I am upgrading from Odroid C2 to N2. Everything works as expected, except the two DVB-T2 USB adapters. With C2 (CoreELEC 9.0.3) everything was o.k. With N2 it becomes unreliable. Sometimes o.k., sometimes connection errors on client side. It occurs on all clients therefore I assume a problem on server side.
Examples for error messages in log file are:
2019-07-07 19:37:42.639 T:3809399664 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - Command unsubscribe failed: No response received
2019-07-07 19:37:47.640 T:3346203504 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - Command hello failed: No response received
2019-07-07 19:37:47.641 T:3346203504 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to send hello
lsusb of the DVB-T2 devices:
Bus 001 Device 012: ID 0572:c688 Conexant Systems (Rockwell), Inc. Geniatech T230 DVB-T2 TV Stick
Bus 001 Device 014: ID 2040:0265 Hauppauge (WinTV dualHD)
Which driver(s) do I need? Is that a known problem expected to be fixed soon?
Thanks in advance for your help.
