I am sorry for double post on Khadas and here, but this is really shared area…
I have VIM3L HTPC Kit, which has CoreELEC preinstalled on the eMMC.
If I want to run CE from the SD card (flash) and use USB stick to /storage, what procedure I should follow?
I should be able prepare SD card as usual (Rpi, Odroid). I assume for storage I just need to change disk= within /flash/cfgload or simply change label on eMMC from STORAGE to something else and label USB stick partition as STORAGE, right?
But I read on wiki, that for SD card boot there must be android on eMMC? I am not familiar with eMMC control operations and I dont want to brick my device…
What if I change
setenv rootopt "BOOT_IMAGE=kernel.img boot=LABEL=COREELEC disk=LABEL=STORAGE"
to
setenv rootopt "BOOT_IMAGE=kernel.img boot=UUID=<UUID of SD card flash partition> disk=UUID=<UUID of storage card flash partition>"
on eMMC /flash, will it work without Android? That would be less aggresive change, and quite clean also, but I am not sure about future update process…
Thank you!
VIM3L:~ # parted -l
Error: /dev/mmcblk0rpmb: unrecognised disk label
Warning: Error fsyncing/closing /dev/mmcblk0rpmb: Input/output error
Retry/Ignore? i
i
Model: Generic SD/MMC Storage Card (sd/mmc)
Disk /dev/mmcblk0rpmb: 4194kB
Sector size (logical/physical): 512B/512B
Partition Table: unknown
Disk Flags:
Error: /dev/mmcblk0boot0: unrecognised disk label
Disk /dev/mmcblk0boot0: 4194kB
Disk Flags:
Error: /dev/mmcblk0boot1: unrecognised disk label
Disk /dev/mmcblk0boot1: 4194kB
Disk Flags:
Error: /dev/mmcblk0: unrecognised disk label
Model: MMC AJTD4R (sd/mmc)
Disk /dev/mmcblk0: 15.6GB
Disk Flags:
Is that really the case of CE@VIM3, so we cant modify those parameters at all?
