Looks same as for CE. No idea why it doesn’t work.
Btw: /flash/sc2_s905x4_4g_1gbit.dtb is not needed.
Not sure if it helps but here I compare Ugoos and Vontar
note
the fe01a000.t9015 mapping
and
the virtual consumer:auge_sound and consumer:fe06c000.i2c
Ugoos-X4-Pro:~ # dmesg | grep auge
[ 0.084053@0] amlogic auge_snd_iomap probe done
[ 2.992383@1] asoc-aml-card auge_sound: IRQ audio_exception64 not found
[ 3.198724@1] asoc-aml-card auge_sound: SPDIF-B <-> SPDIF-B mapping ok
[ 3.198799@1] asoc-aml-card auge_sound: fe01a000.t9015 <-> TDM-B mapping ok
[ 3.198858@1] asoc-aml-card auge_sound: SPDIF <-> SPDIF mapping ok
[ 3.198927@1] asoc-aml-card auge_sound: soc:dummy <-> TDM-C mapping ok
VontarX4:~ # dmesg | grep auge
[ 0.095649@0] amlogic auge_snd_iomap probe done
[ 3.071337@2] asoc-aml-card auge_sound: IRQ audio_exception64 not found
[ 3.072830@2] asoc-aml-card auge_sound: SPDIF-B <-> SPDIF-B mapping ok
[ 3.072935@2] asoc-aml-card auge_sound: TDM-B <-> TDM-B mapping ok
[ 3.073002@2] asoc-aml-card auge_sound: SPDIF <-> SPDIF mapping ok
[ 3.073084@2] asoc-aml-card auge_sound: soc:dummy <-> TDM-C mapping ok
[ 16.596613@3] asoc-aml-card auge_sound: S/PDIF[1] Playback enable
[ 16.596742@3] asoc-aml-card auge_sound: S/PDIF[1] Playback enable
Ugoos-X4-Pro:~ # ls -al /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:auge_sound
lrwxrwxrwx 1 root root 0 Oct 11 22:34 /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:auge_sound -> ../../../../virtual/devlink/fe000000.apb4:pinctrl@4000--auge_sound
Ugoos-X4-Pro:~ # ls -al /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:fe06c000.i2c
lrwxrwxrwx 1 root root 0 Oct 11 22:34 /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:fe06c000.i2c -> ../../../../virtual/devlink/fe000000.apb4:pinctrl@4000--fe06c000.i2c
VontarX4:~ # ls -al /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:auge_sound
ls: /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:auge_sound: No such file or directory
VontarX4:~ # ls -al /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:fe06c000.i2c
ls: /sys/devices/platform/soc/fe000000.apb4/fe000000.apb4:pinctrl@4000/consumer:fe06c000.i2c: No such file or directory
actually
if I apply auge_sound section of the ugoos patch and build dtb sc2_s905x4_4g_1gbit
then analog audio does work just fine
#include "sc2_s905x4_2g_1gbit.dts"
coreelec-dt-id = "sc2_s905x4_4g_1gbit";
memory@00000000 {
linux,usable-memory = <0x0 0x000000 0x0 0xf1000000>;
auge_sound {
avout_mute-gpios = <&gpio GPIOD_2 GPIO_ACTIVE_HIGH>;
aml-audio-card,dai-link@1 {
codec {
sound-dai = <&amlogic_codec>;
&drm_vpu {
logo_addr = "0xf0800000";
and (note fe01a000.t9015)
VontarX4:~ # dmesg | grep -i auge
[ 0.095533@0] amlogic auge_snd_iomap probe done
[ 3.053049@1] asoc-aml-card auge_sound: IRQ audio_exception64 not found
[ 3.259892@1] asoc-aml-card auge_sound: SPDIF-B <-> SPDIF-B mapping ok
[ 3.259981@1] asoc-aml-card auge_sound: fe01a000.t9015 <-> TDM-B mapping ok
[ 3.260058@1] asoc-aml-card auge_sound: SPDIF <-> SPDIF mapping ok
[ 3.260146@1] asoc-aml-card auge_sound: soc:dummy <-> TDM-C mapping ok
[ 3.412992@3] #0: AML-AUGESOUND
[ 16.993387@0] asoc-aml-card auge_sound: S/PDIF[1] Playback enable
[ 16.993517@0] asoc-aml-card auge_sound: S/PDIF[1] Playback enable
[ 89.759163@0] asoc-aml-card auge_sound: S/PDIF[1] Playback disable
[ 89.759216@0] asoc-aml-card auge_sound: S/PDIF[1] Playback disable
[ 89.777041@1] asoc-aml-card auge_sound: TDM[1] Playback enable
So this fixes problem, but, is it sc2_s905x4 generic or does it need a separate dts?
I am somewhat of a n00b and propose experts find the exact spot to patch CE ![]()
I didn’t use avout_mute-gpios that’s why it works with your complete changes.
We need to think how to apply this change - to think if can be used generally (probably not) or only for Vontar (which doesn’t have separate dtb).
I believe to see in Vontar shop all X4 models have 4GB RAM and 1Gbps Ethernet. Different models only differ in storage 32|64|128 GB.
So a separate sc2_s905x4_vontar_x4.dts derived by including sc2_s905x4_4g_1gbit.dts might perhaps be safe.
The hardware works well for CE ne, though I have no opportunity to test optical audio so I cannot speak for that part.
I never was able to get analog audio out working in CE on any of my ah2xx devices so I am not sure it is just Vontar
What I meant to say is that I don’t know if a change is good for all devices. It can help but at the same time it can broke some other devices. Who knows.
fwiw: following Vontar X4 specific sc2_s905x4_vontar_x4.dts seems to do well
(Makefile needs update as well)
#include "sc2_s905x4_4g_1gbit.dts"
model = "Vontar X4";
coreelec-dt-id = "sc2_s905x4_vontar_x4";
auge_sound {
codec {
I tried to create a pull request on github to support Vontar X4 and fix Vontar X4 analog audio but I have no contributor status. Would anyone perhaps consider committing this new sc2_s905x4_vontar_x4.dts file? All Vontar X4 have 4GB RAM and 1Gbps Eth, so (apart from storage) are identical.
any news in this update i have same problem
tasinofan, ken you post your compile db, please
For which image is needed?
CoreELEC-Amlogic-ne.aarch64-20.3-Nexus_nightly_20240102
sc2_s905x4_vontar_x4.dtb (72.1 KB)
no loque dont work, ken you post yours.
I think tasinofan needs to tell exactly what is needed.
It is based on this
Vontar X4 (S905X4): install to eMMC? - #28 by tasinofan
this first post loques different
using this one CoreELEC-Amlogic-no.aarch64-21.0-Omega_nightly_20240103, the audio works, dont no if it helps
With which DTB?
White The One its comes white it, sc2_s905x4_4g_1gbit.dts
I don’t see what can be wrong. I hope tasinofan will help again and I will push the changes to repository for NE device.
