip address as my network. My network is 192.168.0.X but the address connected shows 169.254.193.XX and won’t connect to internet.
So both ne and ng nightly have working USB port with Ugoos unique Device Tree dtb, but not working wifi and LAN
Nice story, but without any log you will not get any help…
You can try if a older version will work again:
http://coreelec.relkai.org/?dir=20220929
I’ve just finished a round of tests in my Ugoos X4 pro using -ne nightly (0710) and both wifi and Ethernet work. I also booted from USB and that worked too with the same results as uSD. And just to be sure I used android firmwares 1.0.7 and 1.1.0.
So, provide logs if the problem persists
I got 2 Ugoos X4 pro box which I just received and setting it up for my friends.
The problem I described earlier about wifi and Lan not working happens on one of the box only. From the above picture one of the box was manufactured Nov 2021and the other in July 2022. The one manufactured last year was the one with the networking problem. The newer box wifi and Lan works great.
I’m sorry I’m not very good at all the technical stuffs like how to copy logs. Can someone help me out here please. I can ssh to the box. When I go to CE>System>Submit log and click on Upload latest Kodi log and configs, it shows failed to paste log files.
Btw, USB booting does work when I try from my pendrive, but doesn’t work on my USB SSD. The same USB SSD boot from the HK1 RBox X4 though.
That is rotten Lightning69. Although I cannot help you myself can you be a help to ne and others and say whether there is any other easy to see differences with the user manual, packing box, or anything else so others can identify if they have a problematic earlier version box or a later one, all without opening the box and invalidating any returns policy. I have an X4 Pro shortly about to arrive and if is an earlier model that does not work properly with CE I will return it immediately of course, so would be good to be able to identify an earlier version without opening the case.
Both boxes look identical. However on the bottom of the tv box the serial number actually have date on it. And the there are differences in the chip used.
connect by SSH to each single device and post the result of:
udevadm info /sys/bus/sdio/devices/*
My friend took his box already so I cannot do anymore testing. I have another X4 Plus coming soon. Let’s see how is that box
